Best way to remove this copper broken nipple on Accumulator #2946936
07/25/21 11:43 AM
07/25/21 11:43 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Had a little mishap and threaded nipple broke off.
This thing is on good.
I made a tool to hold cover in place but this nippers will not budge.
Should I hit it with some heat?
The problem is there's rubber o rings inside and they surely will get distorted
Re: Best way to remove this copper broken nipple on Accumulator [Re: Sammy] #2946944
07/25/21 12:11 PM
07/25/21 12:11 PM
A727Tflite Offline
A727Tflite  Offline
What’s the chances of placing in a press and removing the snap ring?
Re: Best way to remove this copper broken nipple on Accumulator [Re: A727Tflite] #2946948
07/25/21 12:23 PM
07/25/21 12:23 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
they are called Easy out / screw extractor. can get it at auto parts or amazon.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Best way to remove this copper broken nipple on Accumulator [Re: A727Tflite] #2946950
07/25/21 12:25 PM
07/25/21 12:25 PM
Texas
Chief Offline
Chief  Offline
Texas
Make a tool to fit in the hole on each side of the nipple. Then get a easy out on it to screw it out.
Simple, only take a little time to do it.
Dave Covey
Re: Best way to remove this copper broken nipple on Accumulator [Re: Chief] #2946952
07/25/21 12:30 PM
07/25/21 12:30 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Its a bit of a pain, but take the snap ring off and take the plate off. I have done it numerous times. I clean my accumulator every so often. Then you can put some heat on it (not too much) and I would put vise grips on it and see what happens.
Re: Best way to remove this copper broken nipple on Accumulator [Re: markz528] #2946978
07/25/21 01:12 PM
07/25/21 01:12 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Get a pipe easy out. They have a hex head and a short extractor spline. I use them at work a lot, they rarely fail.
Re: Best way to remove this copper broken nipple on Accumulator [Re: markz528] #2946982
07/25/21 01:25 PM
07/25/21 01:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree EZ-Outs are marginal in brass and you'll get shavings inside the accumulator.
Re: Best way to remove this copper broken nipple on Accumulator [Re: markz528] #2946988
07/25/21 01:40 PM
07/25/21 01:40 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Those snap rings just flat out suck. I bought the lisle heavy duty snap ring tool. I don't see how it's going to help taking it off.
I won't be able to keep the retainer from moving around.
Re: Best way to remove this copper broken nipple on Accumulator [Re: John_Kunkel] #2946989
07/25/21 01:41 PM
07/25/21 01:41 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I guess I could put great on the eyes out. I do have the full snap on extractor kit.
I did try visegrips and it doesn't budge.
Re: Best way to remove this copper broken nipple on Accumulator [Re: Sammy] #2946995
07/25/21 02:11 PM
07/25/21 02:11 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
1) remove snap ring
2) remove plate
3) clamp plate in vise with soft jaws on faces of plate
4) take die grinder and grind two slots in nipple 180 degrees apart
5) collapse nipple with hammer and punch
6) chase threads and clean all debris from plate
7) install plate
8) install snap ring
9) done
Re: Best way to remove this copper broken nipple on Accumulator [Re: Sammy] #2947005
07/25/21 02:39 PM
07/25/21 02:39 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
You could try sliding a properly sized long socket into the brass fitting and then use vice grips to clamp onto it hard and screw it out. The socket will keep it from collapsing while you try and clamp onto it.
Probably best to do what the guys above are recommending, so you can clean the cylinder while it's apart.
Re: Best way to remove this copper broken nipple on Accumulator [Re: jbc426] #2947009
07/25/21 02:50 PM
07/25/21 02:50 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
2 seconds of heat. Waited 1 minute. 2 more seconds of heat. Visegrips loosened it right up.
I had a extra set of rubber o rings just in case. This was a new never used accumulator. No need to clean anything inside yet. Thanks. I did have the o ring pliers ready to remove if I had to. Thanks guys.
Re: Best way to remove this copper broken nipple on Accumulator [Re: Sammy] #2947024
07/25/21 03:51 PM
07/25/21 03:51 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: Best way to remove this copper broken nipple on Accumulator [Re: 6PakBee] #2947060
07/25/21 06:15 PM
07/25/21 06:15 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Went to hardware store and got a 1/2"x close nipple.
The other end in the shutoff valve came out with a EZ Out fairly easy.
All back together. Waiting to assemble in the car tomorrow. Way too humid.
Re: Best way to remove this copper broken nipple on Accumulator [Re: Sammy] #2947138
07/25/21 09:16 PM
07/25/21 09:16 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I've done this once and used a square cold chisel that fit in the fitting. I tapped it in and the square corners bit into the fitting enough to hold while I twisted it with an adjustable wrench.
You could probably make a removal tool out of a piece of scrap metal - even a bolt that's oversize - grind the end square and tapered and tap it into the fitting.
Re: Best way to remove this copper broken nipple on Accumulator [Re: Stanton] #2947185
07/25/21 11:45 PM
07/25/21 11:45 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
must be the day for it , i had a holley power valve shear off when going to undo it today at work.
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Best way to remove this copper broken nipple on Accumulator [Re: 6PakBee] #2947393
07/26/21 03:08 PM
07/26/21 03:08 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Take the snap ring out. Takes the right tool and two hands. I took mine apart at least once a year and cleaned it out. You will be amazed (disgusted) at the trash those things collect.
Clamp the end plate up, use some heat and a good easy-out. Worst case you'll have to drill it, knock the pieces out and fix the threads.
ETA...failed to read all the way...but it still should be cleaned out occasionally.
Re: Best way to remove this copper broken nipple on Accumulator [Re: CMcAllister] #2947421
07/26/21 04:26 PM
07/26/21 04:26 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Thanks. It was new never used so I just hit it with 2 seconds of heat on each side. Resting 30 seconds on each heat .
Whatever thread sealer they used was on good. It melted and it came right off.
Re: Best way to remove this copper broken nipple on Accumulator [Re: Sammy] #2947796
07/27/21 01:41 PM
07/27/21 01:41 PM
moparx Online content
moparx  Online Content
glad you got it out. up
broken brass can be a real pain at times to remove, especially if over-tightened, causing stretched and/or galled threads.
beer
Re: Best way to remove this copper broken nipple on Accumulator [Re: moparx] #2947832
07/27/21 03:35 PM
07/27/21 03:35 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
beer
Tell me about it.
I thought the other end was going to be worse.
It wasn't.
Moroso puts some crazy thread sealer on the fitting.
