Biow proof bell small block ? #3000201
12/31/21 02:13 AM
12/31/21 02:13 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi ,
need a blow proof bell for a small block 340 mopar .
does anyone make one that has a removable bottom to be able to inspect or change clutch without total removal ?
other wise if not who makes or has the old standby one piece ?
thank you !
Re: Biow proof bell small block ? [Re: calrobb2000] #3000203
12/31/21 02:41 AM
12/31/21 02:41 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
For a 10.5 or 10.95 / 130 tooth fluwheel single disc b&b clutch sstup the Quicktime is okay with some minor modification.
If I was going to get a new bell with a removable window I would call Quicktime and see what they can do in the custom shop. Anything that uses a 143 tooth flywheel requires a Lakewood which is the rather bulky 15335 model. Get out the hammer.
Beyond that you could call Browell and see what they can do for a door car. Not sure how they hande the z bat mounts, etc.
Are you running an a833?
Re: Biow proof bell small block ? [Re: calrobb2000] #3000218
12/31/21 08:18 AM
12/31/21 08:18 AM
Washington
madscientist Offline
Washington
Originally Posted by calrobb2000
hi ,
thank you !
If you don’t mind the size, find a used Lakewood. You can find them on feebay and on forums like this pretty regular. Then you call Lakewood (freaking Holley) and have them set you up to put a window in it. When it comes back it will have the window, a new cert and it will look like brand new. Also, ask for the big window. They have 2 sizes and the big window makes adjustments a bit quicker. I have the small window and I can do an adjustment in 12-15 minutes. Less if I’m just adjusting base pressure.
Re: Biow proof bell small block ? [Re: calrobb2000] #3000254
12/31/21 11:57 AM
12/31/21 11:57 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
PM sent
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
