Re: Teflon tape on ball joint taper ?
[Re: hemienvy]
#2996538
12/18/21 07:07 PM
12/18/21 07:07 PM
Posts: 6,279 nowhere
Sniper
nowhere
I just had this idea, more than likely it's already been thought about though.
How do you keep the tapered joint from sticking together over the years ?
Would a thin layer of something help keep it from getting so stuck ?
I thought about teflon tape, maybe saran wrap ? I just replaced the original tie rods on my 51 Plymouth. A few whacks with the hammer and they popped free. Of course, I don't live where they salt the roads and neither did the Plymouth. Nothing is supposed to go on the tapers, unless you want them to turn in the hole and waller it out.
[Re: volaredon]
#2996596
12/18/21 10:42 PM
12/18/21 10:42 PM
Posts: 950 Central Michigan
nuthinbutmopar
Central Michigan
I've got a quality one of these, probably 20 40years old (*%#@, I'm getting old), that's NEVER failed to pop one loose. Usually just put tension on it and give it a whack with the purse and they fall apart... Hobo Freight screw type separator
[Re: hemienvy]
#2996605
12/18/21 10:55 PM
12/18/21 10:55 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I thought about teflon tape, maybe saran wrap ? This is funny. Got to ask why would you even ask this question.
[Re: nuthinbutmopar]
#2996673
12/19/21 10:32 AM
12/19/21 10:32 AM
Posts: 1,993 Apollo, PA.
B1MAXX
Apollo, PA.
I've got a quality one of these, probably 20 40years old (*%#@, I'm getting old), that's NEVER failed to pop one loose. Usually just put tension on it and give it a whack with the purse and they fall apart... Hobo Freight screw type separator I have one like that from harbor freight but it was part of a front end kit. I just tighten it till they pop. Just make sure the threads a lubed with good oil or grease. Most people don't lube their tools. I've had it close to 10 years and was just using it 2 weeks ago, still going strong.
[Re: NITROUSN]
#2996702
12/19/21 12:13 PM
12/19/21 12:13 PM
Posts: 21,521 N.E. OHIO, USA
A12
N.E. OHIO, USA
I'm with you With racing motorcycles and building them for decades and most having taper fit ignition flywheels using ANYTHING on the taper other than a perfectly clean, grease, oil, etc., free fitment would be a sure chance of failure. There are tens of thousands, make that billions, of ball joint tapers that are fit/installed without anything but a clean, grease and oil free surface for a reason. Get the right tool(s) such as a puller, fork, etc., or the best a BFH and leave the taper clean, it's the way it's supposed to work.
[Re: moparx]
#2996782
12/19/21 06:16 PM
12/19/21 06:16 PM
Posts: 1,894 Harriman NY
71GTX471
Harriman NY
If there tightened to the proper torque they'll come apart easier.
[Re: hemienvy]
#2996807
12/19/21 08:21 PM
12/19/21 08:21 PM
Posts: 43,217 Bend,OR USA
Cab_Burge
[Re: B1MAXX]
#2996857
12/19/21 10:12 PM
12/19/21 10:12 PM
Posts: 15,408 Omaha Ne
TJP
Omaha Ne
I'll have to politely disagree on the part. I've had a few heavy handed employees that used that approach and it sometimes resulted in damaged/broken tools Kudo's on the greasing though
[Re: TJP]
#2996948
12/20/21 09:04 AM
12/20/21 09:04 AM
B1MAXX
Apollo, PA.
They pop with an open end wrench with not too much torque. I've never had to tighten it very much. Have you ever done it? Its nothing and I've done it hundreds of times. Maybe the employees are even using them right.
