Re: Progress - slow going
[Re: 440Jim]
#2996609
12/18/21 11:10 PM
12/18/21 11:10 PM
Posts: 1,072 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Slow going? Yeah, I can relate. That's gonna be a pretty righteous ride when it's all back together.
2021 Challenger 6.4L Scat Pack 1320 (2022) 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) wheels, tires, air filter: 1.714, 11.833 at 115.80 (DA 310 ft)
1973 Challenger 452 ci street/strip (2008) pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: BloFish]
#2996613
12/18/21 11:28 PM
12/18/21 11:28 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
As usual, another nice piece of hardware, Jim! Just don’t look at all your receipts for the fittings and lines for that motor when it’s done! It adds up quickly! What’s it going to weigh when fully wet without driver? I can’t wait to see the performance numbers on it when you’re done.
Wes
"Any fool can know. The point is to understand"
- A. Einstein
[Re: BloFish]
#2996614
12/18/21 11:32 PM
12/18/21 11:32 PM
Posts: 9,963 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I was thinking in terms of Minnesota weàther, which fortunately you don't have. Tracks open mid to late April, early May. I am still waiting on heads, and maybe pistons. When do you want to be race ready?
[Re: EvilB1Dart]
#2996693
12/19/21 11:47 AM
12/19/21 11:47 AM
Posts: 16,916 NC
440Jim
NC
What’s it going to weigh when fully wet without driver? Wes Wes, I scaled the car with the iron engine and it was 2,608 lbs with 3 gallons of gas (2,838 with driver). So with the aluminum block and aluminum heads I hope to lose about 150 lbs.
[Re: gregsdart]
#2996695
12/19/21 11:51 AM
12/19/21 11:51 AM
Posts: 16,916 NC
440Jim
NC
When do you want to be race ready? Greg, The B1 engine needs the oil pan and lines, then I need to put the lifters, pushrods, rockers on it. I need to temporarily put the B1 engine in the car to build the new 2-1/4" headers. Then dyno it with the new headers. I think I need more fuel pump/system to supply enough alky to feed the HP increase, TBD... I did go to a test & tune in Mar 2021, so Mar would be about the earliest. Points racing in April.
[Re: 440Jim]
#2997985
12/23/21 07:10 PM
12/23/21 07:10 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
I actually just found that same pan here with the drainback lines on it already. Just not new.
[Re: 440Jim]
#2998037
12/23/21 09:50 PM
12/23/21 09:50 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
What’s it going to weigh when fully wet without driver? Wes Wes, I scaled the car with the iron engine and it was 2,608 lbs with 3 gallons of gas (2,838 with driver). So with the aluminum block and aluminum heads I hope to lose about 150 lbs. Good deal! That is going to haul some serious a$$ LOL!
- A. Einstein
[Re: 440Jim]
#2998068
12/23/21 10:31 PM
12/23/21 10:31 PM
Posts: 4,267 Morrow, OH
markz528
Morrow, OH
I swapped the oil pump from the Daytona engine to my new B1 engine. So I began mockups/fitting the external oil lines near the end of the day today. These B1 heads have drain back lines to the pan also... Hope those valve covers don't leak!
[Re: EvilB1Dart]
#2998085
12/23/21 10:59 PM
12/23/21 10:59 PM
gregsdart
What’s it going to weigh when fully wet without driver? Wes Wes, I scaled the car with the iron engine and it was 2,608 lbs with 3 gallons of gas (2,838 with driver). So with the aluminum block and aluminum heads I hope to lose about 150 lbs. Good deal! That is going to haul some serious a$$ LOL! Jim, I hope you have a 7.50 cage cert😳
[Re: Al_Alguire]
#2998150
12/24/21 10:19 AM
12/24/21 10:19 AM
Posts: 16,916 NC
440Jim
NC
I actually just found that same pan here with the drainback lines on it already. Just not new. With all those B1 parts, you must have been doing the B1 heads for a long time. I wish the drain back lines could be above the oil level. For less chance of oil seepage at the fitting hole. But with the location of the factory weld on the Milodon pan, I think the holes will be below the built-in windage tray.
[Re: birdtracker]
#3005024
01/13/22 07:44 PM
01/13/22 07:44 PM
Posts: 16,916 NC
440Jim
NC
Did you do the valve covers? Birdtracker Different features were done by various people.
