don't laugh
#2943370
07/15/21 11:02 AM
07/15/21 11:02 AM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
hi, can i replace the air in my tires with helium to make the car lighter
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: don't laugh
[Re: 440lebaron]
#2943380
07/15/21 11:23 AM
07/15/21 11:23 AM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
Technically yes However it would be immeasurable on a racecar scale BTW Nitrogen would also do the same thing as far as weight. But sense the air we breathe is composed of more nitrogen than oxygen it would be almost statistically insignificant.
Re: don't laugh
[Re: Al_Alguire]
#2943384
07/15/21 11:30 AM
07/15/21 11:30 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’ve found out the easiest way to lose weight in a race car is for the driver to go on diet. And even that isn’t easy.
Re: don't laugh
[Re: 440lebaron]
#2943693
07/15/21 08:10 PM
07/15/21 08:10 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Nitrogen molicules are bigger than O2 molicules and won't loose pressure like O2 does, especially when sitting they don't expand with heat or shrink with cold either
Re: don't laugh
[Re: Cab_Burge]
#2943816
07/16/21 07:33 AM
07/16/21 07:33 AM
Posts: 630 Ct
Wirenut
Ct
Nitrogen molicules are bigger than O2 molicules and won't loose pressure like O2 does, especially when sitting they don't expand with heat or shrink with cold either Correct and that’s while circle trackers use it. Don’t know if it would benefit us
Re: don't laugh
[Re: Wirenut]
#2943826
07/16/21 08:09 AM
07/16/21 08:09 AM
Posts: 1,841 South Bend
John Brown
South Bend
Nitrogen molicules are bigger than O2 molicules and won't loose pressure like O2 does, especially when sitting they don't expand with heat or shrink with cold either Correct and that’s while circle trackers use it. Don’t know if it would benefit us It might make your wallet lighter.....
Re: don't laugh
[Re: Wirenut]
#2943833
07/16/21 08:33 AM
07/16/21 08:33 AM
Posts: 165 W. Pa
usp4u
W. Pa
Nitrogen molicules are bigger than O2 molicules and won't loose pressure like O2 does, especially when sitting they don't expand with heat or shrink with cold either Correct and that’s while circle trackers use it. Don’t know if it would benefit us Not really. Dont forget the regular atmosphere you are currently pumping in your tires is already 78% nitrogen, 21% oxygen, 1% various other gases
Re: don't laugh
[Re: usp4u]
#2943838
07/16/21 09:02 AM
07/16/21 09:02 AM
Posts: 1,385 Az
69hemibeep
Az
Nitrogen molicules are bigger than O2 molicules and won't loose pressure like O2 does, especially when sitting they don't expand with heat or shrink with cold either Correct and that’s while circle trackers use it. Don’t know if it would benefit us Not really. Dont forget the regular atmosphere you are currently pumping in your tires is already 78% nitrogen, 21% oxygen, 1% various other gases I have yet to see anyone try to collapse a tire to get all the air out before filling with nitrogen so it is still a mix
1969 Hemi Roadrunner 2nd owner
Re: don't laugh
[Re: usp4u]
#2943840
07/16/21 09:05 AM
07/16/21 09:05 AM
Posts: 1,229 In The Hills
jughed
In The Hills
Nitrogen molicules are bigger than O2 molicules and won't loose pressure like O2 does, especially when sitting they don't expand with heat or shrink with cold either Correct and that’s while circle trackers use it. Don’t know if it would benefit us Not really. Dont forget the regular atmosphere you are currently pumping in your tires is already 78% nitrogen, 21% oxygen, 1% various other gases That translates to, barring a puncture, a cut, a broken valve, etc., a tire will only deflate to the 78% level.....??
Re: don't laugh
[Re: pittsburghracer]
#2943920
07/16/21 01:18 PM
07/16/21 01:18 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
lmao
