Re: starting technique
[Re: lancer493]
#3009537
01/27/22 10:59 AM
01/27/22 10:59 AM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
i'v always cranked it first when hot, seemed to start better, 13 to 1 might need start retard when hot or flip key while cranking
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#3009540
01/27/22 11:12 AM
01/27/22 11:12 AM
Posts: 10,022 MN
JERICOGTX
MN
I always turn mine over before hitting the ignition switch.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3009543
01/27/22 11:20 AM
01/27/22 11:20 AM
Posts: 8,257 fredericksburg,va
cudaman1969
fredericksburg,va
All the engines I had and my buddy had, flip switch and crank, one (two at the max) turn and it fired. Sounds easy but a lot of prep went into that. One engine was 15.19 to 1
[Re: lancer493]
#3009549
01/27/22 12:00 PM
01/27/22 12:00 PM
Posts: 2,917 A shed in England
Tig
A shed in England
From cold, a few pumps of the gas pedal and go from there. Hot, just turn the key. Ignition is always on while cranking, We use an MSD Grid, from memory it has about 18 degrees of timing at 200rpm rising to 36 @ 1200. We take 4 degrees out in 3rd gear. Mopar (Denso?) mini starter too 12.5:1 580. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: lancer493]
#3009585
01/27/22 01:31 PM
01/27/22 01:31 PM
Posts: 43,172 Bend,OR USA
Cab_Burge
Which ignition and how much timing at cranking RPM? I use the mechanical advance in my distributor in my S/P E 85 stroker motor (508 C.I.) with 15.1 to 1 comp ratio, it idles at 16 degrees BTDC and has 34 degrees total at 2200 RPM, I turn the ignition on before cranking with no issues, so far Some of the later model ignition MSD boxes won't fire the coil until the crank turns over twice
[Re: Cab_Burge]
#3009593
01/27/22 01:54 PM
01/27/22 01:54 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
With the old MSD 6AL boxes I always just fire them up like normal. Ignition on and hit the starter. This works on a 14.5:1 440, an 11:1 575" hemi, and a 15:1 436" SB chevy
My current 6AL-2 programmable likes to kick back and I haven't figured out the run retard program deal.
[Re: an8sec70cuda]
#3009753
01/27/22 08:43 PM
01/27/22 08:43 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
My 12.8:1 stock stroke deal was wired to the stock starter with a 7AL2 in it former life. When warm, crack throttle a hair and hit key and it fired no problem. If you didn't crack the throttle the engine would go a revolution or two and then fire.
On the other hand if you lock out the timing it would make sense to crank and then fire i.e. with a crank trigger. Chances are if you have a crank trigger you also have some electronic capable of controlling timing to some degree. If not you can find an old school MSD 3 step timing retard box for reasonable money. Definitely verify the actual number if you use one damhik.
[Re: Jeremiah]
#3009758
01/27/22 08:52 PM
01/27/22 08:52 PM
Posts: 9,835 MI, usa
dvw
MI, usa
572, 15-1 34 degrees fixed. Big plenum. Cold, pump 3 times. Let it set 30 seconds. throttle cracked. Crank with ignition on 2 revolutions or less. Warm 1 pump same scenario. Very warm, no pump. Starts in less than 1 revolution. Very cold gets a cloth fender cover over the carbs. Doug
[Re: dvw]
#3009821
01/27/22 11:28 PM
01/27/22 11:28 PM
Posts: 781 wine country
8urvette
wine country
I had some issue with a few "built" 440s.
What I ended up finding out, bigger battery cable from trunk to starter is required, go bigger than the kits suggest. Get a bigger battery and make sure your grounds are good.
Once these were issues remedied 3 large CI engines crank like low compression small blocks!!! Timing retard and igntion kill not needed then. If weight isnt a huge issue, i got the biggest truck battery i could get. The last one from NAPA had over 1000 CCAs.
