727 lost forward gears #2363896
09/02/17 03:21 AM
09/02/17 03:21 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Just got back from track was running good, made 6 runs around 10.2. Let the car cool for a couple minutes and lost all forward gears. Still has reverse, and when you apply trans brake in first, it tries to back up.
727 trans was rebuild be decent shop around 25 passes. Not sure who valve body, but don't need to apply trans brake to back up in reverse.
What first thing I should check in the morning?
Dragweek coming fast.
Re: 727 lost forward gears [Re: Dart451] #2363898
09/02/17 03:25 AM
09/02/17 03:25 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
Bellview spring .
Had the same thing happen earlier this year .
Re: 727 lost forward gears [Re: Dart451] #2363902
09/02/17 03:48 AM
09/02/17 03:48 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A weak Belleville spring allows the rear clutch piston to pop out of its bore. The Belleville spring on the left is more robust than the one on the right but requires the matching piston.
Re: 727 lost forward gears [Re: Dart451] #2364007
09/02/17 12:35 PM
09/02/17 12:35 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Ok will pull trans an have shop check it out. Need to learn how to do more tranny work myself
