Re: Best way to remove this copper broken nipple on Accumulator
[Re: A727Tflite]
#2946948
07/25/21 12:23 PM
07/25/21 12:23 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
they are called Easy out / screw extractor. can get it at auto parts or amazon.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: A727Tflite]
#2946950
07/25/21 12:25 PM
07/25/21 12:25 PM
Posts: 200 Texas
Chief
Texas
Make a tool to fit in the hole on each side of the nipple. Then get a easy out on it to screw it out. Simple, only take a little time to do it.
Dave Covey
[Re: Chief]
#2946952
07/25/21 12:30 PM
07/25/21 12:30 PM
Posts: 4,267 Morrow, OH
markz528
Morrow, OH
Its a bit of a pain, but take the snap ring off and take the plate off. I have done it numerous times. I clean my accumulator every so often. Then you can put some heat on it (not too much) and I would put vise grips on it and see what happens.
[Re: markz528]
#2946978
07/25/21 01:12 PM
07/25/21 01:12 PM
Posts: 20,149 Park Forest, IL
slantzilla
Park Forest, IL
Get a pipe easy out. They have a hex head and a short extractor spline. I use them at work a lot, they rarely fail.
[Re: markz528]
#2946982
07/25/21 01:25 PM
07/25/21 01:25 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Its a bit of a pain, but take the snap ring off and take the plate off. EZ-Outs are marginal in brass and you'll get shavings inside the accumulator.
[Re: markz528]
#2946988
07/25/21 01:40 PM
07/25/21 01:40 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Its a bit of a pain, but take the snap ring off and take the plate off. I have done it numerous times. I clean my accumulator every so often. Then you can put some heat on it (not too much) and I would put vise grips on it and see what happens. Those snap rings just flat out suck. I bought the lisle heavy duty snap ring tool. I don't see how it's going to help taking it off. I won't be able to keep the retainer from moving around.
[Re: John_Kunkel]
#2946989
07/25/21 01:41 PM
07/25/21 01:41 PM
Sammy
Wind Gap,Pa.
Its a bit of a pain, but take the snap ring off and take the plate off. EZ-Outs are marginal in brass and you'll get shavings inside the accumulator. I guess I could put great on the eyes out. I do have the full snap on extractor kit. I did try visegrips and it doesn't budge.
[Re: Sammy]
#2946995
07/25/21 02:11 PM
07/25/21 02:11 PM
Posts: 10,666 North Dakota
6PakBee
North Dakota
1) remove snap ring 2) remove plate 3) clamp plate in vise with soft jaws on faces of plate 4) take die grinder and grind two slots in nipple 180 degrees apart 5) collapse nipple with hammer and punch 6) chase threads and clean all debris from plate 7) install plate 8) install snap ring 9) done
[Re: Sammy]
#2947005
07/25/21 02:39 PM
07/25/21 02:39 PM
Posts: 3,275 West Coast, USA
jbc426
West Coast, USA
You could try sliding a properly sized long socket into the brass fitting and then use vice grips to clamp onto it hard and screw it out. The socket will keep it from collapsing while you try and clamp onto it.
Probably best to do what the guys above are recommending, so you can clean the cylinder while it's apart.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Stanton]
#2947185
07/25/21 11:45 PM
07/25/21 11:45 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
must be the day for it , i had a holley power valve shear off when going to undo it today at work.
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 6PakBee]
#2947393
07/26/21 03:08 PM
07/26/21 03:08 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Take the snap ring out. Takes the right tool and two hands. I took mine apart at least once a year and cleaned it out. You will be amazed (disgusted) at the trash those things collect.
Clamp the end plate up, use some heat and a good easy-out. Worst case you'll have to drill it, knock the pieces out and fix the threads.
ETA...failed to read all the way...but it still should be cleaned out occasionally.
[Re: CMcAllister]
#2947421
07/26/21 04:26 PM
07/26/21 04:26 PM
Sammy
Wind Gap,Pa.
ETA...failed to read all the way...but it still should be cleaned out occasionally. Thanks. It was new never used so I just hit it with 2 seconds of heat on each side. Resting 30 seconds on each heat . Whatever thread sealer they used was on good. It melted and it came right off.
[Re: moparx]
#2947832
07/27/21 03:35 PM
07/27/21 03:35 PM
Sammy
Wind Gap,Pa.
glad you got it out. broken brass can be a real pain at times to remove, especially if over-tightened, causing stretched and/or galled threads. Tell me about it. I thought the other end was going to be worse. It wasn't. Moroso puts some crazy thread sealer on the fitting.
