Oil pan bolt leaks #2959669
08/31/21 08:11 PM
08/31/21 08:11 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Many of my oil pan bolts are seeping. The pan seal to the block is dry. I do have double gasket due to use of a windage tray. It seems to be getting worse with age. Is there any way to fix this without pulling the pan and starting over? If the pan needs to come off, is that possible with a B-block in a E-body without lifting the engine? I know the drag link will need to be removed, but will the pan clear the craddle with a stoker crank (3.9")?
Thanks for the thoughts!
Re: Oil pan bolt leaks [Re: davenc] #2959683
08/31/21 08:36 PM
08/31/21 08:36 PM
I would put some sealant on those bolts
Re: Oil pan bolt leaks [Re: RapidRobert] #2959685
08/31/21 08:40 PM
08/31/21 08:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Like Robert says, I'd try some thread sealant first.
I can't speak for E-bodies, but on my Duster, the pan will hang up on a crank counterweight unless I turn the crank to a certain position to clear the front lip of the pan.
I marked the balancer for that position, and can have the pan off in minutes - and it's a 10 quart, so I gotta pull the center link.
Re: Oil pan bolt leaks [Re: davenc] #2959697
08/31/21 09:00 PM
08/31/21 09:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
We've had good success by letting the engine sit as long as possible for the oil to drain down.
remove 1 bolt at a time.
brake clean the bolt and block threads
Use a small amount of permatex Ultra Black on the bolt threads and if possible the block as well. ( wooden stick Q-tips work well)
Reinstall
Move onto the next bolt until all the leakers are done. Do not overtighten when reinstalling as the gaskets may not like it wink beer
Re: Oil pan bolt leaks [Re: TJP] #2959736
08/31/21 10:34 PM
08/31/21 10:34 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
been battling that for the last year or so . Bolts will loosen and then weep oil across gasket. Tried permatex gray , red and blue loctite . I was using ARP bolts , never had this before with factory bolts . Also has got the stock cork/rubber gasket . Just refitted factory bolts yesterday with loctite blue . I did find an old moparts link with a guy saying could not get the arp bolts to stay tight . I also have a couple different Felpro gaskets to try - #1808 performance gasket black compressed , #1834 steel core blue non stick (top fuel type )
Tex
PS : the #1808 seems similar to the Milodon gasket
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Oil pan bolt leaks [Re: TJP] #2959737
08/31/21 10:34 PM
08/31/21 10:34 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Thanks for all the suggestions!
Re: Oil pan bolt leaks [Re: tex013] #2959740
08/31/21 10:39 PM
08/31/21 10:39 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Hmmm....now I am wondering what the pan bolt length is on my engine. The double gasket and windage tray will certainly reduce the thread engagement in the block which maybe is reducing clamping force?? Maybe the bolts are loosening on my motor as well. Will need to get under the car this weekend.
Re: Oil pan bolt leaks [Re: davenc] #2959766
09/01/21 01:11 AM
09/01/21 01:11 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
The very reason I love the Superformance oil pan gaskets - Two gaskets with the windage tray
The material doesn’t compress , Non wicking , I don’t use rtv with these gaskets
And then the reproduction factory OEM oil pan bolt set that you can buy today , the oil pan bolts come with a dry blue thread locker already installed on threads
Perfection
Zero drips or tightening of bolts in years
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Oil pan bolt leaks [Re: bee1971] #2959835
09/01/21 09:56 AM
09/01/21 09:56 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
I would use a flat tap and clean the bolt holes to make sure they will fully tighten and blow them out with air hose. Also make sure the pan rail is flat if some of the bolts were over tightened.
Re: Oil pan bolt leaks [Re: davenc] #2959838
09/01/21 10:04 AM
09/01/21 10:04 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Remember the pair of bolts that go into the rear main seal holder are a few threads shorter than the rest of them. Are you using split washers? Brake or carb clean the holes and bolts, blow them out/off with air and seal with Permatex ultra seal.
I use the Hughes oil pan hold down flange reinforcing plates now days too. They require longer bolts. Not too long as its easy to crack out the ends of the holes into the crankcase.
Re: Oil pan bolt leaks [Re: jbc426] #2959846
09/01/21 10:29 AM
09/01/21 10:29 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
If those are the AR Engineering hold-downs, they don't work real well with the dimpled stock-type rails
in that the end holes are cantilevered over the dimples and don't exert an even clamping force effectively.
My experience...
Joe
Re: Oil pan bolt leaks [Re: jbc426] #2960106
09/01/21 08:40 PM
09/01/21 08:40 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
I honestly don't remember which bolts are on my motor. The motor was assembled years ago. Been doing some front suspension work and noticed oil coating on many under chassis things, and can see little drips forming on many of the bolts. Pan rail itself is dry and the pan is in very good shape (no bends). I am not using any sort of hold downs.
Did the factory bolt use a split washer?
Re: Oil pan bolt leaks [Re: davenc] #2960188
09/02/21 01:05 AM
09/02/21 01:05 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Nope on the split washer, and I think the torque spec on pan bolts will not compress
a normal split washer enough to be effective.
Maybe an internal star....
Joe
Re: Oil pan bolt leaks [Re: davenc] #2960319
09/02/21 02:41 PM
09/02/21 02:41 PM
Did the factory bolt use a split washer? Dave
Nope, never from 1955 to now on all the V8 I've work on scope The oil pan bolts have a capture flat washer, not split or star washers tsk
On your deal I would put some adhesive silicone sealer on the threads and tighten them so they have decent tension on them, that should stop the oil coming down the threads wrench scope up
Re: Oil pan bolt leaks [Re: Cab_Burge] #2960325
09/02/21 02:59 PM
09/02/21 02:59 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I bought a composite windage tray from Summit and have been pretty happy with it - molded in modern rubber o-ring style gasket on both sealing surfaces. After I installed it and a new pan (old one was crunched), I still had leaks that were coming from the front of the engine - pulled out the bolts that were going into the timing cover, RTV'd them, reassembled, and now it has finally stopped leaking!
Re: Oil pan bolt leaks [Re: Blusmbl] #2960531
09/03/21 07:35 AM
09/03/21 07:35 AM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Does you motor have a stroker crank? I wonder if these off the shelf composite windage trays will clear a 3.91" crank.
I need to think about whether to just try to seal the bolts or pull the pan and start over.
Thanks!
Re: Oil pan bolt leaks [Re: davenc] #2960541
09/03/21 08:50 AM
09/03/21 08:50 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Thanks!
They offer two sizes of them if I remember correctly - one for 3.75", and I think the other for 4.25". Mine is a stock stroke 440 so I used the 3.75" one. At 3.91" I'm sure you could use the 4.25" stroke version but it likely won't give you as much of a benefit as one specifically made for the 3.91" stroke.
Re: Oil pan bolt leaks [Re: Cab_Burge] #2960567
09/03/21 10:25 AM
09/03/21 10:25 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Cab, I know internal star washers were never on pan bolts, just offering a remedy.
Joe
Re: Oil pan bolt leaks [Re: jlatessa] #2960585
09/03/21 11:10 AM
09/03/21 11:10 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The only time I had problems with bolts leaking was on the Max Wedge engine. Bolts keep coming lose and the rest did drip a little. Long story went back and checked the service manual, it showed the torque, so many inch pounds?, after doing I never lost a bolt or leaked again. Never had to use any sealant, had windage tray also. stock bolts too
Re: Oil pan bolt leaks [Re: cudaman1969] #2961934
09/07/21 05:36 PM
09/07/21 05:36 PM
PA
moparacer Offline
moparacer  Offline
PA
Superformance gasket and ARP pan stud kit here. Best setup for the Milodon pans and scrapers.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
