727 lower shield #2955895
08/21/21 07:42 AM
08/21/21 07:42 AM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Not supposed to look like this? Asking for a friend. :-)
Re: 727 lower shield [Re: Vert] #2955920
08/21/21 10:24 AM
08/21/21 10:24 AM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
that shield doesn't do a very good job of stopping convertor bolts........seriously that shield should be trimmed anywhere the convertor bolts will pass by. Also if you have one of those shim/gaskets between the starter and trans, that should be trimmed as well.
Re: 727 lower shield [Re: varunner] #2955925
08/21/21 10:35 AM
08/21/21 10:35 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
It's bent/warped that's what cause the bolt to hit it. Trimming it will only make it weaker bend it back to straight where it won't be at risk of getting hit.You may have to put in some relief cuts in it to compensate for the stretched metal.
Re: 727 lower shield [Re: Moparite] #2955941
08/21/21 11:28 AM
08/21/21 11:28 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
They were an issue years back ( 60-80's), seemed more so on small blocks if I remember correctly. I ran a lot of cars without them wink beer
Re: 727 lower shield [Re: TJP] #2955944
08/21/21 11:41 AM
08/21/21 11:41 AM
5thAve Offline
5thAve  Offline
Mine doesn't have one. Partially because I didn't have a 727 when I switched over only 904 ones and they don't fit. Also because the one I did end up getting was the taller kind that tends to be warped in and hit those bolts after it's installed. Could have cut it and maybe I did I can't remember but it's not on there.
Re: 727 lower shield [Re: Vert] #2955985
08/21/21 01:24 PM
08/21/21 01:24 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
I have two, the other one being taller, and not warped like this one. Thinking I may either cut out the warped one, or go without. Between my headers and "custom" trans lines, a stock unit needs to be bowed some to get it in place. Maybe I could fit a piece of plexiglass and watch the goodies turn round and round.
Re: 727 lower shield [Re: Vert] #2956123
08/21/21 08:49 PM
08/21/21 08:49 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
LOL good beerone
Re: 727 lower shield [Re: Vert] #2956751
08/23/21 09:15 PM
08/23/21 09:15 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yea, and the plexiglass one wouldn't put up as much resistance when the bolt heads hit it the next time.
Given the options, I think I would just leave it off.
Re: 727 lower shield [Re: Vert] #2956809
08/24/21 12:44 AM
08/24/21 12:44 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
well you do know that is the wrong dust shied , correct.
Re: 727 lower shield [Re: calrobb2000] #2956810
08/24/21 01:22 AM
08/24/21 01:22 AM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Andy sold a nice powder coated shield at one time... at least I think I got from him, don't see it on his site anymore though...
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: 727 lower shield [Re: calrobb2000] #2957103
08/24/21 10:26 PM
08/24/21 10:26 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
I did not. I have two, one that was on the 727 that came out, and one on the 727 I had rebuilt. Don't recall which I used. What does the one I need look like?
Re: 727 lower shield [Re: Vert] #2957120
08/24/21 11:14 PM
08/24/21 11:14 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
look at where the converter bolts have hit the shied you posted .
the correct shield will be offset here for bolt head clearance .
you do have the correct flex plate to converter bolts i hope , not just regular bolts ?
Re: 727 lower shield [Re: calrobb2000] #2957161
08/25/21 04:15 AM
08/25/21 04:15 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Clearance Clarence
I had to remove mine because of under hard acceleration, it would touch the oversized converter bolts and make noise.
I havent gotten around to addressing it yet.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: 727 lower shield [Re: calrobb2000] #2957426
08/25/21 08:29 PM
08/25/21 08:29 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Pretty sure I have the correct converter bolts. Had a pack from ATi, and a pack from Mopar Performance. Thin heads.
Re: 727 lower shield [Re: Vert] #2957628
08/26/21 02:23 PM
08/26/21 02:23 PM
You guys do know that there are two different sizes, correct?
12 inch and 11 inch converter shields are different scope
Same thing on the converters having 5/16 bolts compared to the ones with 7/16 inch bolts shruggy
Re: 727 lower shield [Re: Cab_Burge] #2957773
08/26/21 08:52 PM
08/26/21 08:52 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up beer
Re: 727 lower shield [Re: 5thAve] #2957821
08/26/21 10:51 PM
08/26/21 10:51 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
I ran my 72 D200 without one for many years, no issues. My 68 Dart doesn't have one either.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 727 lower shield [Re: GTSDart340] #2957925
08/27/21 10:05 AM
08/27/21 10:05 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
And, it can't hurt with cooling too.
Joe
Re: 727 lower shield [Re: jlatessa] #2958122
08/27/21 09:33 PM
08/27/21 09:33 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
They sure help if you live on, or drive on a gravel road though. That open bell does a great job at scooping up and collecting dirt grit, small stones, and gravel dust, without the shield.
Re: 727 lower shield [Re: Cab_Burge] #2958139
08/27/21 10:56 PM
08/27/21 10:56 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Cab, from the pic, it appears I may have the smaller converter. ATi Streetmaster is what I remember. Even with the wrong shield, it worked fine until I removed it again and flexed it to reinstall around. the trans lines. Ray Barton said this was the converter I needed, but he never saw the trans or shield.
