70 CHALLENGER ANTENNA BEZEL ISSUE
#2970903
10/05/21 12:46 PM
10/05/21 12:46 PM
Posts: 14,470 renton, Washington
ph23vo
renton, Washington
i have 1 nos bezel [complete assy nos also that came with it. ] and one repro bezel... both make the antenna mast lean outwards from the body.. is this normal?..or is there a different bezel that will make the mast sit straight up? thanks guys
Re: 70 CHALLENGER ANTENNA BEZEL ISSUE
[Re: EW1BH27]
#2971288
10/06/21 11:28 AM
10/06/21 11:28 AM
ph23vo
renton, Washington
Seems i tried to put it in opposite and it would not fit in the fender...and since the bezel has a cut out inside it at an angle, if i did flip it , it looks like it would bend mast inward too far....will look again tomorrow thanks guys..
[Re: moparmarks]
#2971833
10/07/21 07:40 PM
10/07/21 07:40 PM
ph23vo
renton, Washington
They have a part number on them. What number is on your NOS one? sadly cant read it at all.. but by picture its a 68-70 b body and 70 t/a challenger...i bought the antenna nos in the mid 80's at the dealer...obv the correct one eitehr wasnt avail or it was superceeded to the t/a one..as close enuf..
[Re: ph23vo]
#2972439
10/09/21 04:28 PM
10/09/21 04:28 PM
Posts: 6,342 SE PA.
QuickBpBp
SE PA.
the one on far right...is this correct for a 70-71 challenger? I know 2 of the 5 are bezels shown are for the inside door panel for the remote control of the Drivers side mirror...
[Re: moparmarks]
#2972764
10/10/21 05:30 PM
10/10/21 05:30 PM
ph23vo
renton, Washington
Here is a 70 Challenger. I don't know why but the book shows a different part number for 70 versa 71-4. YES THATS THE ONE! THANKSq@
[Re: QuickBpBp]
#2972765
10/10/21 05:31 PM
10/10/21 05:31 PM
ph23vo
renton, Washington
the one on far right...is this correct for a 70-71 challenger? I know 2 of the 5 are bezels shown are for the inside door panel for the remote control of the Drivers side mirror... yes i knew that..it was the only pic i could find
[Re: burdar]
#2974393
10/14/21 06:14 PM
10/14/21 06:14 PM
ph23vo
renton, Washington
I have a new reproduction that doesn't fit the contour of the fender. I had to have the original one re-chromed. I ENDED UP BUYING A REPRO FROM VANS AUTO OFF FLEABAY...AND LUCKILY IT FITS PERFECTLY AND THE ANTENNA IS STRAIGHT... FINALLY
