Thoughts on Beehive Springs? #2991133
12/02/21 02:46 AM
12/02/21 02:46 AM
California
BigDaddy440 Offline OP
California
What are your thoughts and experiences with Beehive Springs?
GM has been using them in their LSX engines for decades with success, but some claim they're junk and they break "all the time" or wear out prematurely. Factory GM camshafts probably don't have super aggressive lobe profiles, but LS engines take a lot of abuse and the springs survive.
They're typically lighter than conventional springs, especially when considering the much smaller retainer than can be used. They also can usually allow for more lift in applications where retainer to valve seal contact is an issue. Lighter valve-train should require less seat pressure to control valve events and less spring pressure should help allow parts to last longer.
My concern with running a Beehive Spring is breakage and a potentially dropped valve which could totally wreck an entire engine. I'm specifically considering a set (non mopar engine) for a fairly small (.510 lift) hydraulic roller camshaft with an aggressive lobe profile. The aggressive lobe fuels my concern.
I noticed Steve Dulcich had some Beehives on a small block mopar recently. I was surprised because I haven't noticed a lot of guys running Beehives on Non-GM engines. Any thoughts or advice would be appreciated.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Thoughts on Beehive Springs? [Re: BigDaddy440] #2991138
12/02/21 03:48 AM
12/02/21 03:48 AM
Do you really want to be a Guinea pig and lead the way or would you rather go with a proven product like a set of Isky #8005 valve springs work
I don't want to be test bed unless the company providing me the parts is paying me to do testing for them.
I have had to try unproven race parts (R&D) in my motors when the parts I was using wouldn't live or do what I needed them to do up work
Re: Thoughts on Beehive Springs? [Re: BigDaddy440] #2991153
12/02/21 07:49 AM
12/02/21 07:49 AM
Canada
Max Weg Offline
Max Weg  Offline
Canada
Beehives work great!! I have used them in Stock Eliminator for over 10 years with only 1 failure which was more my fault. I as well have used them on multiple street builds with good success.
Max Weg
Re: Thoughts on Beehive Springs? [Re: BigDaddy440] #2991156
12/02/21 08:11 AM
12/02/21 08:11 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Depends on what you are gonna do with the car. Viper and late model Hemi's have beehive springs and I've seen the Viper powered truck and a cop Hemi street engine drop a valve cause they broke. On a race engine that gets checked, or the springs get replaced more often, I guess they can work.
Re: Thoughts on Beehive Springs? [Re: BigDaddy440] #2991168
12/02/21 09:18 AM
12/02/21 09:18 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
I've been running beehives on my 528 Hemi for about 15k miles now. Street use and occasional track visit. They control some pretty heavy valvetrain just fine. I've rev'd it to 7k on accident before. (solid flat tappet).
I'm a believer. I don't intend to run traditional springs ever again if I can help it.
Re: Thoughts on Beehive Springs? [Re: 73DAD] #2991184
12/02/21 10:01 AM
12/02/21 10:01 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Mild hydro roller, over 11k miles & so far so good.
Re: Thoughts on Beehive Springs? [Re: CSK] #2991194
12/02/21 10:52 AM
12/02/21 10:52 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
If the OEM is willing to use them, it's not a design you should be worried about.
Buy from a good spring manufacture, and don't look back.
Re: Thoughts on Beehive Springs? [Re: BigDaddy440] #2991197
12/02/21 11:00 AM
12/02/21 11:00 AM
AndyF Offline
AndyF  Offline
I've been running beehive springs for at least 20 years. The last few engines I used conical springs which are even better than beehives. The conical springs are a dual spring design.
https://www.motortrend.com/how-to/dyno-tested-dual-conical-valve-springs/
Re: Thoughts on Beehive Springs? [Re: BigDaddy440] #2991279
12/02/21 02:37 PM
12/02/21 02:37 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Beehive springs are great. My question is how much money will the upgrade cost and could the money be better spent elsewhere.
