Re: T-56 Magnum Mini-Starter Issues With QuickTime bell housing
[Re: NITROUSN]
#3017248
02/21/22 12:38 AM
02/21/22 12:38 AM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
You should not need to grind the block. If the block was the problem the starter would not work no matter what bell housing is used. Simple concept here. The flywheel is fixed off the crankshaft. The bell locates the starter. This is the same with any bell. If your starter is not fitting the block is not the problem. I have heard of the starters not fitting but that was the wiring block on the starter. Lots of minis you just removed the block. The metal dust shield still should be used. I have the kit behind my Hemi. My bets are this. Are the dowels in place? Was the bell housing dialed in properly. Dials are in place, everything looks good, I can’t confirm the bell was dialed in properly as I can’t get ahold of the installer. Hopefully tomorrow I’ll get ahold of him. The block was removed form the mini and a relocation kit Was installed. Don’t ever remember having any problems with the 4-speed and factory starter. I’ve read several articles people claiming to have everything dialed in and they still had to grind the block to make the mini work. I mean if the QuickTime was so perfect why do they send a top shim with it? I was reading from the QuickTime installation paper that sometimes after get it dialed you make have to buy offset dials from Lakewood. Maybe this is the problem???
[Re: 70RT Charger]
#3017308
02/21/22 11:43 AM
02/21/22 11:43 AM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I mean if the QuickTime was so perfect why do they send a top shim with it? That is a bushing. The bell you have has no pocket for the starter to fit into. The starter has a larger hole and the bushing locates the starter correctly. All bell housings should have the register dialed in. Your instructions state that in step 3. Every one I have done needed a correction. Once you get readings you can then determine how much of an offset dowel you will need. I use these as they are easily removed and adjustable. Dowels
[Re: NITROUSN]
#3017427
02/21/22 06:10 PM
02/21/22 06:10 PM
70RT Charger
eastern,Ky
I mean if the QuickTime was so perfect why do they send a top shim with it? That is a bushing. The bell you have has no pocket for the starter to fit into. The starter has a larger hole and the bushing locates the starter correctly. All bell housings should have the register dialed in. Your instructions state that in step 3. Every one I have done needed a correction. Once you get readings you can then determine how much of an offset dowel you will need. I use these as they are easily removed and adjustable. Dowels I just found out my bell housing was not dialed in at all. I called SST and they were nice enough to sell me a gauge plate at half cost because when I bought one of the first T-56 kits there wasn’t any instructions from them about dialing it in but there was instructions from QuickTime at the time covering the dialing in, my installer didn’t read them. I’ve watched several videos and now I understand the process. I don’t think I’ve got to drive it long to hurt anything. Thanks for the advise.
[Re: 70RT Charger]
#3017489
02/21/22 08:57 PM
02/21/22 08:57 PM
70RT Charger
eastern,Ky
What do you mean by gauge plate? As far as I know all kits have instructions and you must do the bell run out and send them your numbers. Otherwise the warranty is void. Bell run out Like I said. I bought one of the very first Magnum kits offered. I have all of the original paper work, recommended videos and I’m pretty for sure there was no such thing as sending anybody any numbers for bell run out for warranty. Im thinking it was only after the matter of fact that they applied the bell run out numbers to the warranty but it doesn’t matter. SST has been really good to me and helpful. The guy I spoke to at SST even brought that to my attention, that’s why he gave me a big discount on the index plate. QuickTime did have instructions like I mentioned but my installer didn’t read them. I just want to get it fixed correctly, my warranty is up anyways lol.
[Re: 70RT Charger]
#3017511
02/21/22 09:32 PM
02/21/22 09:32 PM
NITROUSN
What do you mean by gauge plate? As far as I know all kits have instructions and you must do the bell run out and send them your numbers. Otherwise the warranty is void. Bell run out I see now what it does. If you do not have it with that style transmission and the bell it requires you can not dial it in.
[Re: 70RT Charger]
#3017513
02/21/22 09:34 PM
02/21/22 09:34 PM
NITROUSN
What do you mean by gauge plate? As far as I know all kits have instructions and you must do the bell run out and send them your numbers. Otherwise the warranty is void. Bell run out Like I said. I bought one of the very first Magnum kits offered. I have all of the original paper work, recommended videos and I’m pretty for sure there was no such thing as sending anybody any numbers for bell run out for warranty. Im thinking it was only after the matter of fact that they applied the bell run out numbers to the warranty but it doesn’t matter. SST has been really good to me and helpful. The guy I spoke to at SST even brought that to my attention, that’s why he gave me a big discount on the index plate. QuickTime did have instructions like I mentioned but my installer didn’t read them. I just want to get it fixed correctly, my warranty is up anyways lol. I hear what you are saying. The shop that you paid should of known that.
[Re: NITROUSN]
#3017527
02/21/22 10:00 PM
02/21/22 10:00 PM
70RT Charger
eastern,Ky
What do you mean by gauge plate? As far as I know all kits have instructions and you must do the bell run out and send them your numbers. Otherwise the warranty is void. Bell run out Like I said. I bought one of the very first Magnum kits offered. I have all of the original paper work, recommended videos and I’m pretty for sure there was no such thing as sending anybody any numbers for bell run out for warranty. Im thinking it was only after the matter of fact that they applied the bell run out numbers to the warranty but it doesn’t matter. SST has been really good to me and helpful. The guy I spoke to at SST even brought that to my attention, that’s why he gave me a big discount on the index plate. QuickTime did have instructions like I mentioned but my installer didn’t read them. I just want to get it fixed correctly, my warranty is up anyways lol. I hear what you are saying. The shop that you paid should of known that. I’ll agree!
