starting technique #3009534
01/27/22 10:54 AM
01/27/22 10:54 AM
St.Pete,Florida
lancer493 Offline OP
St.Pete,Florida
So as not to highjack the battery thread, what type of starting techniques are recommended for carbed , 13-1 big block, race only motors. Question is whether to crank the engine first and then flip on the ignition switch or turn on ignition first then crank the motor. I am using chrysler mini starters. May sound trivial, but I would like to hear of some of your experiences. Thanks, Bill
Re: starting technique [Re: lancer493] #3009537
01/27/22 10:59 AM
01/27/22 10:59 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
i'v always cranked it first when hot, seemed to start better, 13 to 1 might need start retard when hot or flip key while cranking
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: starting technique [Re: 440lebaron] #3009540
01/27/22 11:12 AM
01/27/22 11:12 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I always turn mine over before hitting the ignition switch.
69 GTX 68 Road Runner
Re: starting technique [Re: JERICOGTX] #3009543
01/27/22 11:20 AM
01/27/22 11:20 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
All the engines I had and my buddy had, flip switch and crank, one (two at the max) turn and it fired. Sounds easy but a lot of prep went into that. One engine was 15.19 to 1
Re: starting technique [Re: lancer493] #3009549
01/27/22 12:00 PM
01/27/22 12:00 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
From cold, a few pumps of the gas pedal and go from there. Hot, just turn the key. Ignition is always on while cranking, We use an MSD Grid, from memory it has about 18 degrees of timing at 200rpm rising to 36 @ 1200. We take 4 degrees out in 3rd gear. Mopar (Denso?) mini starter too 12.5:1 580. HTH's up
Re: starting technique [Re: Tig] #3009574
01/27/22 01:12 PM
01/27/22 01:12 PM
WI
mopar873 Offline
mopar873  Offline
WI
This is always what I did as well.^ 13.5:1 compression worked fine
Re: starting technique [Re: lancer493] #3009585
01/27/22 01:31 PM
01/27/22 01:31 PM
Which ignition and how much timing at cranking RPM?
I use the mechanical advance in my distributor in my S/P E 85 stroker motor (508 C.I.) with 15.1 to 1 comp ratio, it idles at 16 degrees BTDC and has 34 degrees total at 2200 RPM, I turn the ignition on before cranking with no issues, so far luck
Some of the later model ignition MSD boxes won't fire the coil until the crank turns over twice scope
Re: starting technique [Re: Cab_Burge] #3009593
01/27/22 01:54 PM
01/27/22 01:54 PM
an8sec70cuda Offline
With the old MSD 6AL boxes I always just fire them up like normal. Ignition on and hit the starter. This works on a 14.5:1 440, an 11:1 575" hemi, and a 15:1 436" SB chevy
My current 6AL-2 programmable likes to kick back and I haven't figured out the run retard program deal.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: starting technique [Re: an8sec70cuda] #3009753
01/27/22 08:43 PM
01/27/22 08:43 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
My 12.8:1 stock stroke deal was wired to the stock starter with a 7AL2 in it former life. When warm, crack throttle a hair and hit key and it fired no problem. If you didn't crack the throttle the engine would go a revolution or two and then fire.
On the other hand if you lock out the timing it would make sense to crank and then fire i.e. with a crank trigger. Chances are if you have a crank trigger you also have some electronic capable of controlling timing to some degree. If not you can find an old school MSD 3 step timing retard box for reasonable money. Definitely verify the actual number if you use one damhik.
Re: starting technique [Re: Jeremiah] #3009758
01/27/22 08:52 PM
01/27/22 08:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
572, 15-1 34 degrees fixed. Big plenum. Cold, pump 3 times. Let it set 30 seconds. throttle cracked. Crank with ignition on 2 revolutions or less. Warm 1 pump same scenario. Very warm, no pump. Starts in less than 1 revolution. Very cold gets a cloth fender cover over the carbs.
Doug
Re: starting technique [Re: dvw] #3009821
01/27/22 11:28 PM
01/27/22 11:28 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
I had some issue with a few "built" 440s.
What I ended up finding out, bigger battery cable from trunk to starter is required, go bigger than the kits suggest. Get a bigger battery and make sure your grounds are good.
Once these were issues remedied 3 large CI engines crank like low compression small blocks!!! Timing retard and igntion kill not needed then. If weight isnt a huge issue, i got the biggest truck battery i could get. The last one from NAPA had over 1000 CCAs.
Re: starting technique [Re: lancer493] #3009895
01/28/22 11:17 AM
01/28/22 11:17 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Starter button, oil pressure, ignition
