I would like to add aftermarket AC to my 1973 Charger Rallye 340CID.
I do have the correct crank and water pump pulleys for an AC car. I will replace the alternator to a 2 groove style.
I would like to use 2 V belts like the factory did and have it look like this attached picture. This is a factory setup modified by owner.
Bouchillion, Vintage Air, Auto AC Solutions, Classic Air etc.... don't offer the right brackets to run 2 V belts for small block engines.
Wondering if anyone knows of a vendor that has such a kit.
