Page 2 of 3 1 2 3
Re: 5/8" wheel studs [Re: d330] #3002167
01/04/22 11:07 PM
01/04/22 11:07 PM
gregsdart Offline
gregsdart  Offline
For those that want to run 1/2 inch studs, reaching the best clamp load is a must. Check on final torque specs and talk to experts about what lube if any to use. Think of them like rod bolts, because they are affected the same way. Thread friction is a large part of the torque spec. Get that wrong and clamp load will be off, allowing twisting forces to break the studs.
Re: 5/8" wheel studs [Re: d330] #3002179
01/04/22 11:32 PM
01/04/22 11:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Part of the issue is the amount of surface area between the wheel and rotor. If it's minimal, it takes way more clamping force to keep from bending the studs. Factory steel wheels have the least contact.
Doug
Re: 5/8" wheel studs [Re: d330] #3002198
01/05/22 03:16 AM
01/05/22 03:16 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by d330
I have a 3650 lbs car with a 4 speed runs 9:40s-50s. Low 1:30s 60ft Times. 1/2 ARP bolts without issues.
Good luck.
I have a buddy with a very similar combination. Dead hooks it and controls the 60s in the bellhousing. Car is nearly trouble free at this point. I know what he's gone through with that and helped fix a lot of it.
Re: 5/8" wheel studs [Re: CMcAllister] #3002200
01/05/22 05:45 AM
01/05/22 05:45 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I think the shear force of a 8 D finish nail is somewhere in the 5000 pound range, so.. Of course my friends 63 Polara with one of those aftermarket K-frames sheared off a 3/4 grade 8 bolt on the lca just backing-hard turning out of his garage, might have been just loose, the maker did make a brace to get double clamping to fix the issue. Grade 5 is a better stud-bolt to use on axels. I also think the type of wheel used has a lot do with strength, thick (Pro Star type vs thin (Centerline, Borgart), shorter the stud the stronger or less apt to bend over.
Re: 5/8" wheel studs [Re: cudaman1969] #3002214
01/05/22 09:12 AM
01/05/22 09:12 AM
an8sec70cuda Offline
When I first switched to 5/8" studs, I asked around about drilling and tapping my axles myself. EVERYONE said send them back to the manufacturer to have it done. So back to Moser they went. Biggest problem was finding a box to ship them in. I've kept a couple of axle boxes in storage since then, lol. Kind of like header boxes. Don't think about it until you need one, then it's a PITA.
5/8" studs makes changing tires/wheels so much easier too.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 5/8" wheel studs [Re: an8sec70cuda] #3002221
01/05/22 09:45 AM
01/05/22 09:45 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I changed because all the cool kids did it…. Honestly it was just one of those things we looked at and thought of as a very good safety upgrade as we entered the mid 9 zone. Pretty cheap protection considering the catastrophic damage that can result from breakage. It should have been done when my dad had the S60 built, but was probably an over-site. Kind of like a billet drum in a 727…. Pretty cheap insurance in the scope of the mayhem that can incur….
Re: 5/8" wheel studs [Re: J_BODY] #3002473
01/06/22 12:33 AM
01/06/22 12:33 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
What do you guys torque your 5/8" lug nuts to?
Re: 5/8" wheel studs [Re: mopowers] #3002478
01/06/22 01:44 AM
01/06/22 01:44 AM
Cab_Burge Online work
Cab_Burge  Online Work
100 to 120 Ft. lbs. wrench up
Re: 5/8" wheel studs [Re: mopowers] #3002490
01/06/22 07:03 AM
01/06/22 07:03 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
100
68 Barracuda Formula S 340
Re: 5/8" wheel studs [Re: Bad340fish] #3002505
01/06/22 08:58 AM
01/06/22 08:58 AM
100
iagree
CHIP
Re: 5/8" wheel studs [Re: an8sec70cuda] #3002509
01/06/22 09:20 AM
01/06/22 09:20 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
100
iagree
69 GTX 68 Road Runner
Re: 5/8" wheel studs [Re: JERICOGTX] #3002600
01/06/22 02:05 PM
01/06/22 02:05 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
100
iagree
I stripped a stud pulling off my race tires at Byron on drag week. So I had to use every Ugga Dugga i had available when I put my race tires on for friday...still haven't taken those tires off ha.
Re: 5/8" wheel studs [Re: an8sec70cuda] #3002742
01/06/22 09:57 PM
01/06/22 09:57 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Hahahaha X2 on all this, Chip!
"Any fool can know. The point is to understand"
- A. Einstein
Re: 5/8" wheel studs [Re: EvilB1Dart] #3002756
01/06/22 10:55 PM
01/06/22 10:55 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Many years ago, I got set of axles from a very reputable manufacturer that were beautiful in every way, except the stud holes weren't threaded for the 1/2" studs I intended to use. Yes they were ordered for screw in studs and the studs were even in the box separately.
Oh well, easy fix I thought. After wrecking a 1/2-20 tap and not putting a scratch in the holes, I sent them back. The company apologized, fixed them and life went on.
Re: 5/8" wheel studs [Re: CMcAllister] #3004161
01/11/22 02:50 PM
01/11/22 02:50 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Questions from a guy that doesn't have a lot of experience drag racing, but is building a car for it:
1. The 5/8" Studs are really only suggested for the rear (drive axles) of the vehicle, not the front too, correct?
2. I have some Weld wheels, and some old Cragar Super Trick wheels that use long threaded shank lug nuts. Will I need to get completely different wheels if I opt for 5/8" studs?
I am asking these questions because I am getting ready to order a Dana 60 OR a Fabricated 9" for my Cuda build - and was already thinking about stepping up to 5/8" studs.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: 5/8" wheel studs [Re: 19swinger70] #3004182
01/11/22 03:42 PM
01/11/22 03:42 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
1) Yes. 1/2" on the front.
2) The holes in the wheels you have should be 11/16" and the shank of a nut for those fits those holes. 5/8" studs also have an 11/16" shoulder in the middle that also acts as the wheel interface. The wheel will slide over those when being installed. The fit should not be sloppy. If it's too tight to install with some wiggling, the holes in the wheels may need to be finessed - honed or filed, don't get the drill out. The studs you purchase need to be sized for the thickness of the wheel center. The shoulder portion needs to protrude out of the wheel some amount - typically ~1/2" - with an appropriate spacer used under the nut.
Strange has a selection of studs for use with all common wheels. Look at that for a better explanation. Personal experience causes me to recommend the one piece machined studs over the bolt with a sleeve style. Or look up the Strange instruction sheet for them.
Re: 5/8" wheel studs [Re: CMcAllister] #3004191
01/11/22 04:20 PM
01/11/22 04:20 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Thank you for that information - good to know!
55 Plymouth Project
Re: 5/8" wheel studs [Re: CMcAllister] #3004605
01/12/22 03:28 PM
01/12/22 03:28 PM
moparx Offline
moparx  Offline
i thank you as well for that chart ! bow
beer
Re: 5/8" wheel studs [Re: moparx] #3004625
01/12/22 04:11 PM
01/12/22 04:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We torque all ours to 125ft/lbs.
Re: 5/8" wheel studs [Re: Al_Alguire] #3004727
01/12/22 08:50 PM
01/12/22 08:50 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
125lbs is what i was told also. asked several racers. so that's what I do.
Page 2 of 3 1 2 3
