Just got the 512 fired up broke cam in. Then tore valve train off and installed inner springs. Does it sound like it has a slight miss or is that sound i hear normal??
Sounds like someone beating on the car starter with the ignition key, is the motor running? I would pull all the spark plugs now and see how black they are and see if they have oil on them How old was the gas you use to break-in the cam? Did you degree the cam or install it with the timing gear dots align? Try another sound tests standing at the back of the car so we can hear the exhaust better
Re: Fresh 512. Does this sound ok
[Re: Mally69]
#2997185 12/20/2110:47 PM12/20/2110:47 PM
You can't hear a miss with open headers and a big cam. If you think a cylinder is weak then use a temp gun on the header tubes. Another test is to use a timing light on each cylinder to verify each wire has a good spark.
[Re: AndyF]
#2997190 12/20/2110:53 PM12/20/2110:53 PM
I def have no exhaust on the car. Its open headers. Gas was new idk if its just me or if its the lopey ass cam. Its a fairly large cam heres the specs below11.1 comp
[Re: Mally69]
#2997193 12/20/2110:57 PM12/20/2110:57 PM
This is the largest cam and build ive ever done. So like i said it could all be in my head what i think i am hearing is as its idleing there seems like a quick short hesitation in the rythem. From time to time.
[Re: Mally69]
#2997215 12/21/2101:10 AM12/21/2101:10 AM
Firing order 18436572. Notice that 2 cylinders on each bank fire consecutively and the rest alternate from bank to bank. Sometimes at idle you can hear or feel that and think it is a miss. In other words - left right right left right left left right.
How fast is that idling? Might be a bit slow for that size cam.
[Re: Mally69]
#2997217 12/21/2101:40 AM12/21/2101:40 AM
That is exactly what I'd expect that cam to sound like at idle with open headers. Doesn't sound like it has a lot of compression, a high compression engine will sound a little crisper. What is your timing at idle? With that cam you'll want at least 20 degrees at idle, maybe 25. If the timing is slow and the idle speed is slow then the sounds starts to get softer or rounder. Do you have a vacuum gauge? You should have at least 12 inches with that cam in a 512. If you don't then you need to add timing, add speed and check for leaks.
I think its fine. I just never had one lope that hard before everything seems fine its snappy and revs up very fast. Ill get another video and post it, at least you guys get to hear the beast anyhow. Its in a 69 superbee with 18 spline 4spd dana 60. Not factory equip. Was origionally 383 auto dark blue white stripe.
[Re: Mally69]
#2997246 12/21/2110:13 AM12/21/2110:13 AM
It’s idling way too low. Should be around 1200 when it’s at operating temp.
I doubt it will have over 10” of vacuum....... but I do agree it should have a very short ignition curve with as much initial timing as it will tolerate without causing a hot start problem.
Ive always had good luck pinning my distributer and setting it where the car runs the smoothest. Thats what i have done here as well. Seems okay. On this one. Im going to start it again today make a few adjustments. Ill post another video. As for suspension its just setting somewhat close until i take it to the alighnment shop. Wheels are just on therr to push it around.haha. i have alot of work to do yet.
[Re: Mally69]
#2997277 12/21/2112:32 PM12/21/2112:32 PM
Sounds cool to me, although in a big motor like that it does sound quite lopey there and with such a mild cam, needs a bit of tweaking perhaps, but thats exactly how my all iron 440 sounded with the CC 290@.050 .650/.650 sft in it, ticked over@900rpm.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: Mally69]
#2997336 12/21/2103:27 PM12/21/2103:27 PM
My 12.5:1 511 warmed up idles at 1400 in park with 9" vacuum, in drive at 1100 with 7" vacuum. My timing is 29* initial and 36* all in at 2500rpm. My cam is a SFL with 270/275@50 on 110. Runs great.
