Page 1 of 3 1 2 3
Fresh 512. Does this sound ok #2997153
12/20/21 09:22 PM
12/20/21 09:22 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
Just got the 512 fired up broke cam in. Then tore valve train off and installed inner springs. Does it sound like it has a slight miss or is that sound i hear normal??
https://vm.tiktok.com/TTPdjwMTab/
Re: Fresh 512. Does this sound ok [Re: Mally69] #2997161
12/20/21 09:48 PM
12/20/21 09:48 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
Just sounds like it has a slight intermittent miss when at idle.
Re: Fresh 512. Does this sound ok [Re: Mally69] #2997182
12/20/21 10:45 PM
12/20/21 10:45 PM
Sounds like someone beating on the car starter with the ignition key, is the motor running?
I would pull all the spark plugs now and see how black they are and see if they have oil on them scope twocents
How old was the gas you use to break-in the cam?
Did you degree the cam or install it with the timing gear dots align?
Try another sound tests standing at the back of the car so we can hear the exhaust better up twocents
Re: Fresh 512. Does this sound ok [Re: Mally69] #2997185
12/20/21 10:47 PM
12/20/21 10:47 PM
AndyF Offline
AndyF  Offline
You can't hear a miss with open headers and a big cam. If you think a cylinder is weak then use a temp gun on the header tubes. Another test is to use a timing light on each cylinder to verify each wire has a good spark.
Re: Fresh 512. Does this sound ok [Re: AndyF] #2997190
12/20/21 10:53 PM
12/20/21 10:53 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
I def have no exhaust on the car. Its open headers. Gas was new idk if its just me or if its the lopey ass cam. Its a fairly large cam heres the specs below11.1 comp
Re: Fresh 512. Does this sound ok [Re: Mally69] #2997193
12/20/21 10:57 PM
12/20/21 10:57 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
This is the largest cam and build ive ever done. So like i said it could all be in my head what i think i am hearing is as its idleing there seems like a quick short hesitation in the rythem. From time to time.
Re: Fresh 512. Does this sound ok [Re: Mally69] #2997215
12/21/21 01:10 AM
12/21/21 01:10 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Firing order 18436572. Notice that 2 cylinders on each bank fire consecutively and the rest alternate from bank to bank. Sometimes at idle you can hear or feel that and think it is a miss. In other words - left right right left right left left right.
How fast is that idling? Might be a bit slow for that size cam.
Re: Fresh 512. Does this sound ok [Re: Mally69] #2997217
12/21/21 01:40 AM
12/21/21 01:40 AM
AndyF Offline
AndyF  Offline
That is exactly what I'd expect that cam to sound like at idle with open headers. Doesn't sound like it has a lot of compression, a high compression engine will sound a little crisper. What is your timing at idle? With that cam you'll want at least 20 degrees at idle, maybe 25. If the timing is slow and the idle speed is slow then the sounds starts to get softer or rounder. Do you have a vacuum gauge? You should have at least 12 inches with that cam in a 512. If you don't then you need to add timing, add speed and check for leaks.
Listen to this one. It is a 505 with 11:1 compression and a 266/272 solid roller cam with open headers: https://www.youtube.com/watch?v=sNeBSOqpO40
Re: Fresh 512. Does this sound ok [Re: AndyF] #2997234
12/21/21 08:42 AM
12/21/21 08:42 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Sounds good. If you think a hole is dead or want to check all. Drip a few drops of water on each header pipe. It will boil off fast it it's firing
Re: Fresh 512. Does this sound ok [Re: FastmOp] #2997238
12/21/21 09:21 AM
12/21/21 09:21 AM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
I think its fine. I just never had one lope that hard before everything seems fine its snappy and revs up very fast. Ill get another video and post it, at least you guys get to hear the beast anyhow. Its in a 69 superbee with 18 spline 4spd dana 60. Not factory equip. Was origionally 383 auto dark blue white stripe.
Re: Fresh 512. Does this sound ok [Re: Mally69] #2997246
12/21/21 10:13 AM
12/21/21 10:13 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
512 sounds great!
Tick over is way toooooo looooow... fan
It’s that front tyre I would be worried about lol... drive
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: Fresh 512. Does this sound ok [Re: Gtxxjon] #2997258
12/21/21 11:14 AM
12/21/21 11:14 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It’s idling way too low. Should be around 1200 when it’s at operating temp.
I doubt it will have over 10” of vacuum....... but I do agree it should have a very short ignition curve with as much initial timing as it will tolerate without causing a hot start problem.
Re: Fresh 512. Does this sound ok [Re: fast68plymouth] #2997263
12/21/21 11:38 AM
12/21/21 11:38 AM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
Ive always had good luck pinning my distributer and setting it where the car runs the smoothest. Thats what i have done here as well. Seems okay. On this one. Im going to start it again today make a few adjustments. Ill post another video. As for suspension its just setting somewhat close until i take it to the alighnment shop. Wheels are just on therr to push it around.haha. i have alot of work to do yet.
Re: Fresh 512. Does this sound ok [Re: Mally69] #2997277
12/21/21 12:32 PM
12/21/21 12:32 PM
UK
rb446 Offline
rb446  Offline
UK
Sounds cool to me, although in a big motor like that it does sound quite lopey there and with such a mild cam, needs a bit of tweaking perhaps, but thats exactly how my all iron 440 sounded with the CC 290@.050 .650/.650 sft in it, ticked over@900rpm.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Fresh 512. Does this sound ok [Re: Mally69] #2997336
12/21/21 03:27 PM
12/21/21 03:27 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
My 12.5:1 511 warmed up idles at 1400 in park with 9" vacuum, in drive at 1100 with 7" vacuum. My timing is 29* initial and 36* all in at 2500rpm. My cam is a SFL with 270/275@50 on 110. Runs great.
Re: Fresh 512. Does this sound ok [Re: Mally69] #2997375
12/21/21 06:17 PM
12/21/21 06:17 PM
West Palm Beach, Florida
Craig J Offline
Craig J  Offline
Sorry I don't know how to do embedded videos on this forum.
494 RB, even with mufflers the idle will not be very smooth with that much cam.
https://youtu.be/lCLDsV0vbTY
Re: Fresh 512. Does this sound ok [Re: Craig J] #2997377
12/21/21 06:24 PM
12/21/21 06:24 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It's through an exhaust, but not much of an exhaust.....First video is not up to temp.
Second video is all the way up to temp/driven for quite awhile + A cleaner tune-up
Rich H.
Esse Quam Videri
Re: Fresh 512. Does this sound ok [Re: Craig J] #2997378
12/21/21 06:24 PM
12/21/21 06:24 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Rich H.
Esse Quam Videri
Re: Fresh 512. Does this sound ok [Re: ZIPPY] #2997381
12/21/21 06:26 PM
12/21/21 06:26 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Rich H.
Esse Quam Videri
Re: Fresh 512. Does this sound ok [Re: ZIPPY] #2997402
12/21/21 07:42 PM
12/21/21 07:42 PM
IL
furious70 Offline
furious70  Offline
IL
I could listen to those all day long....
70 Sport Fury
68 Charger
69 Coronet
72 RR
Page 1 of 3 1 2 3
