Teflon tape on ball joint taper ? #2996532
12/18/21 06:50 PM
12/18/21 06:50 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I just had this idea, more than likely it's already been thought about though.
How do you keep the tapered joint from sticking together over the years ?
Would a thin layer of something help keep it from getting so stuck ?
I thought about teflon tape, maybe saran wrap ?
Re: Teflon tape on ball joint taper ? [Re: hemienvy] #2996538
12/18/21 07:07 PM
12/18/21 07:07 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I just replaced the original tie rods on my 51 Plymouth. A few whacks with the hammer and they popped free. Of course, I don't live where they salt the roads and neither did the Plymouth.
Nothing is supposed to go on the tapers, unless you want them to turn in the hole and waller it out.
Re: Teflon tape on ball joint taper ? [Re: Sniper] #2996587
12/18/21 10:26 PM
12/18/21 10:26 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree up
Re: Teflon tape on ball joint taper ? [Re: TJP] #2996588
12/18/21 10:27 PM
12/18/21 10:27 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Yup they're supposed to be a really tight fit to do the job they are supposed to do.
Re: Teflon tape on ball joint taper ? [Re: volaredon] #2996596
12/18/21 10:42 PM
12/18/21 10:42 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
I've got a quality one of these, probably 20 40years old (*%#@, I'm getting old), that's NEVER failed to pop one loose. Usually just put tension on it and give it a whack with the purse and they fall apart...
Hobo Freight screw type separator
Re: Teflon tape on ball joint taper ? [Re: nuthinbutmopar] #2996603
12/18/21 10:54 PM
12/18/21 10:54 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Yeah, I know if the taper shaft turns then you can't tighten the nut.
Grrrrrrr
Nuthinbutmopar, that Harbor Freight thing looks like it would bend / crack. It works though ?
Re: Teflon tape on ball joint taper ? [Re: hemienvy] #2996605
12/18/21 10:55 PM
12/18/21 10:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
This is funny. Got to ask why would you even ask this question.
Re: Teflon tape on ball joint taper ? [Re: nuthinbutmopar] #2996673
12/19/21 10:32 AM
12/19/21 10:32 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I have one like that from harbor freight but it was part of a front end kit. I just tighten it till they pop. Just make sure the threads a lubed with good oil or grease. Most people don't lube their tools. I've had it close to 10 years and was just using it 2 weeks ago, still going strong.
Re: Teflon tape on ball joint taper ? [Re: B1MAXX] #2996676
12/19/21 10:56 AM
12/19/21 10:56 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
use some never seize, I would think that would be the best thing to do, at least that is what I used. Stayed tight enough in the taper to tighten the nut. How much it will help, I dont know. I doubt I will be the one to take it apart again if it ever needs to come apart.
Re: Teflon tape on ball joint taper ? [Re: NITROUSN] #2996702
12/19/21 12:13 PM
12/19/21 12:13 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I'm with you up With racing motorcycles and building them for decades and most having taper fit ignition flywheels using ANYTHING on the taper other than a perfectly clean, grease, oil, etc., free fitment would be a sure chance of failure. There are tens of thousands, make that billions, of ball joint tapers that are fit/installed without anything but a clean, grease and oil free surface for a reason. Get the right tool(s) such as a puller, fork, etc., or the best a BFH and leave the taper clean, it's the way it's supposed to work. twocents
Re: Teflon tape on ball joint taper ? [Re: A12] #2996715
12/19/21 01:01 PM
12/19/21 01:01 PM
moparx Offline
moparx  Offline
nothing on a taper fit, ever. you may be able to get the retaining nut tight, but whatever you put on the taper will eventually work it's way out of the joint and wooly out the taper and ruin both parts.
a clean, grease/oil free mating surface only.
beer
Re: Teflon tape on ball joint taper ? [Re: moparx] #2996782
12/19/21 06:16 PM
12/19/21 06:16 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
If there tightened to the proper torque they'll come apart easier.
Re: Teflon tape on ball joint taper ? [Re: hemienvy] #2996807
12/19/21 08:21 PM
12/19/21 08:21 PM
Their design to not hurt you if they come loose, DON"T use anything to not allow them to get real tight on the interference fit tsk twocents
I use a pickle fork on them and on tie rod ends hammer up scope
How often will you remove them? work whistling grin
Re: Teflon tape on ball joint taper ? [Re: 71GTX471] #2996828
12/19/21 09:08 PM
12/19/21 09:08 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
71 gtx 471,
You know, for some reason I never thought about a torque spec for all those taper joints. Out comes the Manual.
Re: Teflon tape on ball joint taper ? [Re: B1MAXX] #2996857
12/19/21 10:12 PM
12/19/21 10:12 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'll have to politely disagree on the
Quote
part. I've had a few heavy handed employees that used that approach and it sometimes resulted in damaged/broken tools frown Kudo's on the greasing though wink beer
Re: Teflon tape on ball joint taper ? [Re: TJP] #2996948
12/20/21 09:04 AM
12/20/21 09:04 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
They pop with an open end wrench with not too much torque. I've never had to tighten it very much. Have you ever done it? Its nothing and I've done it hundreds of times. shruggy Maybe the employees are even using them right.
