b / rb valve cover gaskets ? #2952844
08/11/21 03:57 PM
08/11/21 03:57 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
who makes the best leak free valve cover gaskets for the b /rb stock valve covers ?
tired of the oil spot on the floor !
thank you !
Re: b / rb valve cover gaskets ? [Re: calrobb2000] #2952974
08/11/21 08:48 PM
08/11/21 08:48 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have good luck with the FelPro Fel-Pro VS50145R gaskets.
Re: b / rb valve cover gaskets ? [Re: jwb123] #2953021
08/11/21 10:52 PM
08/11/21 10:52 PM
PA
moparacer Online content
moparacer  Online Content
PA
Best I have found is the Cometic C5983
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: b / rb valve cover gaskets ? [Re: calrobb2000] #2953031
08/12/21 12:09 AM
08/12/21 12:09 AM
SCE thick black rubber cork combination, sorry for no part # blush
Re: b / rb valve cover gaskets ? [Re: calrobb2000] #2953050
08/12/21 07:18 AM
08/12/21 07:18 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I use the Blue Moroso ones with steel core with my Mopar Performance Cast Valve Covers. Been on the car for 6-7 years without any issues. I check valve lash at least once a year and reuse them.
Re: b / rb valve cover gaskets ? [Re: DusterKid] #2953123
08/12/21 12:36 PM
08/12/21 12:36 PM
moparx Offline
moparx  Offline
duster, what heads do you have ?
i have a 440 on the stand as we speak, it has rpm heads and the mp cast covers.
beer
Re: b / rb valve cover gaskets ? [Re: moparx] #2953145
08/12/21 01:25 PM
08/12/21 01:25 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
beer
Been using TF 240s for the last 3 years. Before that I used 440 source stealth heads that are on my spare motor.
Re: b / rb valve cover gaskets ? [Re: DusterKid] #2953173
08/12/21 03:05 PM
08/12/21 03:05 PM
PA
PA
I had trouble with the blue Moroso gaskets splitting and leaking once they were tightened several times. I have Indy heads and valve covers.
The cometics are a harder rubber and have solved that problem.
Much better.
Re: b / rb valve cover gaskets ? [Re: moparacer] #2953214
08/12/21 05:29 PM
08/12/21 05:29 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Best I've found is Superformance Carbon-X gaskets with stock covers and heads but, as of a few months ago, they were unobtainum. Called Superformance direct, a few other distributors and Todd at Marsh and no one has them. Todd said that he has essentially the same gasket that Fel-Pro makes so; I had him send me two sets. I've not tried them yet though.
Re: b / rb valve cover gaskets ? [Re: jwb123] #2953223
08/12/21 06:01 PM
08/12/21 06:01 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
This has been my go to gasket since the 90's. If rocker clearance is needed I glue them together and use them doubled up for clearance. Still no leaks and reusable over and over if you don't over tighten them or try to torque them down full of oil. The surfaces need to be clean on the gasket and head so the gasket doesn't slide out of place.
Re: b / rb valve cover gaskets ? [Re: calrobb2000] #2953255
08/12/21 08:12 PM
08/12/21 08:12 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Mr Gasket ultraseal works for me. Glue them to the cover with 3m trim adhesive(gorilla snot). Use nothing on head side.
Re: b / rb valve cover gaskets ? [Re: GomangoCuda] #2953641
08/14/21 06:43 AM
08/14/21 06:43 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I always use cast aluminum valve covers(mopar/MT). The stamped ones are to flimsy and bend/distort when you tighten the bolts. Don't use tree bark (cork) gaskets for anything they suck!
Re: b / rb valve cover gaskets ? [Re: calrobb2000] #2954973
08/18/21 10:04 AM
08/18/21 10:04 AM
California, U.S.A.
Torquemonster440 Offline
California, U.S.A.
I've tried many. Blue Moroso steel core.. rubber split around the core and leaked. This was on 906 iron heads. The superformance black cork/fiber work ok.. they deform easily after a few uses. Good ol' cork Felpros's seem to seal the best for me. Just be careful not to over tighten any of them and you'll be ahead of the curve.
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: b / rb valve cover gaskets ? [Re: Torquemonster440] #2955033
08/18/21 01:51 PM
08/18/21 01:51 PM
moparx Offline
moparx  Offline
it appears over tightening is more prevalent than one thinks.
i use a nut driver. that seems to work the best for me no matter what cover/head combo is in use.
your mileage will vary.
beer
Re: b / rb valve cover gaskets ? [Re: GomangoCuda] #2955121
08/18/21 06:52 PM
08/18/21 06:52 PM
NC
440Jim Offline
440Jim  Offline
NC
With factory stamped steel valve covers, glue is the ticket. And don't over tighten. When new, tighten reasonably; then after a heat cycle do final tightening.
I tend to use Felpro cork/rubber combo, and they work great. I think the ones on my street Cuda 440 are at least 7 years old...
My current Daytona "tow truck" engine has factory valve covers and factory iron heads and they don't leak at all.
Re: b / rb valve cover gaskets ? [Re: moparx] #2955221
08/19/21 03:18 AM
08/19/21 03:18 AM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
beer
iagree
I use the Moroso steel cored gaskets. Eventually they split, most likely because they were over tightened and because I check the valves probably too frequently
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
