front spring eye bushing inner sleeve length #2970598
10/04/21 10:24 PM
10/04/21 10:24 PM
Iowa
burdar Online work OP
Owen's Dad
burdar  Online Work OP
Owen's Dad
Iowa
I've got a set of the 0 arch MP oval track springs. The inner bushing sleeve sticks out past the rubber on both sides slightly. When the spring eye bolt is tightened, the inner sleeve is locked in place but the rubber isn't compressed at all. This isn't how the stock springs/bushings were. With the stock springs, the inner sleeve must be a little shorter then the rubber because when you tighten the bolt down, the rubber toughes the sides of the hanger and gets compressed.
Is this an issue? Should I machine down the inner sleeves so they are at least the same width as the rubber or slightly shorter?
Edit: Inner bushing sleeve length 3.110"
Out to out of rubber bushing 3.035"
Re: front spring eye bushing inner sleeve length [Re: burdar] #2970850
10/05/21 11:36 AM
10/05/21 11:36 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
Rubber is not compressed. The bushing should have an outer shell and inner sleeve which are impregnated together when it is made. The bushing outer shell is pressed into the spring eye. The bolt then squeezes both sides of the mounting bracket against the inner sleeve.
Re: front spring eye bushing inner sleeve length [Re: NITROUSN] #2970854
10/05/21 11:50 AM
10/05/21 11:50 AM
Iowa
Owen's Dad
Owen's Dad
Iowa
The rubber sticks out past the outer sleeve but the inner sleeve sticks out farther than the rubber. On the stock springs the bushing rubber touches the sides of the hanger and is slightly compressed when the bolt is tightened. On this new set of springs, when the bolt is tightened, the rubber won't even touch the sides of the hanger. Just want to make sure this is OK since it's different then the stock setup.
Re: front spring eye bushing inner sleeve length [Re: burdar] #2970922
10/05/21 01:15 PM
10/05/21 01:15 PM
N
N
Post pictures.
Re: front spring eye bushing inner sleeve length [Re: NITROUSN] #2971112
10/05/21 07:45 PM
10/05/21 07:45 PM
Iowa
Owen's Dad
Owen's Dad
Iowa
You can see that the inner sleeve on the new bushing is longer then the rubber. When you tighten the bolt, you are left with a gap between the hanger and the bushing rubber. The inner sleeve is held tight though. On the original bushing, the rubber touches the hanger and is compressed when the bolt is tightened. I'm not sure that this is an issue. Just wanted to hear from others.
Re: front spring eye bushing inner sleeve length [Re: burdar] #2971151
10/05/21 09:31 PM
10/05/21 09:31 PM
N
N
Even on the original there was a sleeve . The rubber touching the sides of the brackets is irrelevant and had no function. As long as the bushing it tight in the eye and the inner bushing is squeezed tight within the mount you are fine.
Re: front spring eye bushing inner sleeve length [Re: burdar] #2971346
10/06/21 02:26 PM
10/06/21 02:26 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
The bushing is only for the leaf spring twisting action. The sleeve can touch the hangers... no problems or concerns.
Re: front spring eye bushing inner sleeve length [Re: Mopar Mitch] #2971572
10/06/21 10:33 PM
10/06/21 10:33 PM
Iowa
Owen's Dad
Owen's Dad
Iowa
OK, with that out of the way, next question.
I'm using Dr Diff offset hangers and shackles on this Dart. The bolt head for the front spring eye is tapered and accepts an allen wrench to hold it while the nut is being tightened. The bolt head ends up right next to the frame rail so the only way to tighten up the bolt is with the springs OFF the car.(no way to get an allen wrench on it with the front hanger installed on the car) On my Challenger, I waited until the weight of the car was on the springs before tightening the front spring eye and shackles. I hope it's not that critical for the front spring eye that the car be on the suspension before tightening.
Re: front spring eye bushing inner sleeve length [Re: burdar] #2972011
10/08/21 11:39 AM
10/08/21 11:39 AM
moparx Offline
moparx  Offline
a small hole drilled through both rail sides will allow the allen key to pass through. cut the short leg off using a wizz wheel or chop saw. a regular hack saw won't get it, as those keys are hard material unless they are made of chinesium. then use a standard socket the size of the key to tighten the bolt at ride height.
beer
Re: front spring eye bushing inner sleeve length [Re: moparx] #2972028
10/08/21 12:22 PM
10/08/21 12:22 PM
Iowa
Owen's Dad
Owen's Dad
Iowa
Thanks. I thought about that. The only issue with that is the front hanger has two spring eye bolt mounting positions.(upper and lower hole) I'm not sure which hole will give me the stance I want yet. It would take two holes all the way through the frame in order to get the wrench on both positions.
Re: front spring eye bushing inner sleeve length [Re: burdar] #2972073
10/08/21 02:22 PM
10/08/21 02:22 PM
North Seattle, Washington. USA
U code RR Offline
U code RR  Offline
Don't tighten the bolt until you check your ride height and made your final choice.
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
Re: front spring eye bushing inner sleeve length [Re: NITROUSN] #2972169
10/08/21 06:53 PM
10/08/21 06:53 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
IMO regarding your last two comments, you are making two contradictory statements, the last one being mostly the correct one, just to be clear for others.
All to mean, the leaf should not contact the mounting bracket, tightly squeezed rubber bushing prevents that contact in all but the most brutal impacts.
Re: front spring eye bushing inner sleeve length [Re: jcc] #2974151
10/13/21 10:17 PM
10/13/21 10:17 PM
N
N
No I am not. Look at his pictures. He has a new style bushing that does not have the excess side rubber like the factory one. He was worried about not having the excess side rubber thinking it was a problem. Please do not start your BS with me.
Re: front spring eye bushing inner sleeve length [Re: NITROUSN] #2974781
10/15/21 09:38 PM
10/15/21 09:38 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I have always been under the impression that a conventional sleeved rubber bushing (steel inner sleeve/outer sleeve) the sleeves were held stationary and undistorted with the car at ride height. When the suspension moves, the rubber distorts to allow movement but the two sleeves are stationary. At east that is the impression I have always been under. shruggy
Re: front spring eye bushing inner sleeve length [Re: NITROUSN] #2974788
10/15/21 09:45 PM
10/15/21 09:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Speaking of BS, you never explained why his "thinking it was a problem" is not a problem. I wonder why? laugh2
Re: front spring eye bushing inner sleeve length [Re: jcc] #2974808
10/15/21 10:40 PM
10/15/21 10:40 PM
Iowa
Owen's Dad
Owen's Dad
Iowa
My thougth was that since there is a 1/16" gap between the rubber and the hanger on each side... That if cornering hard, the rubber could flex and the spring eye could move from side to side. If the rubber was touching the sides, there could still be side to side movement in the spring eye but it would be greatly reduced. It sound like this movement isn't enough to worry about. I had thought about adding a thin stainless washer on each side of the spring eye to take up the gap. The center hole in the washers would be large enough that the center sleeve would pass through them and still clamp tight to the hanger. Probably just over thinking it.
Re: front spring eye bushing inner sleeve length [Re: burdar] #2974810
10/15/21 10:44 PM
10/15/21 10:44 PM
Iowa
Owen's Dad
Owen's Dad
Iowa
Quote
That was my thought as well. That's why I wondered about how to tighten the front spring eye bolts when they can't be accessed with the springs mounted. Worst case scenario is I install the springs with the eye bolt loose. Once ride height it established, mark the location of the spring and front hanger so I have a reference point to hold them at while I tighten the bolt off the car.
Re: front spring eye bushing inner sleeve length [Re: burdar] #2974916
10/16/21 11:11 AM
10/16/21 11:11 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
IMO, nope.
