Page 2 of 3 1 2 3
Re: 1959 361ci. swap to 383 [Re: 3hundred] #2947503
07/26/21 07:52 PM
07/26/21 07:52 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The pre 62 autos used a separate bellhousing which had to be dialed in to the torque converter hub when removed or the converter changed. The converter mounts directly to the crank. then the bellhousing to the bloc. per the FSM you heat the front of the converter to get it within spec which is +/- .0015 or .002. It's a trial and error until you get the hang of where and how much to heat> BTW you wont find this info in the trans section, it's at the back of the engine section. AMHIK. Failure to do the above will typically take out the front bushing in a short time. I'm also not sure if the bellhousing to block bolt pattern is the same
Should you really want to pursue this idea here's a pic of the front of the trans and I'll say you have bigger "cajones" Than I biggrinwhistling beer
Re: 1959 361ci. swap to 383 [Re: TJP] #2947577
07/26/21 10:16 PM
07/26/21 10:16 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
You ain’t kidding😬. I guess all I can hope for is to be able to work with the original engine and try to get it running right. I really want to retain the push button functionality of the transmission.
Re: 1959 361ci. swap to 383 [Re: rapom] #2947584
07/26/21 10:32 PM
07/26/21 10:32 PM
Is it a 2 speed Powerflyte or a 3 speed torqeflyte?
Re: 1959 361ci. swap to 383 [Re: rapom] #2947743
07/27/21 11:20 AM
07/27/21 11:20 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up Give us an update when you get the car. beer
Re: 1959 361ci. swap to 383 [Re: rapom] #2947750
07/27/21 11:39 AM
07/27/21 11:39 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Imperial Services makes a kit to use your pushbutton shifter with a newer trans. At the bottom:
http://www.imperialservices.net/Cparts.html
Re: 1959 361ci. swap to 383 [Re: Sniper] #2947778
07/27/21 01:07 PM
07/27/21 01:07 PM
I have a friend who bought one of Imperial kits for using a GM250 O.D. tranny behind his M.W. 1963 plymouth, it wouldn't work so he sent it back to them.
He waited a long time after ordering it and to get it and then it wouldn't work down twocents
Re: 1959 361ci. swap to 383 [Re: Cab_Burge] #2947831
07/27/21 03:34 PM
07/27/21 03:34 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
They don't even list a kit for a GM trans. It's not claimed to be universal.
Re: 1959 361ci. swap to 383 [Re: TJP] #2947878
07/27/21 06:16 PM
07/27/21 06:16 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
I’ll post some pictures when I get it home Saturday 🤞
Re: 1959 361ci. swap to 383 [Re: Sniper] #2947885
07/27/21 06:35 PM
07/27/21 06:35 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Thanks for the link. I see they are out of stock. I’ll have to call them up about when they can make more.
Re: 1959 361ci. swap to 383 [Re: Sniper] #2947890
07/27/21 06:51 PM
07/27/21 06:51 PM
According to him they sold him the kit saying it would work and it took forever to get. I wonder if they were developing it after he made his order.
He ended up getting another brand that does work up
My message is be careful when dealing with them twocents
Re: 1959 361ci. swap to 383 [Re: Cab_Burge] #2949322
08/01/21 09:06 AM
08/01/21 09:06 AM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Here’s a pic of the car. I posted more pics on the general forum.
Re: 1959 361ci. swap to 383 [Re: rapom] #2949491
08/01/21 06:34 PM
08/01/21 06:34 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Beautiful car!
Re: 1959 361ci. swap to 383 [Re: rapom] #2949526
08/01/21 08:32 PM
08/01/21 08:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
drool drool up
Re: 1959 361ci. swap to 383 [Re: TJP] #2949613
08/02/21 09:27 AM
08/02/21 09:27 AM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Thanks guys
Re: 1959 361ci. swap to 383 [Re: rapom] #2949633
08/02/21 10:37 AM
08/02/21 10:37 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
wow!!!
what's wrong with the 361 ? ( aside the lack of available pistons for them ).
Re: 1959 361ci. swap to 383 [Re: rapom] #2949634
08/02/21 10:45 AM
08/02/21 10:45 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Thanks for the info everybody. Just trying to figure out all my options. And it looks like the easy option is not a option.🤔. I might be getting a car with a tired 361.
If you have a nice 383, just go find a newer 727, mate them up and put them in together. That of just get the 361 running as best you can and drive it until it fails.
Coming soon!!!!
Re: 1959 361ci. swap to 383 [Re: rapom] #2949635
08/02/21 10:46 AM
08/02/21 10:46 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
dam that is sexy.
Coming soon!!!!
Re: 1959 361ci. swap to 383 [Re: Mr.Yuck] #2949654
08/02/21 11:35 AM
08/02/21 11:35 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I've been told a '65-only 727 will work with a later 383 and the pushbuttons, because of the compatible "rooster comb" still in use that year.
2 guys that should definitely know from experience have told me that.
Re: 1959 361ci. swap to 383 [Re: topside] #2949672
08/02/21 12:40 PM
08/02/21 12:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The pre-62 transmissions are a different trans altogether and do not have a park mechanism relying on a brake band mounted to the back of the trans instead. One may be able to make something work but it's not going to be a plug and play deal. May be more information on the Forward Look site beer
Re: 1959 361ci. swap to 383 [Re: TJP] #2949997
08/03/21 01:09 PM
08/03/21 01:09 PM
moparx Offline
moparx  Offline
the 65 only transmission works with the 62-64 pushbutton with the park lever.
it is desirable because it has a slip yoke instead of the ball and trunnion u-joint, while still using the two cables necessary for the pushbutton shifter.
beer
Page 2 of 3 1 2 3
