Re: 440 fuel pump install questions [Re: fal3] #3000172
12/30/21 11:48 PM
12/30/21 11:48 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Use an air hose to blow through the fuel line from the pump back to the gas tank. Get someone to help so you can crawl under the car and listen for air. Lots of these old cars have rotten rubber fuel lines attaching to the sending unit in the tank. If the line checks out you probably have a bad fuel pump. New parts do not mean working parts anymore unfortunately.
Re: 440 fuel pump install questions [Re: TJP] #3000223
12/31/21 09:25 AM
12/31/21 09:25 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
BTW you can use the gauge for bench testing as well. As far as a new pushrod goes I'd look for NOS or do some serious research as I've had several new ones fail, some claimed. indestructible made from unobtanium whistling
As far as travel goes, if someone had a BB camshaft they could measure the lobe height, subtract the OD of the lobe and you would have the travel. Ideally measuring the lift it in a block or lathe would be more accurate. That would give you an indication of how much wear on the pushrod might be tolerable beer
Re: 440 fuel pump install questions [Re: TJP] #3000232
12/31/21 10:38 AM
12/31/21 10:38 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree blow thru the fuel inlet at tank to push gas to the pump.As for NOS member here has a suppy of them.Great price and they work Got mine about 4 years or more fro him to replace the crappy MP one.Rocky
Chrysler Firepower
Re: 440 fuel pump install questions [Re: therocks] #3000249
12/31/21 11:45 AM
12/31/21 11:45 AM
central il.
second 70 Offline
second 70  Offline
central il.
I worked on a friends truck a few years ago that had dual tanks and he thought it was stuck in between tanks. I couldn't find anything wrong so I got a can of gas and put the inlet hose into can which proved it was the pump even though it was new. Took 3 new pumps before I got 1 that worked.
Re: 440 fuel pump install questions [Re: fal3] #3000255
12/31/21 12:00 PM
12/31/21 12:00 PM
Pasadena, Texas
fal3 Offline OP
fal3  Offline OP
Pasadena, Texas
Thanks to all for your input. I will use recommendations to get this ride running. Happy New Year men!!
Re: 440 fuel pump install questions [Re: fal3] #3000276
12/31/21 01:20 PM
12/31/21 01:20 PM
moparx Offline
moparx  Offline
did i mention to check the tank vent ? take the gas cap off, then see if the pump works. if it does, the cap or the vent system needs looked at.
beer
Re: 440 fuel pump install questions [Re: mopars4ever] #3000407
12/31/21 06:27 PM
12/31/21 06:27 PM
BDW Online content
BDW  Online Content
Originally Posted by mopars4ever
Not sure if this is your problem but I had a car that was not getting suction from a cracked rubber fuel line. Might be worth a check. Sometimes you can`t visually see the cracks in the hose.
This is exactly what happened to me, pump would not work not matter what I tried.
Finally found a cracked rubber hose feeding the steel line and all was well after that.
Re: 440 fuel pump install questions [Re: fal3] #3004626
01/12/22 04:16 PM
01/12/22 04:16 PM
Pasadena, Texas
fal3 Offline OP
fal3  Offline OP
Pasadena, Texas
Ok, wanted to get back to youse guys that provided info. Had 2 problems going on. 1 purchased another fuel rod that measured 3.24" 2. hose from tank to gas line was soft and weepy (FYI-second time I had to replace this hose; my theory is ethanol laced gas is playing hell with the rubber). Replaced hose; installed new pump rod and new pump (for those that asked Summit was supplier of pump), and vroom car started. As stated, wanted to let youse know car ran. Seems people come on here asking for advice, but seldom report back on findings.
Re: 440 fuel pump install questions [Re: fal3] #3004630
01/12/22 04:28 PM
01/12/22 04:28 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Thanks for the update. up
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 440 fuel pump install questions [Re: fal3] #3004748
01/12/22 10:04 PM
01/12/22 10:04 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up for the feedback as most don't frown
Also the Newer fuel hose and pump should be ethanol compatible. Might want to change the other fuel hoses as well if you haven't already beer
Re: 440 fuel pump install questions [Re: TJP] #3004867
01/13/22 12:54 PM
01/13/22 12:54 PM
70sixpkrt Offline
70sixpkrt  Offline
What fuel pump did you end up using?
4-speed
3:54 Dana
Re: 440 fuel pump install questions [Re: 70sixpkrt] #3004893
01/13/22 02:06 PM
01/13/22 02:06 PM
moparx Offline
moparx  Offline
it's always good to hear of a good outcome to a problem. up
beer
Re: 440 fuel pump install questions [Re: fal3] #3005651
01/15/22 05:17 PM
01/15/22 05:17 PM
Pasadena, Texas
fal3 Offline OP
fal3  Offline OP
Pasadena, Texas
master: used the summit one.
