don't laugh #2943370
07/15/21 11:02 AM
07/15/21 11:02 AM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hi, can i replace the air in my tires with helium to make the car lighter
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: don't laugh [Re: 440lebaron] #2943380
07/15/21 11:23 AM
07/15/21 11:23 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Technically yes grin However it would be immeasurable on a racecar scale cool BTW Nitrogen would also do the same thing as far as weight. But sense the air we breathe is composed of more nitrogen than oxygen it would be almost statistically insignificant.
Re: don't laugh [Re: Al_Alguire] #2943384
07/15/21 11:30 AM
07/15/21 11:30 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I’ve found out the easiest way to lose weight in a race car is for the driver to go on diet. And even that isn’t easy.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: don't laugh [Re: pittsburghracer] #2943393
07/15/21 11:46 AM
07/15/21 11:46 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Back in my tunnel-hull boat racing days, we thought of doing that in the sponsons, thinking the boat would always be on plane and lighter.
But the added weight of containment would likely offset any gains.
I think the entire discussion contained laughter...
Re: don't laugh [Re: 440lebaron] #2943693
07/15/21 08:10 PM
07/15/21 08:10 PM
Nitrogen molicules are bigger than O2 molicules and won't loose pressure like O2 does, especially when sitting up
they don't expand with heat or shrink with cold either up scope
Re: don't laugh [Re: Cab_Burge] #2943816
07/16/21 07:33 AM
07/16/21 07:33 AM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Correct and that’s while circle trackers use it.
Don’t know if it would benefit us
Re: don't laugh [Re: Wirenut] #2943826
07/16/21 08:09 AM
07/16/21 08:09 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
It might make your wallet lighter.....
Re: don't laugh [Re: Wirenut] #2943833
07/16/21 08:33 AM
07/16/21 08:33 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
Not really. Dont forget the regular atmosphere you are currently pumping in your tires is already 78% nitrogen, 21% oxygen, 1% various other gases
Re: don't laugh [Re: usp4u] #2943838
07/16/21 09:02 AM
07/16/21 09:02 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I have yet to see anyone try to collapse a tire to get all the air out before filling with nitrogen so it is still a mix
1969 Hemi Roadrunner 2nd owner
Re: don't laugh [Re: usp4u] #2943840
07/16/21 09:05 AM
07/16/21 09:05 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
That translates to, barring a puncture, a cut, a broken valve, etc., a tire will only deflate to the 78% level.....??
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: don't laugh [Re: pittsburghracer] #2943920
07/16/21 01:18 PM
07/16/21 01:18 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
lmao
Re: don't laugh [Re: Cab_Burge] #2944129
07/17/21 12:21 AM
07/17/21 12:21 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Nitrogen, Oxygen, and air are all 1.38 on the Ideal Gas laws, the heat ratio of all three are 1.38
Re: don't laugh [Re: wyoming] #2944167
07/17/21 04:20 AM
07/17/21 04:20 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
thank you up
It's incredible how much pseudo-scientific baloney is accepted as fact. Next up, "the coolant is moving too fast through the radiator to shed heat" rolleyes
Re: don't laugh [Re: wyoming] #2944322
07/17/21 03:59 PM
07/17/21 03:59 PM
What does this mean confused help
