Page 2 of 3 1 2 3
Re: Air shocks\wide tires [Re: exile5700] #2960774
09/03/21 08:16 PM
09/03/21 08:16 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
You might consider some Super Stock springs.
Re: Air shocks\wide tires [Re: forphorty] #2960839
09/04/21 12:26 AM
09/04/21 12:26 AM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
You could have a shop that rebuilds springs re-arc and add a leaf of two the springs you have.
Re: Air shocks\wide tires [Re: 57Fury440] #2960865
09/04/21 06:40 AM
09/04/21 06:40 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Someone mentioned longer rear hangers which would help reduce the need for high shock pressures but if I remember correctly they won't work on an e-body because of the hangers hitting the rear valence.
I remember back in the day you would see cars with them and the rear valence cut for clearance. I don't think you want that "vintage" look. Super stock springs are not a good idea for a street vehicle. My first Challenger had air shocks and the upper shock support was cracked everywhere. Re arch the springs would be my choice.
Re: Air shocks\wide tires [Re: Moparite] #2960886
09/04/21 09:30 AM
09/04/21 09:30 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I remember with my Challengers using a 15x10 wheel with a 4.5" backspace. N50X15s of various branding- Kelley Supercharger- Pro Trac. I had air shocks and made sure to keep the rear high enough to not have the fender lip damage the beautiful side walls when going over rail road tracks.
Keep old mopars alive.
Re: Air shocks\wide tires [Re: 2boltmain] #2960922
09/04/21 11:02 AM
09/04/21 11:02 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
A wee bit off topic but my '83 El Camino came from the factory with air shocks and all the mounting points looked great last time I changed shocks. Over 200,000 miles on that one......
Re: Air shocks\wide tires [Re: bobby66] #2960936
09/04/21 11:38 AM
09/04/21 11:38 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
It's also irrelevant. Your Elco doesn't even use the same style rear suspension. Is not made by the same manufacturer and was designed by the factory to use air shocks.
Re: Air shocks\wide tires [Re: 57Fury440] #2960942
09/04/21 11:51 AM
09/04/21 11:51 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
If you're set on air shocks, Gabriel HiJackers was the go to back in the day shock.
Best is ew springs and longer shocks. Talk with a knowledgeable spring shop and have the height (lift) and current center to center of the bushing dimension. Let them know the ride you desire (race or comfort). It's possible to re-arc but I've found that to not last. SS springs may not give you the "look" you want, and will likely end up with an uneven height across the rear. New properly set springs are really not that expensive in the big picture.
Lifting using pressure can hurt the body end mount of the shock over time, and amount of lift. Doing it with springs does not generate more forces on the uniframe.
Re: Air shocks\wide tires [Re: exile5700] #2960962
09/04/21 01:13 PM
09/04/21 01:13 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I love the old look.
Re: Air shocks\wide tires [Re: Sunroofcuda] #2960964
09/04/21 01:17 PM
09/04/21 01:17 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
And this one.
Re: Air shocks\wide tires [Re: 2boltmain] #2961074
09/04/21 09:43 PM
09/04/21 09:43 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I had N50 15 Mickey Thompson set up like that. But even with air shocks we rolled the lips.
Wood baseball bat stuffed between the tire and wheel lip held by friend as you drive away slooooow.
I knew quite a few guys who also did the same thing. Even used my bat.
They thought I was a genius.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Air shocks\wide tires [Re: kermit1] #2961215
09/05/21 11:56 AM
09/05/21 11:56 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Originally Posted by kermit1
fyi there is no way 10 inch rims arent going to stick out passed the quarter a little
Regarding the snipped comment above, 10" rims will fit inside the wheel lip if you move the leaf springs in and use the correct backspace wheel. I've got 10" rims with a 12" wide tire under my Challenger, all inside the wheel lip opening.
Re: Air shocks\wide tires [Re: TC@HP2] #2961221
09/05/21 12:21 PM
09/05/21 12:21 PM
340SIX Offline
340SIX  Offline
This but please move both front and rear.
I have seen guys just do the easy part. Move both.
Re: Air shocks\wide tires [Re: 340SIX] #2961739
09/07/21 12:19 AM
09/07/21 12:19 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
This is what six may be referring to
http://www.2040-parts.com/nos-mopar...ackles-for-super-stock-springs-i1302177/
just grabbed this not for the ad, but the pic.
Re: Air shocks\wide tires [Re: srt] #2961764
09/07/21 06:59 AM
09/07/21 06:59 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
IIRC, E bodies have splayed leafs, so the front hangers are already in compared to the rear.
The offset shackles just moves the rear in and makes them more parallel. Not sure why that would be an issue.
Re: Air shocks\wide tires [Re: Sniper] #2961801
09/07/21 10:28 AM
09/07/21 10:28 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
It isn't a big problem to change an E body's splayed mounting to parallel and it does provide additional clearance at the rear spring segment, which can help with fitting wider tires in the wheel well. Many drag racers do this. However, the splayed mounting does provide benefits in roll resistance, lateral stability, and rear steer characteristics. That is why the factory went to the splayed mounting arrangement in all cars eventually. The E bodies started in 70, the B bodies in 73, and the F bodies in 76. A bodies never got splayed mounting.
On my car, I did move both ends of the spring in an inch to both provide clearance and retain the design characteristics.
Re: Air shocks\wide tires [Re: TC@HP2] #2987955
11/22/21 06:53 PM
11/22/21 06:53 PM
St. Louis, MO
BevoHoosier Offline
BevoHoosier  Offline
St. Louis, MO
Saw a hi-jacked beater/period modded Trans-Am in a show on Netflix yesterday, and noticed that it had small brake/taillights mounted underneath the car on the shock mounts. ---As in, the back of the car is jacked up high, so they put a couple small lights way under the car where you can see them from behind... Anyone ever seen this this done back in the day? I'd never heard of it, but was kind of cool in a hoosier / mullet sorta way...
BMW 67 Dodge Polara 383
Re: Air shocks\wide tires [Re: BevoHoosier] #2987999
11/22/21 08:08 PM
11/22/21 08:08 PM
IMGTX Offline
IMGTX  Offline
Never saw the brake lights under the car but there were a lot of blue dots installed in the middle of the brake/taillights back in the day.
Re: Air shocks\wide tires [Re: IMGTX] #2988068
11/22/21 11:57 PM
11/22/21 11:57 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Getting back to air shocks I'm trying to think which reason came first for air shocks in the first place? Was it for load leveling for say pulling a trailer like an Air Stream, etc., or packing up tjhe family daily driver to head out for vacation or visit family? Or was it to jack up the rear of a car to put bigger tires on it.............I'm thinking it was the former and not the later back in the day. There were several other things marketed to help with load leveling for more daily driver/hauling vehicles that found there way onto muscle cars for changing the rear stance too. When you think of the market for load leveling versus hot rodding back in the day I don't think that Gabrial only considered big rear tires as the reason for air shocks......just my take on it.................and yes back in 1969 or was that 1970 I had a pair of air shocks on my '69 Road Runner with H70-14 tires but never really with a lot of PSI in them, just liked the slightly higher rear stance....
Re: Air shocks\wide tires [Re: IMGTX] #2988225
11/23/21 12:58 PM
11/23/21 12:58 PM
moparx Offline
moparx  Offline
blue dots, i used lots of those back when ! biggrin
also did the lights on the rear, mounted on the rear of the slapper bars. Lakewood's of course, when using Gabriel Hi-Jackers.
and speaking of high jackers, i just came into a set from a dart. don't know if they are any good, but i'll test them one of these days.
beer
Re: Air shocks\wide tires [Re: moparx] #2988368
11/23/21 06:49 PM
11/23/21 06:49 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
And the Hi-Jackers are still made! One of my reps reps Gabriel.
Page 2 of 3 1 2 3
