Why are you people letting me work unsupervised? #2937522
06/28/21 01:02 AM
06/28/21 01:02 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I primed the oil system today on the 541. It took surprisingly little effort to hit 20 psi. The drill was barely moving.
Spinning it a little faster saw a max of 75 psi.
Then, my faithful assistant turned the crank so we could verify oil to the rockers.
Someone really should have reminded me that the Comp roller rockers have oil holes on the top.
Did you know that with 75 psi you can spray 8 perfectly straight streams of oil and hit the lathe 17 feet away?
laugh2
- Stu Harmon
Re: Why are you people letting me work unsupervised? [Re: feets] #2937538
06/28/21 05:48 AM
06/28/21 05:48 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Just wipe down the ways with it and call it good.
Re: Why are you people letting me work unsupervised? [Re: justinp61] #2937542
06/28/21 07:11 AM
06/28/21 07:11 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Rust prevention for the lathe.
Re: Why are you people letting me work unsupervised? [Re: fbs63] #2937571
06/28/21 09:32 AM
06/28/21 09:32 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'll go out on a limb here and predict adequate oiling will not be a problem...
Re: Why are you people letting me work unsupervised? [Re: topside] #2937605
06/28/21 11:33 AM
06/28/21 11:33 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
FYI, the same thing happens with gasoline. It will shoot out and cover the walls if you have stuck floats and remove the spark plugs to clear the cylinders.
'63 Dodge 330
11.19 @ 121 mph
Re: Why are you people letting me work unsupervised? [Re: feets] #2937608
06/28/21 11:46 AM
06/28/21 11:46 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
obviously non of us wants your lathe to get rusty stirthepot
Re: Why are you people letting me work unsupervised? [Re: 1Fast340] #2937618
06/28/21 12:14 PM
06/28/21 12:14 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
You should see what a 1/8" dia stream at 600psi does... you cant even react fast enough to prevent cleaning the rest of the day.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Why are you people letting me work unsupervised? [Re: feets] #2937619
06/28/21 12:17 PM
06/28/21 12:17 PM
Who forgot to use restrictors to the rocker arm shafts whistling shruggy scope wrench twocents
Re: Why are you people letting me work unsupervised? [Re: feets] #2937696
06/28/21 03:54 PM
06/28/21 03:54 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Any chance the rocker shafts are upside down?
Re: Why are you people letting me work unsupervised? [Re: Cab_Burge] #2937703
06/28/21 04:08 PM
06/28/21 04:08 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
What I was thinking. That's oil filling up the heads instead of being on the bearings.
Re: Why are you people letting me work unsupervised? [Re: CMcAllister] #2937730
06/28/21 05:01 PM
06/28/21 05:01 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You have to remember that when the engine is running, the holes in the cam to feed the heads only line up for a split second every other revolution.
There is no flood of oil going to the top end with the interrupted factory thru-the-cam oiling when the engine is running.
Re: Why are you people letting me work unsupervised? [Re: fast68plymouth] #2937741
06/28/21 05:27 PM
06/28/21 05:27 PM
Mooresburg, Tn
'72CudaRacer Online content
'72CudaRacer  Online Content
Mooresburg, Tn
Unless you have a Koleno block.
Brian
Re: Why are you people letting me work unsupervised? [Re: feets] #2937749
06/28/21 05:49 PM
06/28/21 05:49 PM
AndyF Offline
AndyF  Offline
Clear valve covers are the way to solve that problem. Then you can watch the oiling without getting it on you.
Re: Why are you people letting me work unsupervised? [Re: fast68plymouth] #2937764
06/28/21 06:40 PM
06/28/21 06:40 PM
I have all my BB Mopars solid roller cams and most hydraulic roller cams grooved on the #4 cam journal to oil the rocker shafts full time to help oil cool the valve springs for better valve spring life, especially on my street motors up Same thing on SB also on # 2 and #4 cam journals wrench
Restrict as needed wrench
Re: Why are you people letting me work unsupervised? [Re: fast68plymouth] #2938775
07/01/21 03:16 PM
07/01/21 03:16 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
But it floods nicely when you've got pressure up and your faithful assistant stops turning the crank because he burst out in laughter.
- Stu Harmon
Re: Why are you people letting me work unsupervised? [Re: feets] #2939800
07/04/21 12:00 PM
07/04/21 12:00 PM
moparx Offline
moparx  Offline
you can tell a "true" friend, because he picks you up...............after he stops laughing........... laugh2
beer
