Msd.. street fire plug wires on 440
#3013107
02/07/22 04:52 PM
02/07/22 04:52 PM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Was thinking of buying a set msd. Street fires plug wires. For the 440 They are pre assembled and have straight plug ends on them Will they fit with out touching the headers? I have never had any luck with a straight plug. With headers
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Msd.. street fire plug wires on 440
[Re: toplescuda]
#3013334
02/08/22 01:08 PM
02/08/22 01:08 PM
Posts: 19,342 north of coder
moparx
do you have the headers you are going to run ? if so, they should tell you if they will work with straight plug boots. if you do not have the headers, i would wait until you do. then buy plug wires with the correct ends that will work. don't be surprised if you need a combination of various ends so the boots do not touch the pipes.
[Re: moparx]
#3013353
02/08/22 02:05 PM
02/08/22 02:05 PM
Posts: 1,604 westerly, ri. usa
440lebaron
westerly, ri. usa
I wanted factory terminated plug ends, had to by 2 sets. 1 90* 1 str. used 4 of each. b-body with hooker headers, now have spare set. you do not want 5-7 running side by side 1-8-4-3-6-5-7-2, "they say" they will crossfire.
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#3013366
02/08/22 02:28 PM
02/08/22 02:28 PM
Posts: 4,667 Wichita
GY3
Wichita
Go Firecore.
You can specify which boot you want for each wire.
Some of the best wires I've had (better than MSD, Taylor, etc.)
[Re: jlatessa]
#3013453
02/08/22 04:58 PM
02/08/22 04:58 PM
Posts: 3,372 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
On my 383 and my 440, I really needed an assortment to work perfectly. Some cylinders called for straight, some 45, and some 90.
I'd get the headers first, then custom order a set wire-by-wire. As others have said, there are sets that you can order that way.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: 70sixpkrt]
#3013932
02/10/22 05:29 AM
02/10/22 05:29 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
I already have the headers. Bought years ago. Off eBay. And that is bout all I remember about them. And that the bolt holes fit like crap lol
Car has been a back burner for years. And it's just a little here. Little there as time goes by. And while time. Money and work. Permits
[Re: toplescuda]
#3014020
02/10/22 01:13 PM
02/10/22 01:13 PM
moparx
saying the bolt holes fit like crap prompted me to relay this to you. cut the flanges between the end pipes and the center pair. drill the one hole to 25/64, drill the other hole to 7/16 or 29/64 on each pipe flange. doing this will almost guarantee the pipes will seal. this allows the pipes to move around a little bit during the heating and cooling process, preventing leaks to occur. i stole this idea from member Mr. P-Body 20 years or so ago, and even the junkiest set of headers sealed up perfectly !
[Re: toplescuda]
#3015951
02/16/22 12:14 PM
02/16/22 12:14 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I bought the 8.5mm Super Conductors. They have straight boots that have a spot that can be bent. Work with TTi headers. Weird thing is there is no mention in the instructions. I called MSD.
I’m listening.
