good source for weatherstripping? #3003463
01/09/22 02:16 PM
01/09/22 02:16 PM
ILLINOIS
V
volaredon Offline OP
V
ILLINOIS
Looking for all new OEM style weatherstripping for '85 D150. who's a good source? Best bang for buck. Not looking for the most expensive, nor the cheapest, for sake of bragging either way.
and I remember there being a difference in back window weatherstrip on these, for solid back window vs slider vs OEM slider vs aftermarket slider??? What is different among them?
truck currently has original solid back window. I have a late 80s/early 90s factory slider window to go back in.
Need the lock strips too/ Who do you guys get yours from? Prefer USA made/ definitely something other than made in China!!!
Re: good source for weatherstripping? [Re: volaredon] #3003474
01/09/22 02:52 PM
01/09/22 02:52 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Depending on what exactly you are looking for some weatherstripping is not reproduced so not much choice there. I believe the factory subbed the sliders from C.R. Laurence
may check there. A few other places for weatherstripping...
https://www.steelerubber.com/
https://www.lmctruck.com/dodge
Re: good source for weatherstripping? [Re: Moparite] #3003561
01/09/22 07:35 PM
01/09/22 07:35 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
For weather stripping that may no longer be reproduced, often you can but the rubber shaped in the form you need, at the correct size, from generic rubber supply outlets like JC Whitney (really) and others, at by the foot prices. Get the length you need, then use superglue to connect the ends. It may not be the best stuff, but it is sure better then nothing.
Weatherstripping is expensive! Gene
Re: good source for weatherstripping? [Re: poorboy] #3003590
01/09/22 08:50 PM
01/09/22 08:50 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I bought seal and lock strip with end pieces from Ebay. It worked fine. https://www.ebay.com/sch/i.html?_fr..._nkw=dodge+truck+lock+strip&_sacat=0
Re: good source for weatherstripping? [Re: stumpy] #3003601
01/09/22 09:02 PM
01/09/22 09:02 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: good source for weatherstripping? [Re: moparmarks] #3003926
01/10/22 08:51 PM
01/10/22 08:51 PM
ILLINOIS
V
V
ILLINOIS
eventually looking to replace it ALL. so far, I have some for the wing windows is all.
Re: good source for weatherstripping? [Re: volaredon] #3004078
01/11/22 11:35 AM
01/11/22 11:35 AM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
I'm pretty sure that this is the only manufacturer of rubber products for the older dodge trucks.
https://www.prp.com/
everyone else is likely re-selling Precision's products.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: good source for weatherstripping? [Re: shanker] #3004503
01/12/22 11:30 AM
01/12/22 11:30 AM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
Steele also makes there own products - PRP and Steele are the only two out there
David S.
Part Time Owner
Dodge Connection
www.dodgeconnection.com
904-209-9388
Re: good source for weatherstripping? [Re: volaredon] #3005098
01/13/22 10:59 PM
01/13/22 10:59 PM
Guitar Jones Offline
No one makes the weatherstrip for the factory slider. Haven't seen an NOS one for sale in a very long time. The windshield gaskets suck, they are too small and a total pain in the butt to install. The solid rear window gasket is the same as a Ford part, no lock strip in that. Wing window seals for the 87-93 are also not available and the early window belt weatherstrips are terrible as well. The straight ones. Channel runs are ok but you may find some of the trucks don't have the holes for the pins installed in the run so they have to be removed. The on body door weatherstrips seem to be to thick as the doors don't want to close well. Some are really bad like my crew cab. So bad after replacing one I took it back out, no amount of adjustment could get the door to close.
In short yeah new weatherstrips are nice but the available offerings leave something to be desired. I wouldn't replace any you don't have to.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: good source for weatherstripping? [Re: Guitar Jones] #3005223
01/14/22 12:18 PM
01/14/22 12:18 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I’m a little confused on the part names, I need the ‘fuzzys’ on a 88, the piece that rides against the glass at bottom of glass opening (the piece that scratches your arm when window is down) proper name? Are these available?
Re: good source for weatherstripping? [Re: cudaman1969] #3005291
01/14/22 04:03 PM
01/14/22 04:03 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
Also known as cat whiskers or fuzzies or beltline seals or... https://www.dodgeconnection.com/catalog/item/6756240/5555466.htm
David S.
Part Time Owner
Dodge Connection
904-209-9388
Re: good source for weatherstripping? [Re: LilRed7879] #3005292
01/14/22 04:06 PM
01/14/22 04:06 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Re: good source for weatherstripping? [Re: cudaman1969] #3005320
01/14/22 06:20 PM
01/14/22 06:20 PM
Window belt mouldings or weatherstrips and they are available, unless it's for the rear door of a crew cab. Then you have to modify the front door pieces to fit the rear door.
Edit; actually anything for the rear door of a crew cab isn't available. Front door parts have to be modified to fit.
