hi ,
need a blow proof bell for a small block 340 mopar .
does anyone make one that has a removable bottom to be able to inspect or change clutch without total removal ?
other wise if not who makes or has the old standby one piece ?
thank you !
If you don’t mind the size, find a used Lakewood. You can find them on feebay and on forums like this pretty regular. Then you call Lakewood (freaking Holley) and have them set you up to put a window in it. When it comes back it will have the window, a new cert and it will look like brand new. Also, ask for the big window. They have 2 sizes and the big window makes adjustments a bit quicker. I have the small window and I can do an adjustment in 12-15 minutes. Less if I’m just adjusting base pressure.
