Re: fabricated oil pan
[Re: AndyF]
#3015907
02/16/22 08:58 AM
02/16/22 08:58 AM
Posts: 9,847 MI, usa
dvw
MI, usa
Here are the dimensions for one of the pans Andy showed that Charlie made for me. Its been a good pan for me. There is a front baffle, a rear bolt in baffle, and a swing trap door below the center link tube. You can see the baffles in Andy's picture.The factory dipstick location will not work. A dipstick tube was fabbed to fit in the right side kick out. Its calibrated to read oil in the pan, not the engine itself. If there are 7 qts in the pan it never fluctuates. Even at 6 qts the only time I saw anything was on hard braking. The center link hole may need adjustment for your engine placement. But a good welder should be able to copy it. Doug
[Re: Dragula]
#3015965
02/16/22 12:48 PM
02/16/22 12:48 PM
Posts: 566 Texas
RustyM
Texas
Thanks guys, your all a blessing. Last two seasons i worked pretty hard at reducing parasitic losses and we picked up good mph and lowered 60fts and et . Now that we are building this BMP block at 540 ci , i'm trying to do my due diligence with oil control, windage. Someone on here about a year or so ago ( might be 2, im old) mentioned an Engine masters oil pan shootout so, i went and found it- was amazed. Talked to some engine builders with dynos that confirmed this wasn't a fluke, it matters, 20-30 hp power of mattering in some cases . There is a plethora of good pans for the chevy and ford crowd and, yes, i understand why but, never imagined the pickings would be so slim for us Mopar guys, not on oil pans anyway. So, as usual, i come here and get some links- thanks guys, i honestly don't know what we little guys running mopars would do without this site, you folks. Yes, we know this will be expensive but, 20--30 hp at this level always seems expensive- grin. Thanks again.
[Re: RustyM]
#3015969
02/16/22 12:54 PM
02/16/22 12:54 PM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
Windage is an issue with a BBM for sure. Oil in suspension because of the design of the pan and skirted block is an issue for sure. Poor windage control will exacerbate that for sure. Billet Fab, Moroso, Williams Perfromance, can all make custom pans and also have anumber of shelf units that are pretty nice as well.
[Re: HardcoreB]
#3018160
02/23/22 06:08 PM
02/23/22 06:08 PM
Posts: 248 near St Petersburg, FL
Lifsgrt
Stan at Stef's did a fantastic job on the custom dry sump pan he built for my 499" Bonneville wedge. Buit exactly to my external dimensions, fits perfect. If you design it he can build it.
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
