hurst 4 speed shifter adjustment ??? #2991388
12/02/21 08:54 PM
12/02/21 08:54 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
working on a car with 833 trans with hurst comp pluss shifter .
the two outer shift levers have the alignment hole for the 1/4" pin but the reverse lever no hole for the pin !
sooo how is this shifter adjusted properly !
thank you !
Re: hurst 4 speed shifter adjustment ??? [Re: calrobb2000] #2991417
12/02/21 10:18 PM
12/02/21 10:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
There is a hole unless someone has swapped some parts around. Normally lining up the 3 levers so they are inline (flush) with each other as they exit the shifter housing and then moving them together while trying to insert the alignment gauge will get you there. beer
Re: hurst 4 speed shifter adjustment ??? [Re: TJP] #2991426
12/02/21 10:30 PM
12/02/21 10:30 PM
s. e. pa.
s. e. pa.
hi
yep that sounds right except there is NO hole in the reverse lever !
Re: hurst 4 speed shifter adjustment ??? [Re: calrobb2000] #2991434
12/02/21 10:41 PM
12/02/21 10:41 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Original (OEM) shifters don't have a hole in the reverse arm. The original tool only had a pin long enough that engages the forward arms and forked around them to keep them straight. Not sure that the rev. was that important.
Re: hurst 4 speed shifter adjustment ??? [Re: calrobb2000] #2991435
12/02/21 10:41 PM
12/02/21 10:41 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have seen that before and I just had to keep adjusting the reverse rod until it cleared the gate smoothly. Corvette used a shifter that didn't have holes and there is a "U" shaped adjustment tool that aligns the levers for adjustments. Maybe you could make a tool that would work.
Gus beer
64 Plymouth Savoy
Dana 60
Re: hurst 4 speed shifter adjustment ??? [Re: fourgearsavoy] #2991439
12/02/21 10:47 PM
12/02/21 10:47 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Yes, the out side fork was the only part of the tool that held the reverse arm.
Re: hurst 4 speed shifter adjustment ??? [Re: calrobb2000] #2991444
12/02/21 11:08 PM
12/02/21 11:08 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Correcto...
Some Hurst shifter gates did not have an alignment hole in the reverse arm. Just eyeball it and align the reverse arm with the other 2 levers. When done right the shifter lever will move easy from left to right when in neutral..
Just my $0.02... wink
Re: hurst 4 speed shifter adjustment ??? [Re: Sinitro] #2991508
12/03/21 05:21 AM
12/03/21 05:21 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Originally Posted by Sinitro
Correcto...
Agreed 👍
Re: hurst 4 speed shifter adjustment ??? [Re: B1MAXX] #2991601
12/03/21 12:15 PM
12/03/21 12:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
With the OP saying it was a Comp Plus shifter I assumed it was not an OEM unit but an aftermarket one, My bad spank
And Myself I always offset the reverse lever adjustment a turn or two so one has to 'jiggle" the shifter a bit to get in the "gate". Helps prevent mistakenly putting the car in reverse beer
Re: hurst 4 speed shifter adjustment ??? [Re: calrobb2000] #2991653
12/03/21 01:50 PM
12/03/21 01:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is a special tool to align the levers without three holes. Eyeballing the lever alignment in Neutral with the pin installed has always worked for me.
