Page 3 of 3 1 2 3
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: gregsdart] #2987628
11/21/21 07:56 PM
11/21/21 07:56 PM
AndyF Offline
AndyF  Offline
Originally Posted by gregsdart
Originally Posted by fast68plymouth
Port injection?
So I guess it still has to have the fuel rails, etc installed.
Individual nozzles screw into each runner by the head.
Have you played around with different nozzle locations? There should be some power gain from evaporation but I don't know where the nozzle should be to optimize that.
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: gregsdart] #2987672
11/21/21 10:51 PM
11/21/21 10:51 PM
Port injection?
Is that after having the manifold machined for them?
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: Cab_Burge] #2987676
11/21/21 11:08 PM
11/21/21 11:08 PM
gregsdart Offline OP
Port injection?
I drilled and tapped them. As far as nozzle placement I have asked experts about it, as I recall no advantage to moving them. But, a call to Kinsler tomorrow since you mentioned it for another opinion.
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: gregsdart] #2987691
11/22/21 01:28 AM
11/22/21 01:28 AM
I've seen, years ago, roundy round dirt sprint cars with the Kinsler F.I. using them with the methanol injector nozzles mounted halfway up the tubes, not anywhere near the flanges. work
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: AndyF] #2987702
11/22/21 05:43 AM
11/22/21 05:43 AM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted by AndyF
Looks great. Should pick up some power for you. I've tested a lot of Wilson intakes and they are usually 20 to 30 hp better than as cast.
Definitely looks great. I don't know anything. So, itis good to hear experience fron testing.
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: 440Jim] #2987793
11/22/21 12:39 PM
11/22/21 12:39 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Looks good to me too but, like everyone else has said, the proof is in the pudding! I'm eager to see this run.
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: gregsdart] #2987812
11/22/21 01:43 PM
11/22/21 01:43 PM
NC
440Jim Offline
440Jim  Offline
NC
Talked to Wilson Manifolds yesterday and i am having a " mid level full port" done. That includes work on full length of the runners but no major cutting I assume.
So what was the cost? twocents
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: 440Jim] #2987817
11/22/21 01:57 PM
11/22/21 01:57 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
This was a quote for my 440-2 before we started to make an entirely new intake based on that casting:
"Our Competition Porting Service is $1675 and an EFI Conversion (install bungs, billet -8 or -10 fuel rails and stanchions) is $800. "
I will most likely send it out eventually as my low deck engine collection grows.
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: Jeremiah] #2987852
11/22/21 02:47 PM
11/22/21 02:47 PM
NC
440Jim Offline
440Jim  Offline
NC
OK,
I think Indy is selling the 3X intake for $700 now. Plus $1700 ... $2,400 cast intake manifold.
I did look at Wilson's web site and some of their sheet metal intakes are around $4,500
I guess the days of $150 used intakes from the swap meet are over...
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: 440Jim] #2987874
11/22/21 03:45 PM
11/22/21 03:45 PM
AndyF Offline
AndyF  Offline
OK,
I'll sell you a used intake for $150. It won't make as much power as a $1500 intake, but your engine will run.
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: AndyF] #2988580
11/24/21 09:32 AM
11/24/21 09:32 AM
Port injection?
After reading this I chose to leave the nozzles where they were. Puppy agreed.
Reading further about down nozzles in the heads that spray directly on the intake valve is interesting.
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: gregsdart] #2988606
11/24/21 10:50 AM
11/24/21 10:50 AM
Washington
madscientist Offline
Washington
Port injection?
That’s on stack injection and I’m not sure I even believe that. I ran two flying toilets on a tunnel ram and every time I moved the nozzles up I made more power everywhere. Maybe, maybe because stack injection limits airflow moving the nozzles up may be a power loss. Maybe. But on a manifold like yours moving the nozzles up to the base of the plenum will make more power. If you lose some idle quality, increase the idle check pressure. I ended up at 12 or 14 PSI on the idle check with the nozzles up high and it idled as good as it did with the lower nozzle position.
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: madscientist] #2989474
11/26/21 11:10 PM
11/26/21 11:10 PM
Mad, I will investigate further. Thanks all for input. The last piece of the puzzle showed up today, a Jesel belt drive. Now if I have the right length pushrods,,,,,, 🤔
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: gregsdart] #2993708
12/09/21 05:36 PM
12/09/21 05:36 PM
NC
440Jim Offline
440Jim  Offline
NC
Got the 3X intake back from Wilson. I wish I knew what I am looking at🧐
Greg,
Are the port exit openings (to the heads) this size? or closer to 1.375 x 2.65
From the Indy web site for intake gaskets:
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: 440Jim] #2993881
12/09/21 11:18 PM
12/09/21 11:18 PM
My ports match the 572 gaskets perfectly. They were done by Radar(nickname?) In Iowa in 2002.
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: gregsdart] #2993933
12/10/21 07:52 AM
12/10/21 07:52 AM
tboomer Online work
tboomer  Online Work
Roger Lechtenberg. Same guy that did my MW Victors and Indy intake. wave
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: gregsdart] #2993945
12/10/21 08:49 AM
12/10/21 08:49 AM
NC
440Jim Offline
440Jim  Offline
NC
Then your $$$$ intake will be perfect if you decide to change to 572-13 heads. up
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: Al_Alguire] #2994858
12/13/21 09:56 AM
12/13/21 09:56 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted by Al_Alguire
And here is a properly ported 3X.....Oh yeah NOT done in Florida stirthepot
I talked to Ken Lazzeri of INDY at PRI, on Thursday, and we discussed the 440-3X intake. They are redesigning it to look more like this. Said it will take a while before it's ready, but is in the works. He wasn't shy about telling me what needed to be done to mine.
69 GTX 68 Road Runner
Re: Indy 3X , 550 cubes, gains from p porting the intake? [Re: JERICOGTX] #2994860
12/13/21 10:05 AM
12/13/21 10:05 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Ken has consistently been very sharing with information every time I engaged him. Which is one reason I do business with Indy regardless of the previous owners.
Page 3 of 3 1 2 3
