Page 1 of 4 1 2 3 4
Why is my Buddy's Olds Street Car so Fast? #2983877
11/10/21 05:42 PM
11/10/21 05:42 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
No roll cage (although it is on the agenda). Street car that he drives on a regular basis. 67 Olds Cutlass that his parents bought new. He had an aftermarket big block Olds built. Made 840 hp on the dyno.
I figured it would run high nines given that its a street car without a race suspension and should be relatively heavy.
9.12 @ 149 mph+! I find that crazy!
Re: Why is my Buddy's Olds Street Car so Fast? [Re: markz528] #2983883
11/10/21 06:03 PM
11/10/21 06:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
shock
Re: Why is my Buddy's Olds Street Car so Fast? [Re: markz528] #2983897
11/10/21 06:41 PM
11/10/21 06:41 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
My first assumption would be spraying a couple hundred. S/F...Ken M
Re: Why is my Buddy's Olds Street Car so Fast? [Re: EchoSixMike] #2983909
11/10/21 07:13 PM
11/10/21 07:13 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
It might be lighter than you think- I got burned on a bet with my buddy on his 66/67 Buick Skylark. Big car, all stock, hubcaps to ashtray and that d*mn thing weighed like 3200-3300 pounds. They do have factory 4 link rears and full frames so with aftermarket uppers and lowers, it might hook pretty well. Still a very impressive number from your buddy for sure.
Re: Why is my Buddy's Olds Street Car so Fast? [Re: BigBlockGTS] #2983912
11/10/21 07:17 PM
11/10/21 07:17 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Whaddya think of your Grandpa's Oldsmobile now??? Lol
Kevin
Re: Why is my Buddy's Olds Street Car so Fast? [Re: BigBlockGTS] #2983914
11/10/21 07:22 PM
11/10/21 07:22 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Factory rated it at 3200 lb
Re: Why is my Buddy's Olds Street Car so Fast? [Re: markz528] #2983921
11/10/21 07:52 PM
11/10/21 07:52 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
He obviously works very hard at it.
America First!
Re: Why is my Buddy's Olds Street Car so Fast? [Re: carnut68] #2983953
11/10/21 08:58 PM
11/10/21 08:58 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
He’s messing with you dude, sneaky nitros kit under the intake
Re: Why is my Buddy's Olds Street Car so Fast? [Re: markz528] #2983960
11/10/21 09:22 PM
11/10/21 09:22 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
68 Charger is factory rated 3300 lbs, mine is 3900 + me
Re: Why is my Buddy's Olds Street Car so Fast? [Re: markz528] #2983988
11/10/21 11:21 PM
11/10/21 11:21 PM
NY
B1duster Offline
B1duster  Offline
NY
That olds is making some steam, how many cubes is it ?
Re: Why is my Buddy's Olds Street Car so Fast? [Re: B1duster] #2983989
11/10/21 11:27 PM
11/10/21 11:27 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
I don't fully remember exactly, but somewhere near mid 500.
Re: Why is my Buddy's Olds Street Car so Fast? [Re: markz528] #2984013
11/11/21 03:20 AM
11/11/21 03:20 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Get that pig to 60 and you got an 8 sec player!
Re: Why is my Buddy's Olds Street Car so Fast? [Re: markz528] #2984020
11/11/21 07:34 AM
11/11/21 07:34 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Any ideal what the Old's aftermarket blocks are?
Re: Why is my Buddy's Olds Street Car so Fast? [Re: racerx] #2984027
11/11/21 08:08 AM
11/11/21 08:08 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
840 hp @3200 lbs. Thats what it should run. My geuss is its lighter than you think. Perfect example of accurate dyno #s matching track performance. Dyno's are a measuring device and need to be calibrated often to stay accurate. They are also easily fooled by entering in inaccurate data points. Temp, water grains, barometric pressure all change results. So you guys who have "840 Dyno tested HP" and the car doesn't perform near that good, what does that tell you?
Re: Why is my Buddy's Olds Street Car so Fast? [Re: fbs63] #2984029
11/11/21 08:24 AM
11/11/21 08:24 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
friend up the street from me has a '72 (?) cutlass. he had a 496 in it and did some 11:20"s (he may have snuck a couple teens in there) at 123mph, thru the mufflers and pump gas. it has edelbrock heads with serious work, torker intake , AED carb, hydraulic roller, 3.73 rear, turbo 400. it's set up for a bottle but don't think he has any times with n2o. full interior; bet it's at least 3700lbs. think it dynoed 575+hp. currently has a 540 in it, dynoed 670hp. no good times yet with the 540. i would think some kind of power adder would be needed to get into the nines with full street trim. it does take some money to get big performance from these cars, but they can be impressive. i don't think it makes any difference which brand they are you can make those old in-line valve dinosaurs run'
Re: Why is my Buddy's Olds Street Car so Fast? [Re: racerx] #2984030
11/11/21 08:27 AM
11/11/21 08:27 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
Rocket blocks. good 4 bolt blocks with bigger bores. 4 or 5 grand to buy one. i think big cranks are an issue. my friend had to get a callies billet made; $3500.
Re: Why is my Buddy's Olds Street Car so Fast? [Re: lewtot184] #2984094
11/11/21 12:40 PM
11/11/21 12:40 PM
UK
rb446 Offline
rb446  Offline
UK
You sure can, we were lucky enough to buy (just when we started looking) a mild big cube 589ci 10:1CR pump gas wedge motor all fresh and dyno'd for £10k around $13k, went into a 3800lb '69RR which was raced in full street spec inc bench seat full exhausts air cleaner etc. etc., a small older 950DP and driven to track/raced/driven home, its gone a best of 10.35@130 with 1.42 60's on a good day, there's a low 10 in it with one of Doms Thumper carbs, no muffs and a re tune I reckon, it only makes a poultry 680fwhp@6200rpm on track the way its raced, not too bad for a dinosaur.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Why is my Buddy's Olds Street Car so Fast? [Re: lewtot184] #2984118
11/11/21 01:29 PM
11/11/21 01:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
And don't forget the Olds DRCE block used in current Pro Stockers.
Re: Why is my Buddy's Olds Street Car so Fast? [Re: markz528] #2984121
11/11/21 01:46 PM
11/11/21 01:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Seems pretty close if the car does indeed weigh 3200 but as stated id better its a bit lighter. Or he is very good at squeexing everything out of that combo, but with that 60' I would say its lighter than 3200.
Re: Why is my Buddy's Olds Street Car so Fast? [Re: Al_Alguire] #2984210
11/11/21 05:43 PM
11/11/21 05:43 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
The incremental from 60-330 is pretty good. 840 corrected HP isn't going to get it done unless its pretty light.
Doug
Page 1 of 4 1 2 3 4
