What's broke in my trans? #3010641
01/30/22 07:40 PM
01/30/22 07:40 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Went to Speedworld in Orlando today for test n tune
Girlfriend made 4 good passes 11 teen range.
Last run she got to staging lane and no forward gears...
Car backs up perfect but any forward gear feels like neutral.
493 wedge in 69 GTX. Full automatic valve body 727 built by JW transmissions back around 1999.
Yeah it has about 30,000 street miles and maybe 2000 passes.
There is a 3000 stall Turbo action converter in front that has been in this car about 20 years.
Any ideas? And how do I confirm?
Re: What's broke in my trans? [Re: mercman1] #3010651
01/30/22 08:07 PM
01/30/22 08:07 PM
IL
Dart451 Offline
Dart451  Offline
IL
Bellview spring
Littel more info
Has same ting happen few years ago
Re: What's broke in my trans? [Re: mercman1] #3010656
01/30/22 08:20 PM
01/30/22 08:20 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
What color is the fluid? If it's brown and smells, you lost the forward clutch pack.. If it's red, time to pull the pan to see what's in it.
Joe
Without Data, you’re just another guy with an opinion.
Re: What's broke in my trans? [Re: sr4440] #3010701
01/30/22 11:33 PM
01/30/22 11:33 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Forward clutch. (rear clutch). The drum with the input shaft sticking out of it. Take it apart.
I'm assuming manual VB. If not, look at the roller clutch as well.
NVM, just saw automatic. Manual low should apply the rear band. No go in manual low, forward clutch. Either way, it's coming out.
Re: What's broke in my trans? [Re: CMcAllister] #3010748
01/31/22 10:00 AM
01/31/22 10:00 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
YEP it lost the forward clutch, forward clutch is applied in all the forward gears so it takes a lot of abuse. Direct clutch is applied with the low band for reverse. If you do the work yourself, make sure the sealing rings and grooves on the stator support are in good shape, high RPM and just a little bushing clearance will damage them, causing an internal pressure leak, taking out the forward clutch.
Re: What's broke in my trans? [Re: jwb123] #3010761
01/31/22 10:30 AM
01/31/22 10:30 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Could also be a stripped front planet on the output shaft. Been there.
Doug
Re: What's broke in my trans? [Re: Dart451] #3011035
02/01/22 07:50 AM
02/01/22 07:50 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
Originally Posted by Dart451
Bellview spring
Littel more info
My guess is this also
Re: What's broke in my trans? [Re: dvw] #3011220
02/01/22 05:34 PM
02/01/22 05:34 PM
NC
440Jim Offline
440Jim  Offline
NC
The newer design belleville spring is less prone to cracking/breaking. But it does have a different height, so use the matching clutch piston.
