Why is my Buddy's Olds Street Car so Fast?
#2983877
11/10/21 05:42 PM
11/10/21 05:42 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
No roll cage (although it is on the agenda). Street car that he drives on a regular basis. 67 Olds Cutlass that his parents bought new. He had an aftermarket big block Olds built. Made 840 hp on the dyno.
I figured it would run high nines given that its a street car without a race suspension and should be relatively heavy.
9.12 @ 149 mph+! I find that crazy!
Re: Why is my Buddy's Olds Street Car so Fast?
[Re: BigBlockGTS]
#2983914
11/10/21 07:22 PM
11/10/21 07:22 PM
markz528
Morrow, OH
It might be lighter than you think- I got burned on a bet with my buddy on his 66/67 Buick Skylark. Big car, all stock, hubcaps to ashtray and that d*mn thing weighed like 3200-3300 pounds. They do have factory 4 link rears and full frames so with aftermarket uppers and lowers, it might hook pretty well. Still a very impressive number from your buddy for sure. Factory rated it at 3200 lb
[Re: markz528]
#2983921
11/10/21 07:52 PM
11/10/21 07:52 PM
Posts: 3,180 Md.
carnut68
Md.
He obviously works very hard at it.
America First!
[Re: markz528]
#2983960
11/10/21 09:22 PM
11/10/21 09:22 PM
Posts: 2,860 Pattison Texas
CSK
Pattison Texas
It might be lighter than you think- I got burned on a bet with my buddy on his 66/67 Buick Skylark. Big car, all stock, hubcaps to ashtray and that d*mn thing weighed like 3200-3300 pounds. They do have factory 4 link rears and full frames so with aftermarket uppers and lowers, it might hook pretty well. Still a very impressive number from your buddy for sure. Factory rated it at 3200 lb 68 Charger is factory rated 3300 lbs, mine is 3900 + me
[Re: B1duster]
#2983989
11/10/21 11:27 PM
11/10/21 11:27 PM
markz528
Morrow, OH
That olds is making some steam, how many cubes is it ? I don't fully remember exactly, but somewhere near mid 500.
[Re: markz528]
#2984020
11/11/21 07:34 AM
11/11/21 07:34 AM
Posts: 4,070 Mo.
racerx
Mo.
That olds is making some steam, how many cubes is it ? I don't fully remember exactly, but somewhere near mid 500. Any ideal what the Old's aftermarket blocks are?
[Re: fbs63]
#2984029
11/11/21 08:24 AM
11/11/21 08:24 AM
Posts: 3,916 usa
lewtot184
usa
friend up the street from me has a '72 (?) cutlass. he had a 496 in it and did some 11:20"s (he may have snuck a couple teens in there) at 123mph, thru the mufflers and pump gas. it has edelbrock heads with serious work, torker intake , AED carb, hydraulic roller, 3.73 rear, turbo 400. it's set up for a bottle but don't think he has any times with n2o. full interior; bet it's at least 3700lbs. think it dynoed 575+hp. currently has a 540 in it, dynoed 670hp. no good times yet with the 540. i would think some kind of power adder would be needed to get into the nines with full street trim. it does take some money to get big performance from these cars, but they can be impressive. i don't think it makes any difference which brand they are you can make those old in-line valve dinosaurs run'
[Re: racerx]
#2984030
11/11/21 08:27 AM
11/11/21 08:27 AM
Posts: 3,916 usa
lewtot184
usa
That olds is making some steam, how many cubes is it ? I don't fully remember exactly, but somewhere near mid 500. Any ideal what the Old's aftermarket blocks are? Rocket blocks. good 4 bolt blocks with bigger bores. 4 or 5 grand to buy one. i think big cranks are an issue. my friend had to get a callies billet made; $3500.
[Re: lewtot184]
#2984094
11/11/21 12:40 PM
11/11/21 12:40 PM
Posts: 570 UK
rb446
UK
friend up the street from me has a '72 (?) cutlass. he had a 496 in it and did some 11:20"s (he may have snuck a couple teens in there) at 123mph, thru the mufflers and pump gas. it has edelbrock heads with serious work, torker intake , AED carb, hydraulic roller, 3.73 rear, turbo 400. it's set up for a bottle but don't think he has any times with n2o. full interior; bet it's at least 3700lbs. think it dynoed 575+hp. currently has a 540 in it, dynoed 670hp. no good times yet with the 540. i would think some kind of power adder would be needed to get into the nines with full street trim. it does take some money to get big performance from these cars, but they can be impressive. i don't think it makes any difference which brand they are you can make those old in-line valve dinosaurs run' You sure can, we were lucky enough to buy (just when we started looking) a mild big cube 589ci 10:1CR pump gas wedge motor all fresh and dyno'd for £10k around $13k, went into a 3800lb '69RR which was raced in full street spec inc bench seat full exhausts air cleaner etc. etc., a small older 950DP and driven to track/raced/driven home, its gone a best of 10.35@130 with 1.42 60's on a good day, there's a low 10 in it with one of Doms Thumper carbs, no muffs and a re tune I reckon, it only makes a poultry 680fwhp@6200rpm on track the way its raced, not too bad for a dinosaur.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: lewtot184]
#2984118
11/11/21 01:29 PM
11/11/21 01:29 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
That olds is making some steam, how many cubes is it ? I don't fully remember exactly, but somewhere near mid 500. Any ideal what the Old's aftermarket blocks are? Rocket blocks. good 4 bolt blocks with bigger bores. 4 or 5 grand to buy one. i think big cranks are an issue. my friend had to get a callies billet made; $3500. And don't forget the Olds DRCE block used in current Pro Stockers.
[Re: markz528]
#2984121
11/11/21 01:46 PM
11/11/21 01:46 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Seems pretty close if the car does indeed weigh 3200 but as stated id better its a bit lighter. Or he is very good at squeexing everything out of that combo, but with that 60' I would say its lighter than 3200.
