Msd.. street fire plug wires on 440 #3013107
02/07/22 04:52 PM
02/07/22 04:52 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Was thinking of buying a set msd. Street fires plug wires. For the 440 They are pre assembled and have straight plug ends on them
Will they fit with out touching the headers?
I have never had any luck with a straight plug. With headers
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Msd.. street fire plug wires on 440 [Re: toplescuda] #3013334
02/08/22 01:08 PM
02/08/22 01:08 PM
moparx Offline
moparx  Offline
do you have the headers you are going to run ?
if so, they should tell you if they will work with straight plug boots.
if you do not have the headers, i would wait until you do. then buy plug wires with the correct ends that will work.
don't be surprised if you need a combination of various ends so the boots do not touch the pipes.
beer
Re: Msd.. street fire plug wires on 440 [Re: moparx] #3013342
02/08/22 01:35 PM
02/08/22 01:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ This.
I usually end up with mostly 90-degree boots on a BB.
And usually run them below the headers, often with the factory brackets.
Re: Msd.. street fire plug wires on 440 [Re: topside] #3013349
02/08/22 01:55 PM
02/08/22 01:55 PM
moparx Offline
moparx  Offline
i forgot to say, angle plug heads [RPM's and others] can require different combinations than straight plug heads.
it all hinges on what you are going to use for headers. get them first before even thinking about plug wires.
you may even consider buying a roll of plug wire and a bunch of different ends, then making a custom set of wires. it's not all that hard to do, but it can be a little more expensive. if i can do it, "a caveman can"............ biggrin
beer
Re: Msd.. street fire plug wires on 440 [Re: moparx] #3013353
02/08/22 02:05 PM
02/08/22 02:05 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
I wanted factory terminated plug ends, had to by 2 sets. 1 90* 1 str. used 4 of each. b-body with hooker headers, now have spare set. you do not want 5-7 running side by side 1-8-4-3-6-5-7-2, "they say" they will crossfire.
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Msd.. street fire plug wires on 440 [Re: 440lebaron] #3013366
02/08/22 02:28 PM
02/08/22 02:28 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Go Firecore.
You can specify which boot you want for each wire.
Some of the best wires I've had (better than MSD, Taylor, etc.)
'63 Dodge 330
11.19 @ 121 mph
Re: Msd.. street fire plug wires on 440 [Re: GY3] #3013395
02/08/22 03:20 PM
02/08/22 03:20 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Firecore here too, get the three types of bare boots, 90-45-straight and try each cylinder with installed header.
Spec that to Firecore, he generally can tell you lengths based on your combo.
Joe
Re: Msd.. street fire plug wires on 440 [Re: jlatessa] #3013453
02/08/22 04:58 PM
02/08/22 04:58 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
On my 383 and my 440, I really needed an assortment to work perfectly. Some cylinders called for straight, some 45, and some 90.
I'd get the headers first, then custom order a set wire-by-wire. As others have said, there are sets that you can order that way.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Msd.. street fire plug wires on 440 [Re: wingman] #3013466
02/08/22 05:36 PM
02/08/22 05:36 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Firecore here also.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Msd.. street fire plug wires on 440 [Re: 70sixpkrt] #3013932
02/10/22 05:29 AM
02/10/22 05:29 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I already have the headers. Bought years ago. Off eBay. And that is bout all I remember about them. And that the bolt holes fit like crap lol
Car has been a back burner for years. And it's just a little here. Little there as time goes by. And while time. Money and work. Permits
1971 charger
Re: Msd.. street fire plug wires on 440 [Re: toplescuda] #3014020
02/10/22 01:13 PM
02/10/22 01:13 PM
moparx Offline
moparx  Offline
saying the bolt holes fit like crap prompted me to relay this to you.
cut the flanges between the end pipes and the center pair.
drill the one hole to 25/64, drill the other hole to 7/16 or 29/64 on each pipe flange.
doing this will almost guarantee the pipes will seal.
this allows the pipes to move around a little bit during the heating and cooling process, preventing leaks to occur.
i stole this idea from member Mr. P-Body 20 years or so ago, and even the junkiest set of headers sealed up perfectly ! boogie
beer
Re: Msd.. street fire plug wires on 440 [Re: moparx] #3014072
02/10/22 04:24 PM
02/10/22 04:24 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Buttcrack has it right, done this on two sets now, nary a leak.
I didn't do the larger hole fix, but I'm sure that helps with fitment too.
Joe
Re: Msd.. street fire plug wires on 440 [Re: toplescuda] #3015951
02/16/22 12:14 PM
02/16/22 12:14 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I bought the 8.5mm Super Conductors. They have straight boots that have a spot that can be bent. Work with TTi headers. Weird thing is there is no mention in the instructions. I called MSD.
I’m listening.
