Barton T&D vs Stage V rockers #2987953
11/22/21 06:51 PM
11/22/21 06:51 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Barton or Stage V rocker system, which are best suited for 572 gen 2 street/strip (800-850hp) Hemi and why? Barton T&D i could pushrod oil, Stage v not recommended. Suggested convensional oiling.
Re: Barton T&D vs Stage V rockers [Re: mopar dave] #2988030
11/22/21 09:37 PM
11/22/21 09:37 PM
Cab_Burge Online work
Cab_Burge  Online Work
What is the intended use?
Re: Barton T&D vs Stage V rockers [Re: Cab_Burge] #2988034
11/22/21 09:45 PM
11/22/21 09:45 PM
Superfreak
Superfreak
The Barton's have the advantage of not having to take the whole assembly apart when changing a spring, They both cost about the same and apparently they both work well for street or strip. I went with the Barton's.
Re: Barton T&D vs Stage V rockers [Re: ] #2988086
11/23/21 01:32 AM
11/23/21 01:32 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
It has been several years since I inquired about the weight, but when I did I learned that the base plate for the T&d / Barton system is very heavy. The stage v is lighter.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Barton T&D vs Stage V rockers [Re: Hemi_Joel] #2988095
11/23/21 02:27 AM
11/23/21 02:27 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Here we go again.
2011 Drag Pak Challenger
Re: Barton T&D vs Stage V rockers [Re: Cab_Burge] #2988123
11/23/21 08:56 AM
11/23/21 08:56 AM
Mt Morris Michigan
Mt Morris Michigan
Weekend driving only with an occasional T&T day. RPM under 7000. I currently have the Bartons, but i have to do quite a bit massaging to the plate to get it to fit. The Stage v is a direct bolt on and conventional rocker shaft oiling.
Re: Barton T&D vs Stage V rockers [Re: ] #2988196
11/23/21 12:16 PM
11/23/21 12:16 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I'm gonna be making a tool to change springs with the head ect. on the block.
Re: Barton T&D vs Stage V rockers [Re: mopar dave] #2988213
11/23/21 12:38 PM
11/23/21 12:38 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Is the plate aluminum or steel?
Re: Barton T&D vs Stage V rockers [Re: Dragula] #2988291
11/23/21 03:54 PM
11/23/21 03:54 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Mine are Steel
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Barton T&D vs Stage V rockers [Re: 68 HEMI GTS] #2988296
11/23/21 04:07 PM
11/23/21 04:07 PM
Dragula Offline
Dragula  Offline
Wow..I always thought that plate was aluminum...
Re: Barton T&D vs Stage V rockers [Re: Dragula] #2988302
11/23/21 04:20 PM
11/23/21 04:20 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I could be off, but I seem to remember those Bartons weighing 12# more than stage V. But I can't remeber if that was total or per side?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Barton T&D vs Stage V rockers [Re: mopar dave] #2988350
11/23/21 05:58 PM
11/23/21 05:58 PM
PA
RBRE Offline
RBRE  Offline
PA
All the systems come with aluminum base plates. There is an optional steel base plate if you have 1" lift or want to weld supports etc.. We have sold over 800 sets in 21 years with no real failures. Some people have 30,000 miles on them. I have recently seen a few heads that had the spark plug position slightly relocated. I had offered to CNC modify the base plates at no charge, but never heard any more about it. The system is designed to fit most heads with no modifications, but won't fit stock valve covers.
Re: Barton T&D vs Stage V rockers [Re: RBRE] #2988364
11/23/21 06:37 PM
11/23/21 06:37 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
On the motor in a friends car that I help with he has these rockers from RB with spray bars. The complete set up is great and easy to work on. This car is a race car and this set up is one of the first that likely Ray did. One other Hemi that we race with broke a rocker and it is not a fun job at the track taking every thing apart to change a spring. Try the grille, rad just for starters because you have to slide the shaft for the rockers out completely out. If you do not make the hemi work hard most rockers will work for ever. Not sure if RB sell the spray bars but I like that application on a race motor but you have to make sure thing are clean and nothing gets plugged. The set up in the picture takes less Maintenance for each rocker set.
1971 HEMI E BODY REGISTRY
Re: Barton T&D vs Stage V rockers [Re: Dragula] #2988380
11/23/21 07:04 PM
11/23/21 07:04 PM
Mt Morris Michigan
Mt Morris Michigan
My plates are steel and weight about 10# each. Yes Ray did offer to machine my plates because of the offset plug holes, but there is more to it than that. My head is a custom stage V head specifically for FHO, looks like a Millenium head on top, but is not. It has some kind of stiffening ribs on top that the plate sets on, preventing the rocker plate from setting down flat on the head. A lot of grinding and a big price reduction if i ever decide to resale used. Gonna put them on the shelf for later if i change my mine about the Stage v rockers. I didnt understand that Ray was offering this machining for free. How often is Hemi and free used in the same sentence? I appreciate the offer Ray, but there will be more machining than just the spark plug holes. I was under the understanding that the rockers get splash oiled and you dont get enough splash til your really spinning it, so idling in traffic might be a problem. This Ray Barton rocker set looks very robust with great geometry. Not sure how much performance will be lost with the Stage V set.
Re: Barton T&D vs Stage V rockers [Re: mopar dave] #2988666
11/24/21 03:02 PM
11/24/21 03:02 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have the RBRE rocker system on my street Hemi. I like everything about them.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Barton T&D vs Stage V rockers [Re: 6PKRTSE] #2988670
11/24/21 03:21 PM
11/24/21 03:21 PM
Mt Morris Michigan
Mt Morris Michigan
I think those rockers are simply badass, the best. Your spark plug holes look to line up perfectly from what i can see. They are not such a good match for my Custom Stage V's. I hate the idea of machining and clearancing that plate to get it to fit my heads. The price on these will continue to increase along with all other product, when i resale in a year or two i'll get my money back. Ray told me that spray bar really wasn't needed, only in mild street apps. Thanks for the pic.
Re: Barton T&D vs Stage V rockers [Re: RBRE] #2988774
11/24/21 08:02 PM
11/24/21 08:02 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Ordered a set from you in the spring and there was no question which system i was going to use.
