604 ci Hemi can you run a dip stick? #2976414
10/20/21 09:36 AM
10/20/21 09:36 AM
cheshire, ct
davesmopars Offline OP
cheshire, ct
604 ci Hemi can you run a stock dip stick?
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: 604 ci Hemi can you run a dip stick? [Re: davesmopars] #2976477
10/20/21 12:58 PM
10/20/21 12:58 PM
Cab_Burge Online work
Cab_Burge  Online Work
if you are using a after market (usually aluminum race pans) oil pan that the gasket flange blocks the dipstick hole you can fix it by grinding or cutting that part out and use a stock type Mopar or after market dipstick scope wrench up
I've had to do that on more than one race pan shruggy
Re: 604 ci Hemi can you run a dip stick? [Re: Cab_Burge] #2976615
10/20/21 08:59 PM
10/20/21 08:59 PM
cheshire, ct
cheshire, ct
Thanks I will look at my pan
mcodecuda@yahoo.com
Re: 604 ci Hemi can you run a dip stick? [Re: davesmopars] #2976632
10/20/21 09:27 PM
10/20/21 09:27 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
If you can’t notch the pan rail a sight glass would be a good option.
Re: 604 ci Hemi can you run a dip stick? [Re: rickraw] #2976653
10/20/21 10:09 PM
10/20/21 10:09 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
On my aluminum oil pan the factory dipstick hit the pan above the oil level. I added a dipstick to the kickout of the pan itself.
Doug
Re: 604 ci Hemi can you run a dip stick? [Re: dvw] #2976682
10/20/21 11:45 PM
10/20/21 11:45 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Look at how the factory did the BB truck pans. You can buy a simple and easy kit although you will need to calibrate it so it will read right with your pan.
Todd
