Question with a new project #2944107
07/16/21 10:29 PM
07/16/21 10:29 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I’m adding a cowl scoop. The scoop has a point on the front. Some are saying to remove the point. I guess I could cut it off and tiger hair a blunt nose on it. What do you guys think, cut it off or leave it?
F3650915-6896-4A66-A1CA-38CD05046BF0.jpeg94C07D68-6727-457E-BF80-F8E556D7E2BD.jpeg1CD63C72-28B1-4FE7-B45D-97F0CEA62D90.jpeg
Re: Question with a new project [Re: mopar dave] #2944109
07/16/21 10:42 PM
07/16/21 10:42 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I think I would like it better as a smooth transition vs what it is now. It's not terrible as-is, but it's not as clean as it could be basically...
Re: Question with a new project [Re: Neil] #2944110
07/16/21 10:46 PM
07/16/21 10:46 PM
Mt Morris Michigan
Mt Morris Michigan
I suppose I could pick up a can of tiger hair and get busy. It would match the hood line better if it were straight across the front.
Re: Question with a new project [Re: mopar dave] #2944111
07/16/21 10:51 PM
07/16/21 10:51 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
More work, but you could also just shave off the whole hoodscoop perimeter around the bottom to eliminate the front lip instead? You'd loose some overall height though so that may not work for what you have going on.
Re: Question with a new project [Re: Neil] #2944126
07/16/21 11:40 PM
07/16/21 11:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Or taper the cut along the sides & front so the front is more flush but the rear is at full height.
I agree that a smooth transition would look better, but ideal to my eye would be to loose the "point" at the front.
Must be a pretty mellow evening here, usually a few guys will post how much they hate "Chevy hoods"...
I personally have no issue with cowl-induction hoods, and I like the more gradual/rounded shapes I see on some of the SO cars.
Re: Question with a new project [Re: mopar dave] #2944172
07/17/21 07:38 AM
07/17/21 07:38 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would prefer no lip if it was my car but either way looks good. Let me know when you are done and I will send you mine to do lol.
Do you have a hood latch up front? I have a glasstek race weight hood on my 68 Barracuda. Its pinned down in 6 places, the front center pin is on the core support. I can see the hood bending up in front of the front center pin, like a lot. I have lowered it down where it rests well below the header panel but it still comes up. It bends enough in front of the pin that I can't believe it hasn't broken yet.
68 Barracuda Formula S 340
Re: Question with a new project [Re: mopar dave] #2944186
07/17/21 09:40 AM
07/17/21 09:40 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What do YOU think when you walk by it? If YOU don't care, why mess with it? However, if there is the slightest dislike for the 'point' remove it now. Every time YOU walk by the car you don't want to be telling yourself 'Boy, I wish I'd removed that.'.
twocents
Re: Question with a new project [Re: 6PakBee] #2944220
07/17/21 10:41 AM
07/17/21 10:41 AM
my own world
theraif Offline
theraif  Offline
my own world
twocents blend it the front edge
Re: Question with a new project [Re: Bad340fish] #2944221
07/17/21 10:42 AM
07/17/21 10:42 AM
Mt Morris Michigan
Mt Morris Michigan
I have a latch, it is a hinged hood.
Re: Question with a new project [Re: 6PakBee] #2944223
07/17/21 10:43 AM
07/17/21 10:43 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Why does it have to be a cowl scoop? Looks too much like a GM product. I'd opt for one that gets the air from the front.
Re: Question with a new project [Re: mopar dave] #2944224
07/17/21 10:44 AM
07/17/21 10:44 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
A smooth transition will look better
Ok
Re: Question with a new project [Re: topside] #2944226
07/17/21 10:48 AM
07/17/21 10:48 AM
Mt Morris Michigan
Mt Morris Michigan
The hood scoop is a bolt on type and has an inner lip, so i have to be careful how much i take off the bottom or i will remove the mounting flange. I may just remove the center most point and blend the rest in the best i can. That shouldn't be too hard to do. Its not hard to cut as i have removed about 4" from the rear already. I will cut the hole tomorrow and see what i can do with that point on the front. Thanks
Re: Question with a new project [Re: Moparite] #2944231
07/17/21 10:52 AM
07/17/21 10:52 AM
Mt Morris Michigan
Mt Morris Michigan
I like the mopar scoops, but i think they are a big parachute on your hood, especially the Hemi scoop. With a T ram, i think these work better with what i'm doing.
Re: Question with a new project [Re: mopar dave] #2944234
07/17/21 11:12 AM
07/17/21 11:12 AM
Mt Morris Michigan
Mt Morris Michigan
Also, gonna cut the hole tomorrow, do you think a jigsaw with a fine blade works best?
Re: Question with a new project [Re: mopar dave] #2944249
07/17/21 11:53 AM
07/17/21 11:53 AM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
I always mask the area & then draw on the profile I need. Fine jigsaw blade will be fine, cut from the good side of the hood.
Re: Question with a new project [Re: mopar_mark] #2944253
07/17/21 12:01 PM
07/17/21 12:01 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
What about a formica blade ? Made to not chip the hard facing .
Re: Question with a new project [Re: Wirenut] #2944279
07/17/21 01:15 PM
07/17/21 01:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Bad340 - sounds like too much air through the grille.
It hits the radiator & support and dams up.
Try blocking the upper grilles off, either in front or behind.
Re: Question with a new project [Re: topside] #2944290
07/17/21 01:59 PM
07/17/21 01:59 PM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
Extend the front of the scoop all the way to the front edge of the hood with a taper.
Re: Question with a new project [Re: Wirenut] #2944338
07/17/21 04:34 PM
07/17/21 04:34 PM
Mt Morris Michigan
Mt Morris Michigan
I will go to HomeDepot to night and see what a can find.
Re: Question with a new project [Re: mopar dave] #2944584
07/18/21 03:50 PM
07/18/21 03:50 PM
Mt Morris Michigan
Mt Morris Michigan
Point gone. Will fill and sand out next weekend.
