New tunnel ram top #3003317
01/08/22 11:24 PM
01/08/22 11:24 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
I built this dual 4 Barrel tunnel ram top with sheer plates. What are your thoughts how it will work? For a 800 HP W7 small block
Re: New tunnel ram top [Re: Plymouth340] #3003326
01/08/22 11:57 PM
01/08/22 11:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
Try it and let us know your results wrench up
Good luck, it looks really good bow up
Re: New tunnel ram top [Re: Cab_Burge] #3003485
01/09/22 03:19 PM
01/09/22 03:19 PM
moparx Offline
moparx  Offline
very NICE fab work ! up bow
as Cab said, please let us know how it works !
beer
Re: New tunnel ram top [Re: Plymouth340] #3003494
01/09/22 04:15 PM
01/09/22 04:15 PM
tboomer Offline
tboomer  Offline
Looks nice Mike!
Re: New tunnel ram top [Re: tboomer] #3003671
01/09/22 11:41 PM
01/09/22 11:41 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
All the tunnel ram intake tops I've seen have a 3D machined insert that the shear plate fitted on to. They usually just featured a radius to transition from the carb to the plenum.
Alan Jones
Re: New tunnel ram top [Re: LA360] #3003692
01/10/22 02:03 AM
01/10/22 02:03 AM
CEDAR RAPIDS
CEDAR RAPIDS
Re: New tunnel ram top [Re: Plymouth340] #3003698
01/10/22 03:01 AM
01/10/22 03:01 AM
Reversion plates are worth some HP on engine dyno tests I've done up
Re: New tunnel ram top [Re: Plymouth340] #3003715
01/10/22 09:13 AM
01/10/22 09:13 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
From what I can see everything 'looks' right. Are the runners optimized to your application? Regardless, if you've converted a single 4 top to the dual top, I'd say that'll show some measurable gains! The anti-revesion plates as has been mentioned will help too. What's going on top of those???
Re: New tunnel ram top [Re: HardcoreB] #3003835
01/10/22 03:02 PM
01/10/22 03:02 PM
CEDAR RAPIDS
CEDAR RAPIDS
Got two APD 950s coming ...before i was running a single 1200 on this tunnel ram
Re: New tunnel ram top [Re: Plymouth340] #3004823
01/13/22 10:28 AM
01/13/22 10:28 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nearly every time I see or hear 'sheer plates' I assume 'ANTI-REVERSION' is what was meant but, I'd be wrong. I'd pop for a good pair of anti-reversion plates (for a number of reasons) and make whatever mods are necessary to fit those. In my experiences, 'those' will almost certainly show improvement on 'line-of-sight' runner orientation configurations. Wilson are the one's I've seen and used but there are others that are THAT STYLE that'll work. Other brands just don't come to mind ATM.
Re: New tunnel ram top [Re: HardcoreB] #3005416
01/15/22 12:19 AM
01/15/22 12:19 AM
CEDAR RAPIDS
CEDAR RAPIDS
So what is the difference between sheer plates and anti reversion plates? On Wilson manifolds website I see nothing that's said anti-reversion plate
Re: New tunnel ram top [Re: Plymouth340] #3005824
01/16/22 03:32 AM
01/16/22 03:32 AM
LA360 Offline
LA360  Offline
They are the same thing from what I have been lead to believe. Any others I refer to as a transition spacer. I took this information from a podcast or video with Darin Morgan. I figure he knows more than I do.
Alan Jones
Re: New tunnel ram top [Re: LA360] #3005831
01/16/22 03:40 AM
01/16/22 03:40 AM
LA360 Offline
LA360  Offline
I will attach some examples, hopefully it works
Open transition for a shear plate
Alan Jones
Re: New tunnel ram top [Re: LA360] #3005833
01/16/22 03:41 AM
01/16/22 03:41 AM
LA360 Offline
LA360  Offline
4 hole transition spacer
Alan Jones
Re: New tunnel ram top [Re: LA360] #3005840
01/16/22 03:47 AM
01/16/22 03:47 AM
LA360 Offline
LA360  Offline
Shear/Anti Reversion Plate
Alan Jones
Re: New tunnel ram top [Re: LA360] #3005842
01/16/22 03:51 AM
01/16/22 03:51 AM
LA360 Offline
LA360  Offline
This is the type of insert I referred to earlier
Alan Jones
Re: New tunnel ram top [Re: LA360] #3006436
01/18/22 10:05 AM
01/18/22 10:05 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
The extended cones do a good job keeping direct pulses from 'talking' to the carbs, that is the specific type I was mentioning. Thanks for the pics Alan.
Re: New tunnel ram top [Re: HardcoreB] #3006526
01/18/22 01:34 PM
01/18/22 01:34 PM
CEDAR RAPIDS
CEDAR RAPIDS
This is the shear plate i'm using on top of my tunnel ram
Re: New tunnel ram top [Re: Plymouth340] #3006535
01/18/22 01:48 PM
01/18/22 01:48 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I did the same with my top. I also made white nylon spacer for heat dissipation on the street. If you look closely you can see it sandwiched in there.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: New tunnel ram top [Re: 6PKRTSE] #3006592
01/18/22 07:06 PM
01/18/22 07:06 PM
CEDAR RAPIDS
CEDAR RAPIDS
Looks good
