Sanden Compressor brackets for 340 #2949846
08/02/21 10:39 PM
08/02/21 10:39 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
I would like to add aftermarket AC to my 1973 Charger Rallye 340CID.
I do have the correct crank and water pump pulleys for an AC car. I will replace the alternator to a 2 groove style.
I would like to use 2 V belts like the factory did and have it look like this attached picture. This is a factory setup modified by owner.
Bouchillion, Vintage Air, Auto AC Solutions, Classic Air etc.... don't offer the right brackets to run 2 V belts for small block engines.
Wondering if anyone knows of a vendor that has such a kit.
Re: Sanden Compressor brackets for 340 [Re: Gabmando] #2949848
08/02/21 10:46 PM
08/02/21 10:46 PM
BDW Online content
BDW  Online Content
I converted my 340 AC car to Sanden and kept 2 belt system.
Vintage air bracket.
Re: Sanden Compressor brackets for 340 [Re: Gabmando] #2949849
08/02/21 10:48 PM
08/02/21 10:48 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
https://www.speedwaymotors.com/Speedway-Sanden-Style-508-V-Belt-A-C-Compressor-Plain,8581.html?sku=42813459&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=CjwKCAjwr56IBhAvEiwA1fuqGj1lOJAIURCTguEjpvY-2fzkshsWDVYNJ4eqTDtRDX6fU-lWs4SOdBoCREAQAvD_BwE
or
https://www.ebay.com/itm/162722716379?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1zYSlvfLJRjKORKmm-s0DOQ98&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=162722716379&targetid=1262843335169&device=c&mktype=pla&googleloc=1027028&poi=&campaignid=12874650447&mkgroupid=121788266346&rlsatarget=pla-1262843335169&abcId=9300535&merchantid=101678214&gclid=CjwKCAjwr56IBhAvEiwA1fuqGifyd55hDSPjZyv4vMQYQE3VhvggR2PQ9RB9E77S1R8Bb1r0rJv0cBoCm50QAvD_BwE
Re: Sanden Compressor brackets for 340 [Re: Ply72rr] #2949855
08/02/21 10:57 PM
08/02/21 10:57 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we offer a serpentine kit that uses a sanden compressor
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Sanden Compressor brackets for 340 [Re: Jerry] #2949951
08/03/21 10:32 AM
08/03/21 10:32 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have a bracket that came off a 318
Abe Lincoln
Re: Sanden Compressor brackets for 340 [Re: BDW] #2950283
08/04/21 07:00 AM
08/04/21 07:00 AM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
Thank you for all the replies.
BDW did you have to use any of the original AC brackets to work with the Vintage Air bracket?
Did you purchase the whole kit for Challenger from them, or did you mix and match?
If it is not too much trouble, can you please post or IM photos of the whole setup?
I plan to document my conversion in detail for other 71 to 74 B bodies owners so information and tips is very much appreciated.
I also plan on converting my 70 Challenger 383 to the Sanden setup.
Great forum. Thank you for the help.
Re: Sanden Compressor brackets for 340 [Re: Gabmando] #2950326
08/04/21 10:01 AM
08/04/21 10:01 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Can you just use the brackets and pulleys from an 80's 318?
Re: Sanden Compressor brackets for 340 [Re: mgoblue9798] #2950328
08/04/21 10:14 AM
08/04/21 10:14 AM
BDW Online content
BDW  Online Content
I started with factory AC set-up.
Removed compressor and all brackets, bolted on the VA bracket.
Bought the Sanden compressor on EBay, then took car to local guy to fab up the lines to the factory condenser and firewall.
Re: Sanden Compressor brackets for 340 [Re: mgoblue9798] #2950864
08/05/21 09:31 PM
08/05/21 09:31 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
mgoblue9798 using 80's brackets might work too. Sounds reasonable.
