Originally Posted by davesmopars
604 ci Hemi can you run a stock dip stick?
if you are using a after market (usually aluminum race pans) oil pan that the gasket flange blocks the dipstick hole you can fix it by grinding or cutting that part out and use a stock type Mopar or after market dipstick scope wrench up
I've had to do that on more than one race pan shruggy
