604 ci Hemi can you run a dip stick?
#2976414
10/20/21 09:36 AM
10/20/21 09:36 AM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
604 ci Hemi can you run a stock dip stick?
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
Re: 604 ci Hemi can you run a dip stick?
[Re: Cab_Burge]
#2976615
10/20/21 08:59 PM
10/20/21 08:59 PM
davesmopars
cheshire, ct
if you are using a after market (usually aluminum race pans) oil pan that the gasket flange blocks the dipstick hole you can fix it by grinding or cutting that part out and use a stock type Mopar or after market dipstick I've had to do that on more than one race pan Thanks I will look at my pan
