durango blower motor resistor AGAIN
#2984998
11/13/21 11:56 PM
11/13/21 11:56 PM
Posts: 2,226 ILLINOIS
volaredon
ILLINOIS
I've had this 01 Durango for 8-9 years now. almost 300K miles on body. One of the biggest annoyances has been the blower motor resistor. I've replaced it 5 or so times since I have owned. I can tell the PO has replaced it before as well, the pigtail had already been chopped and replaced. Since I have had it I've also changed the pigtail at least 2x. I have also replaced the blower motor thinking it was wore out, drawing too much current. this most recent one went 2 winters, longest of any I have put in. sometimes I don't even get 1 season from them. Is there any other resistor I can wire in, (yeah I'm OK with re replacing pigtail to match) that would be more heavy duty than the OE setup? I'm beyond tired of this issue. I think the problem lies in the small contacts at the pigtail/resistor interface being too small (not enough surface area) for the current involved. Again yesterday I was coming back to work from lunch and my wife calls.... (I work about 35 miles away from where she works) blower worked fine on way to work, she shut it off and went into work, comes out for lunch and..... nothing. so last nite I replaced the resistor AGAIN. I drove that thing all over the day before, (luckily) it was fine then. good thing because I had to take mother in law to Dr appointment. Id have not heard the end of it, if it had gone out then..... and one terminal in the last failed resistor, and matching terminal were burnt within the connector. and since replacing resistor I smell hot wiring again, usually do for a couple days after replacing it......
Re: durango blower motor resistor AGAIN
[Re: gtx6970]
#2985381
11/15/21 12:19 PM
11/15/21 12:19 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Common problem with late model Chrysler's it seems. IMO mini-vans were the worst.
Only thing I can tell you is when I do them For ANY blower inop issue I install a NEW quality built blower motor and resistor same time and every time. I'll use either Four Seasons or Mopar parts only.
I've yet to have a comeback I agree. And I would add to find one with the plug made onto it not a splice it together yourself deal. If you absolutly can not find a plug and play then properly solder and heat shrink the plug onto it for the best chance of survival. Check for any burned terminals in the connector or even a little evidence of melting and replace the connector on the harness again soldering and heat shrinking it. If you have never soldered then watch some videos of people doing it properly.
[Re: 4406bbl]
#2985518
11/15/21 06:40 PM
11/15/21 06:40 PM
volaredon
ILLINOIS
The vans with auto temp control are a real pain in the ass, when they switch to low blower the air flow is not enough to keep the transistor or mosfet cool, and it fails. It has a hugh heat sink but needs more, was also told too good of a cabin filter leads to lower flow on low, killing the atc style resistor. I have had better luck with the Chinese resistor, but am sure that will change. In the winter remove the cabin filter. this vehicle has no cabin filter. and though I have heard this term when talking car radios but what does "mosfet" mean?
[Re: volaredon]
#2985598
11/15/21 09:54 PM
11/15/21 09:54 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Google power mosfet, what I see in the electronic blower resistors is one semiconductor controlling a 25-30 amp load, seems like a marginal design. The quick answer is the transistor is the on off switch, switching thousands of times an hour. I need to look into weather or not the atc blower motor and non atc blower draw the same amps, less would be better.
[Re: B1MAXX]
#2994301
12/11/21 11:36 AM
12/11/21 11:36 AM
volaredon
ILLINOIS
I had the same problem. Finally replaced the pigtail and connector, been good at least 10 years now. have "only" owned 8 years not 10+ like you (yet, it's coming haha)) and it had been done (replaced) at least once before I bought it, and spliced poorly by (or for) PO. This vehicle came from the South, where AC would have gotten alot more use than heat, opposite now (I am near Chicago) I've replaced pigtail 2x myself since (why are they so damn expensive?) once aftermarket and one genuine Mopar. and at least 4 or 5 resistors. and 1 new blower motor in that time thinking a new one would draw less current. On the choice in terminals... I see in the pic with the Amazon link a notice in the package stating a warning about not using the gold plated terminals unless the originals also were... I doubt that would have been the case in 2001 when this thing was brand new. but I'm gonna have to replace the connector AGAIN. One terminal was obviously burnt within the existing plug. but I didn't have one nor the time to replace the last time it croaked. but why wouldn't you want to automatically use the gold plated ones, as to me, the issue is too little surface area for the current in the line to pass similar to a circuit with too light of gauge size of wire. I would think the gold plating would provide the best conductivity, least resistance possible. I do know that alot of cars have the airbag circuit connectors gold plated, as well. and they come with the connector kit in this case, anyways.
[Re: volaredon]
#2994356
12/11/21 03:09 PM
12/11/21 03:09 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
How well can you feel the air blow out the duck on low speed? On high speed? Check another vehicle with same test. If you’re not getting air speed check all doors, vents and outside vent for obstructions. Take resister out and hook to 12 volts, watch it glow hot then blow over it with the air hose, it cools down and stops glowing.
[Re: cudaman1969]
#2994716
12/12/21 08:06 PM
12/12/21 08:06 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
I'm probably out of line here, but I think I would look into moving the the resister to a different location where there may be more, or cooler air flow. If you need to change the pigtail, I would also check into using the old style blower motor resistor in that different location.
The purpose of the blower resistor is to reduce the voltage to the blower motor, and the reason for putting it in the heater box duct work is to help cool it. Nothing says the resister needs to be placed in the heater unit or the heater duct work, just that the blower motor wiring and the switch wiring needs to be connected to it to function. You can leave the dead resister mounted in its original position to plug the hole in the heater box/duct work, just don't connect the wire plug to it, connect the wire plug to the other unit in its new location.
I build hot rods, the blower motor resister on my 49 truck is between the fender and the inner fender where it is kept dry, out of harms way, out of the way where things flammable can't reach it, and has enough air moving past it to keep it cool. The heater box and duct wort are a least 12" away from the resister. Gene
