70 CHALLENGER ANTENNA BEZEL ISSUE #2970903
10/05/21 12:46 PM
10/05/21 12:46 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
i have 1 nos bezel [complete assy nos also that came with it. ] and one repro bezel... both make the antenna mast lean outwards from the body.. is this normal?..or is there a different bezel that will make the mast sit straight up? thanks guys
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: ph23vo] #2971205
10/06/21 12:16 AM
10/06/21 12:16 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Just rotate the bezel 90 degrees
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: PhillyRag] #2971244
10/06/21 08:36 AM
10/06/21 08:36 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Just like PhillyRag said. You can see the the bezel has a slight height variation and it has to be correctly oriented on the fender to make the antenna point straight.
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: EW1BH27] #2971288
10/06/21 11:28 AM
10/06/21 11:28 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
Seems i tried to put it in opposite and it would not fit in the fender...and since the bezel has a cut out inside it at an angle, if i did flip it , it looks like it would bend mast inward too far....will look again tomorrow thanks guys..
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: ph23vo] #2971290
10/06/21 11:41 AM
10/06/21 11:41 AM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
I have a new reproduction that doesn't fit the contour of the fender. I had to have the original one re-chromed.
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: burdar] #2971308
10/06/21 12:22 PM
10/06/21 12:22 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
MINE IS AN NOS ORIGINAL...but i am not sure its for a 70 non t/a challenger...i cannot find a single picture online of a 70 challenger pass fender with an original antenna..all seem to have the cheap aftermarket ones..
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: burdar] #2971313
10/06/21 12:48 PM
10/06/21 12:48 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
flipped it 90 degrees and the antenna is way too far leaning inwards now..i tried 3 other [unidentified] nos bezels i have ,...and one repro supposedly for a challenger , and all are making mast lean one way or the other a ton!..
sadly i took car apart 35 yrs ago and do not know where original is...i prob tossed it because i had bought this nos one... does anyone have a pic of a known correct original non t/a 70 challenger bezel?...
the repro guys show all different kinds and styles so i have no way to know whats right... thanks
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: ph23vo] #2971344
10/06/21 02:22 PM
10/06/21 02:22 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
the one on far right...is this correct for a 70-71 challenger?
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: ph23vo] #2971357
10/06/21 02:38 PM
10/06/21 02:38 PM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
It should be correct for 70-74 Challenger.
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: burdar] #2971404
10/06/21 04:04 PM
10/06/21 04:04 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
OK THANKS ,..THATS MY ISSUE..NONE OF MINE LOOK LIKE THAT..SO I MUST HAVE A B & C BODY BEZELS.. THANKS
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: ph23vo] #2971582
10/06/21 11:41 PM
10/06/21 11:41 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
They have a part number on them. What number is on your NOS one?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: moparmarks] #2971585
10/06/21 11:47 PM
10/06/21 11:47 PM
moparmarks Offline
moparmarks  Offline
Think the Challenger is a 2983164
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: moparmarks] #2971833
10/07/21 07:40 PM
10/07/21 07:40 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
sadly cant read it at all.. but by picture its a 68-70 b body and 70 t/a challenger...i bought the antenna nos in the mid 80's at the dealer...obv the correct one eitehr wasnt avail or it was superceeded to the t/a one..as close enuf..
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: ph23vo] #2971878
10/07/21 09:18 PM
10/07/21 09:18 PM
moparmarks Offline
moparmarks  Offline
Here is a 70 Challenger. I don't know why but the book shows a different part number for 70 versa 71-4.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: ph23vo] #2972439
10/09/21 04:28 PM
10/09/21 04:28 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I know 2 of the 5 are bezels shown are for the inside door panel for the remote control of the Drivers side mirror...
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: moparmarks] #2972764
10/10/21 05:30 PM
10/10/21 05:30 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
YES THATS THE ONE! THANKSq@
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: QuickBpBp] #2972765
10/10/21 05:31 PM
10/10/21 05:31 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
yes i knew that..it was the only pic i could find
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE [Re: burdar] #2974393
10/14/21 06:14 PM
10/14/21 06:14 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
I ENDED UP BUYING A REPRO FROM VANS AUTO OFF FLEABAY...AND LUCKILY IT FITS PERFECTLY AND THE ANTENNA IS STRAIGHT... FINALLY
