Progress - slow going #2996590
12/18/21 10:30 PM
12/18/21 10:30 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I have been making progress on my Daytona engine upgrade to the new B1 572 CID. But it has been slow.
Today's milestone was removing the existing iron headed engine from the car. I need the oil pump since it has both the external oil filter connections needed for the chassis; and the external oil pickup connection which I need to make the pickup lines for the new motor with the new oil pan, etc. I think I have now received all the fittings/lines for the B1 oil drain back lines. Time to cut holes in the new oil pan and make the lines fit.
I did make notes and measurements of the engine midplate, firewall, etc. for the oil drain back lines fitting in the chassis.
Re: Progress - slow going [Re: 440Jim] #2996609
12/18/21 11:10 PM
12/18/21 11:10 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Slow going? Yeah, I can relate. grin
That's gonna be a pretty righteous ride when it's all back together. drool
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Progress - slow going [Re: Brad_Haak] #2996610
12/18/21 11:20 PM
12/18/21 11:20 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Low and steady they say thumbs
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Progress - slow going [Re: BloFish] #2996613
12/18/21 11:28 PM
12/18/21 11:28 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
As usual, another nice piece of hardware, Jim!
Just don’t look at all your receipts for the fittings and lines for that motor when it’s done! It adds up quickly!
What’s it going to weigh when fully wet without driver? I can’t wait to see the performance numbers on it when you’re done.
Wes
"Any fool can know. The point is to understand"
- A. Einstein
Re: Progress - slow going [Re: BloFish] #2996614
12/18/21 11:32 PM
12/18/21 11:32 PM
gregsdart Offline
gregsdart  Offline
I was thinking in terms of Minnesota weàther, which fortunately you don't have. Tracks open mid to late April, early May. I am still waiting on heads, and maybe pistons. When do you want to be race ready?
Re: Progress - slow going [Re: EvilB1Dart] #2996693
12/19/21 11:47 AM
12/19/21 11:47 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Wes
Wes,
I scaled the car with the iron engine and it was 2,608 lbs with 3 gallons of gas (2,838 with driver).
So with the aluminum block and aluminum heads I hope to lose about 150 lbs.
Re: Progress - slow going [Re: gregsdart] #2996695
12/19/21 11:51 AM
12/19/21 11:51 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Greg,
The B1 engine needs the oil pan and lines, then I need to put the lifters, pushrods, rockers on it.
I need to temporarily put the B1 engine in the car to build the new 2-1/4" headers. Then dyno it with the new headers.
I think I need more fuel pump/system to supply enough alky to feed the HP increase, TBD...
I did go to a test & tune in Mar 2021, so Mar would be about the earliest. Points racing in April.
Re: Progress - slow going [Re: 440Jim] #2997961
12/23/21 05:55 PM
12/23/21 05:55 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I swapped the oil pump from the Daytona engine to my new B1 engine. So I began mockups/fitting the external oil lines near the end of the day today.
These B1 heads have drain back lines to the pan also...
Re: Progress - slow going [Re: 440Jim] #2997985
12/23/21 07:10 PM
12/23/21 07:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I actually just found that same pan here with the drainback lines on it already. Just not new.
Re: Progress - slow going [Re: 440Jim] #2998037
12/23/21 09:50 PM
12/23/21 09:50 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
What’s it beergoing to weigh when fully wet without driver?
Wes
Wes,
Good deal! That is going to haul some serious a$$ LOL! beer
- A. Einstein
Re: Progress - slow going [Re: 440Jim] #2998068
12/23/21 10:31 PM
12/23/21 10:31 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Hope those valve covers don't leak! whistling
Re: Progress - slow going [Re: EvilB1Dart] #2998085
12/23/21 10:59 PM
12/23/21 10:59 PM
gregsdart Offline
gregsdart  Offline
Wes
Wes,
Jim, I hope you have a 7.50 cage cert😳
Re: Progress - slow going [Re: markz528] #2998149
12/24/21 10:12 AM
12/24/21 10:12 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
O-ring seal, thanks Mark!
Re: Progress - slow going [Re: Al_Alguire] #2998150
12/24/21 10:19 AM
12/24/21 10:19 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
With all those B1 parts, you must have been doing the B1 heads for a long time.
I wish the drain back lines could be above the oil level. For less chance of oil seepage at the fitting hole.
But with the location of the factory weld on the Milodon pan, I think the holes will be below the built-in windage tray.
Re: Progress - slow going [Re: 440Jim] #3004998
01/13/22 06:16 PM
01/13/22 06:16 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I am ready to start building the headers for the B1 engine.
The power plant is in the car, sitting on the engine mounts (midplate and front plate).
That B1 head drain line on the rear passenger side is a snug fit between the firewall and the midplate.
And the other side is just as tight between the head and the midplate. But they are done, and I was able to route them inside the chassis frame tubes. So the engine drops right in with the lines installed.
Re: Progress - slow going [Re: 440Jim] #3005010
01/13/22 07:08 PM
01/13/22 07:08 PM
birdtracker Offline
birdtracker  Offline
Did you do the valve covers? Birdtracker
Re: Progress - slow going [Re: birdtracker] #3005024
01/13/22 07:44 PM
01/13/22 07:44 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Different features were done by various people.
Re: Progress - slow going [Re: 440Jim] #3005169
01/14/22 09:21 AM
01/14/22 09:21 AM
birdtracker Offline
birdtracker  Offline
I was interested in getting a set done so that the vacuum pump would work better. Birdtracker
Re: Progress - slow going [Re: birdtracker] #3005176
01/14/22 09:57 AM
01/14/22 09:57 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I bought these valve covers used. They had spray bar oiling in them, one side had a 12AN o-ring fitting (female) welded on. The other was a 1.2" grommet hole. I had a local welder put a 12AN male fitting in that hole. Other work/features were done by other people. The aluminum weld fittings are widely available (Summit, Jegs, etc).
Re: Progress - slow going [Re: 440Jim] #3005182
01/14/22 10:12 AM
01/14/22 10:12 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice updates Jim. Still very excited to see it going fast. If you believe your conservative estimates, you'll be pleasantly surprised with how well it runs.
