Re: Air shocks\wide tires
[Re: 57Fury440]
#2960865
09/04/21 06:40 AM
09/04/21 06:40 AM
Posts: 983 rust belt
Moparite
rust belt
Someone mentioned longer rear hangers which would help reduce the need for high shock pressures but if I remember correctly they won't work on an e-body because of the hangers hitting the rear valence. I remember back in the day you would see cars with them and the rear valence cut for clearance. I don't think you want that "vintage" look. Super stock springs are not a good idea for a street vehicle. My first Challenger had air shocks and the upper shock support was cracked everywhere. Re arch the springs would be my choice.
[Re: Moparite]
#2960886
09/04/21 09:30 AM
09/04/21 09:30 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I remember with my Challengers using a 15x10 wheel with a 4.5" backspace. N50X15s of various branding- Kelley Supercharger- Pro Trac. I had air shocks and made sure to keep the rear high enough to not have the fender lip damage the beautiful side walls when going over rail road tracks.
Keep old mopars alive.
[Re: bobby66]
#2960936
09/04/21 11:38 AM
09/04/21 11:38 AM
Posts: 6,240 nowhere
Sniper
nowhere
A wee bit off topic but my '83 El Camino came from the factory with air shocks and all the mounting points looked great last time I changed shocks. Over 200,000 miles on that one...... It's also irrelevant. Your Elco doesn't even use the same style rear suspension. Is not made by the same manufacturer and was designed by the factory to use air shocks.
[Re: 2boltmain]
#2961074
09/04/21 09:43 PM
09/04/21 09:43 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I remember with my Challengers using a 15x10 wheel with a 4.5" backspace. N50X15s of various branding- Kelley Supercharger- Pro Trac. I had air shocks and made sure to keep the rear high enough to not have the fender lip damage the beautiful side walls when going over rail road tracks. I had N50 15 Mickey Thompson set up like that. But even with air shocks we rolled the lips. Wood baseball bat stuffed between the tire and wheel lip held by friend as you drive away slooooow. I knew quite a few guys who also did the same thing. Even used my bat. They thought I was a genius.
[Re: kermit1]
#2961215
09/05/21 11:56 AM
09/05/21 11:56 AM
Posts: 5,388 Pikes Peak Country
TC@HP2
Pikes Peak Country
fyi there is no way 10 inch rims arent going to stick out passed the quarter a little Regarding the snipped comment above, 10" rims will fit inside the wheel lip if you move the leaf springs in and use the correct backspace wheel. I've got 10" rims with a 12" wide tire under my Challenger, all inside the wheel lip opening.
[Re: TC@HP2]
#2961221
09/05/21 12:21 PM
09/05/21 12:21 PM
340SIX
fyi there is no way 10 inch rims arent going to stick out passed the quarter a little Regarding the snipped comment above, 10" rims will fit inside the wheel lip if you move the leaf springs in and use the correct backspace wheel. I've got 10" rims with a 12" wide tire under my Challenger, all inside the wheel lip opening. This but please move both front and rear. I have seen guys just do the easy part. Move both.
[Re: TC@HP2]
#2987955
11/22/21 06:53 PM
11/22/21 06:53 PM
Posts: 388 St. Louis, MO
BevoHoosier
St. Louis, MO
Saw a hi-jacked beater/period modded Trans-Am in a show on Netflix yesterday, and noticed that it had small brake/taillights mounted underneath the car on the shock mounts. ---As in, the back of the car is jacked up high, so they put a couple small lights way under the car where you can see them from behind... Anyone ever seen this this done back in the day? I'd never heard of it, but was kind of cool in a hoosier / mullet sorta way...
BMW
67 Dodge Polara 383
[Re: IMGTX]
#2988225
11/23/21 12:58 PM
11/23/21 12:58 PM
Posts: 19,388 north of coder
moparx
Never saw the brake lights under the car but there were a lot of blue dots installed in the middle of the brake/taillights back in the day. blue dots, i used lots of those back when ! also did the lights on the rear, mounted on the rear of the slapper bars. Lakewood's of course, when using Gabriel Hi-Jackers. and speaking of high jackers, i just came into a set from a dart. don't know if they are any good, but i'll test them one of these days.
[Re: moparx]
#2988368
11/23/21 06:49 PM
11/23/21 06:49 PM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
And the Hi-Jackers are still made! One of my reps reps Gabriel.
