Thoughts on Beehive Springs?
#2991133
12/02/21 02:46 AM
12/02/21 02:46 AM
Posts: 707 California
BigDaddy440
California
What are your thoughts and experiences with Beehive Springs?
GM has been using them in their LSX engines for decades with success, but some claim they're junk and they break "all the time" or wear out prematurely. Factory GM camshafts probably don't have super aggressive lobe profiles, but LS engines take a lot of abuse and the springs survive.
They're typically lighter than conventional springs, especially when considering the much smaller retainer than can be used. They also can usually allow for more lift in applications where retainer to valve seal contact is an issue. Lighter valve-train should require less seat pressure to control valve events and less spring pressure should help allow parts to last longer.
My concern with running a Beehive Spring is breakage and a potentially dropped valve which could totally wreck an entire engine. I'm specifically considering a set (non mopar engine) for a fairly small (.510 lift) hydraulic roller camshaft with an aggressive lobe profile. The aggressive lobe fuels my concern.
I noticed Steve Dulcich had some Beehives on a small block mopar recently. I was surprised because I haven't noticed a lot of guys running Beehives on Non-GM engines. Any thoughts or advice would be appreciated.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
Re: Thoughts on Beehive Springs?
[Re: BigDaddy440]
#2991138
12/02/21 03:48 AM
12/02/21 03:48 AM
Posts: 43,202 Bend,OR USA
Cab_Burge
Do you really want to be a Guinea pig and lead the way or would you rather go with a proven product like a set of Isky #8005 valve springs I don't want to be test bed unless the company providing me the parts is paying me to do testing for them. I have had to try unproven race parts (R&D) in my motors when the parts I was using wouldn't live or do what I needed them to do
[Re: 73DAD]
#2991184
12/02/21 10:01 AM
12/02/21 10:01 AM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
Mild hydro roller, over 11k miles & so far so good.
