Re: good source for weatherstripping?
[Re: volaredon]
#3004078
01/11/22 11:35 AM
01/11/22 11:35 AM
Posts: 5,758 Corpus Christi, TX
shanker
Corpus Christi, TX
I'm pretty sure that this is the only manufacturer of rubber products for the older dodge trucks. https://www.prp.com/everyone else is likely re-selling Precision's products.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: shanker]
#3004503
01/12/22 11:30 AM
01/12/22 11:30 AM
Posts: 1,442 Orange Park FL.
LilRed7879
Orange Park FL.
I'm pretty sure that this is the only manufacturer of rubber products for the older dodge trucks. https://www.prp.com/everyone else is likely re-selling Precision's products. Steele also makes there own products - PRP and Steele are the only two out there
[Re: volaredon]
#3005098
01/13/22 10:59 PM
01/13/22 10:59 PM
Posts: 17,727 in a cattle trailer down by th...
Guitar Jones
No one makes the weatherstrip for the factory slider. Haven't seen an NOS one for sale in a very long time. The windshield gaskets suck, they are too small and a total pain in the butt to install. The solid rear window gasket is the same as a Ford part, no lock strip in that. Wing window seals for the 87-93 are also not available and the early window belt weatherstrips are terrible as well. The straight ones. Channel runs are ok but you may find some of the trucks don't have the holes for the pins installed in the run so they have to be removed. The on body door weatherstrips seem to be to thick as the doors don't want to close well. Some are really bad like my crew cab. So bad after replacing one I took it back out, no amount of adjustment could get the door to close. In short yeah new weatherstrips are nice but the available offerings leave something to be desired. I wouldn't replace any you don't have to.
I raise chickens, so I am literally a chicken tender.
The Scamp is sold, now just two old trucks and one new one. '92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NP435, D44, D60 and NP205 divorced transfer case. NV4500 coming soon. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: cudaman1969]
#3005320
01/14/22 06:20 PM
01/14/22 06:20 PM
Guitar Jones
I’m a little confused on the part names, I need the ‘fuzzys’ on a 88, the piece that rides against the glass at bottom of glass opening (the piece that scratches your arm when window is down) proper name? Are these available? Window belt mouldings or weatherstrips and they are available, unless it's for the rear door of a crew cab. Then you have to modify the front door pieces to fit the rear door. Edit; actually anything for the rear door of a crew cab isn't available. Front door parts have to be modified to fit.
