Re: hurst 4 speed shifter adjustment ???
[Re: calrobb2000]
#2991435
12/02/21 10:41 PM
12/02/21 10:41 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have seen that before and I just had to keep adjusting the reverse rod until it cleared the gate smoothly. Corvette used a shifter that didn't have holes and there is a "U" shaped adjustment tool that aligns the levers for adjustments. Maybe you could make a tool that would work. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: calrobb2000]
#2991444
12/02/21 11:08 PM
12/02/21 11:08 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Correcto... Some Hurst shifter gates did not have an alignment hole in the reverse arm. Just eyeball it and align the reverse arm with the other 2 levers. When done right the shifter lever will move easy from left to right when in neutral.. Just my $0.02...
[Re: Sinitro]
#2991508
12/03/21 05:21 AM
12/03/21 05:21 AM
Posts: 6,391 Abilene, Texas
fastmark
Abilene, Texas
Correcto... Some Hurst shifter gates did not have an alignment hole in the reverse arm. Just eyeball it and align the reverse arm with the other 2 levers. When done right the shifter lever will move easy from left to right when in neutral.. Just my $0.02... Agreed 👍
[Re: calrobb2000]
#2991653
12/03/21 01:50 PM
12/03/21 01:50 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There is a special tool to align the levers without three holes. Eyeballing the lever alignment in Neutral with the pin installed has always worked for me.
